UTEC 'Upgrade?'
Old Jan 3, 2009 | 07:53 AM
  #421
JonnyC's Avatar
JonnyC
Sorry - I was only suggesting UTI-ME for manually editing a map. After I go out and do some runs (going to the grocery store or something), I bring my laptop inside and analyze the logs. Then I just make changes to the map using ME, and upload it to the UTEC next time I go for a drive.
For some reason I was under the impression that the AutoTune feature only worked for MAF based tuning, not Speed Density. Not sure if that's right though.
Only thing I wish ME allowed you to do is set the color scaling on the fuel map. It doesn't help when you see all blue. If I wasn't lazy, I could make a simple excel spreadsheet to do the coloring for me.
Old Jan 3, 2009 | 09:49 AM
  #422
athenG's Avatar
athenG
/\ I was talking about the Autotune, maybe you are right about the the Autotune only working with Maf base tuning... I dont bother using the ME when using the logs coz I'm afraid that chit may happen on the upload process so I just make changes directly in Utec after looking at the raw logs.. lol It is easier for me this way.
Old Jan 3, 2009 | 10:44 AM
  #423
str8dum1's Avatar
str8dum1
in dashboard mode, can you guys also see you rpm with the latest version of UTI?
i can manually record my IAT's but without RPM info, its kinda worthless. I sent a mssg to Jeff thru his website, but no response.
Old Jan 4, 2009 | 06:38 PM
  #424
JonnyC's Avatar
JonnyC
I don't believe I was able to record RPM in Dashboard mode in UTI 3. I'm still using 2.75.
Old Jan 8, 2009 | 11:08 PM
  #425
whoojong's Avatar
whoojong
Does the most recent version of UTI work with the UEGO yet? It says it does on the site.
Old Jan 9, 2009 | 11:13 AM
  #426
zerosec's Avatar
zerosec
Do you guys use the MPS UTEC logger ? they released the new version 3.0
im goin to used with it when i'll go TT...
what u do think ?
btw, is it possible to lock the map to nobody else can access it ?
10x
Old Jan 9, 2009 | 02:46 PM
  #427
str8dum1's Avatar
str8dum1
there is a pin option in one of the settings. just type your 4 digit pin and it locks the utec.
yes, the aem wideband has been support for quite a while.
Old Jan 25, 2009 | 09:02 PM
  #428
nothix's Avatar
nothix
Two questions
1 - Can you edit maps when connected to the utec through the tuner? (Laptop -> Tuner -> UTEC)
2 - Can you output to a boost gauge from the Tuner or UTEC?
Thanks
Old Jan 26, 2009 | 09:51 AM
  #429
nothix's Avatar
nothix
I guess I'll need to make a new thread to get my question answered
Old Jan 27, 2009 | 07:32 PM
  #430
nothix's Avatar
nothix
bump, I know someone has experience with the utec tuner
Old Apr 2, 2009 | 04:54 PM
  #431
CaneZMD's Avatar
CaneZMD
So going back to mps logger for us zeitronix guys, I'm having trouble connecting to the wbo2.
Utec is on com3 via usb and connects to mps fine. Zeitronix is on com4 via serial to usb and connects fine via zeitronix software, but I can't connect to it via mps. Anyone have similar problems.
Please no posts about "why do you have zeitronix" or "you should get an innovate wbo2". I have what I have and I want it to work.
Old Apr 3, 2009 | 01:37 PM
  #432
CaneZMD's Avatar
CaneZMD
So has anyone used MPS logger with the zeitronix wideband?
Old May 16, 2009 | 11:50 PM
  #433
scout35316's Avatar
scout35316
hey just payed for this uti and now cant seem to get to a place to download it
Old May 17, 2009 | 05:42 AM
  #434
frankie945's Avatar
frankie945
You have to log in then you can download UTI and ME. Check your email for your password.
http://www.jeffsoftware.com/
Old Jun 9, 2009 | 12:22 PM
  #435
MardiGrasMax's Avatar
MardiGrasMax
Default UTI Log
I was wondering if any of the heavy tuners out their could look at my UTI logs and let me know what they think... The set up is Greddy TT w/ SFR dual G intercoolers, 2.5" test pipes into a 3" Megan Y pipe with a 3" cut out. 8.8 Weisco pistons, Eagle Rods, ARP head and main studs, S1 cams, intake spacer, single Walbro in tank, 650cc injectors, 2 step colder NGK IX. 5AT, VB, TC, cooler and external filter.
I was considering adding a bit more timing in the lower RPMs, but this is on 93 pump gas... How do you think the timing looks?
UTEC Fuel and Timing file is at the end
[TSMP][RPM][PSIG][TPS][LOD][KN][IPWm][IGN][WBO2][TAFR]
3rd MAP 32,27,20 cut out closed
000.00 5027 +2.9 100 20 0 12.20 16.0 12.33 12.00
000.08 5073 +4.7 101 30 0 13.58 15.8 11.62 11.80
000.14 5192 +6.7 101 50 0 14.86 15.4 11.14 11.50
000.23 5224 +8.1 100 50 0 15.67 15.0 11.12 11.50
000.34 5341 +9.1 100 60 0 16.15 15.0 11.20 11.50
000.42 5411 +9.6 101 60 0 16.79 14.6 11.28 11.50
000.53 5455 +10.0 101 70 0 17.14 14.5 11.43 11.40
000.63 5518 +10.5 102 70 0 17.72 14.2 11.33 11.40
000.73 5518 +11.0 99 70 0 18.05 14.0 11.23 11.40
000.83 5583 +11.3 101 70 0 18.21 13.9 11.08 11.40
000.92 5707 +11.6 99 70 0 18.34 14.1 10.99 11.40
001.03 5707 +11.7 99 70 0 18.38 14.2 10.96 11.40
001.13 5727 +11.7 101 70 0 18.44 14.0 10.87 11.40
001.22 5847 +11.7 85 70 0 18.00 13.9 10.83 11.40
001.33 5817 +12.1 30 70 0 18.46 14.0 10.80 11.40
000.00 5473 +2.6 94 20 0 12.30 15.0 13.47 12.00
000.11 5555 +5.1 99 40 0 13.89 15.2 12.11 11.60
000.20 5649 +6.8 99 40 0 14.87 15.3 11.49 11.60
000.33 5767 +8.4 99 50 0 15.50 15.4 11.37 11.50
000.42 5668 +9.2 99 60 0 16.43 15.4 11.62 11.50
000.52 5777 +9.5 99 60 0 16.53 15.4 11.89 11.50
000.63 5817 +9.9 99 60 0 16.79 15.1 11.92 11.50
000.72 5858 +10.5 99 70 0 17.35 14.9 11.98 11.40
000.83 5931 +11.0 99 70 0 17.62 14.8 11.96 11.40
000.91 5984 +11.0 99 70 0 17.85 14.7 11.89 11.40
001.00 6038 +11.2 98 70 0 18.18 14.7 11.87 11.40
001.11 6082 +11.3 98 70 0 18.57 14.3 11.77 11.40
001.20 6093 +11.4 99 70 0 18.34 14.4 11.76 11.40
001.31 6195 +11.6 99 70 0 18.09 14.9 11.73 11.40
001.41 6207 +11.0 99 70 0 17.75 15.4 11.65 11.40
001.50 6253 +11.0 99 70 0 18.08 15.2 11.56 11.40
001.61 6361 +10.6 98 70 0 17.75 15.3 11.43 11.40
001.70 6337 +11.1 99 70 0 17.97 15.6 11.42 11.40
001.81 6472 +11.1 97 70 0 17.73 15.6 11.39 11.40
001.91 6472 +10.7 84 70 0 17.87 15.7 11.34 11.40
002.00 6523 +11.0 14 70 0 17.68 15.8 11.30 11.40
Continued in the next post...
Old Jun 9, 2009 | 12:24 PM
  #436
MardiGrasMax
3rd MAP 32,27,20 cut out open
000.00 4553 +3.4 79 30 0 12.36 16.0 12.64 11.80
000.09 4681 +5.3 88 40 0 13.84 16.0 12.33 11.60
000.20 4675 +7.4 102 50 0 15.30 16.0 12.00 11.50
000.31 4675 +9.5 101 60 0 16.53 15.8 11.80 11.50
000.42 4816 +10.3 100 70 0 17.24 15.4 11.96 11.40
000.52 4901 +10.7 100 70 0 17.95 15.0 12.11 11.40
000.63 5020 +11.2 102 70 0 18.38 14.8 12.33 11.40
000.72 4990 +11.7 101 70 0 19.14 14.5 12.33 11.40
000.81 5050 +12.1 100 80 0 19.44 14.0 12.17 11.20
000.91 5175 +12.4 100 80 0 19.50 13.7 11.98 11.20
001.02 5257 +12.8 101 80 0 19.68 13.5 11.89 11.20
001.11 5265 +13.1 101 80 0 20.03 13.3 11.92 11.20
001.22 5376 +13.2 101 90 0 20.09 13.3 11.81 11.00
001.31 5420 +13.5 100 90 0 20.24 13.2 11.81 11.00
001.41 5491 +13.5 100 90 0 20.43 13.2 11.76 11.00
001.52 5537 +13.6 101 90 0 20.83 13.1 11.68 11.00
001.61 5611 +13.9 102 90 0 21.04 12.9 11.62 11.00
001.72 5668 +13.9 99 90 0 20.68 13.1 11.53 11.00
001.81 5767 +13.5 100 90 0 20.25 13.1 11.53 11.00
001.91 5787 +13.4 100 90 0 19.91 13.1 11.42 11.00
002.02 5889 +13.6 100 90 0 19.66 13.1 11.37 11.00
002.11 5920 +13.3 100 80 0 19.62 13.1 11.28 11.20
002.22 5910 +13.3 100 80 0 19.49 13.2 11.24 11.20
002.31 5984 +13.3 100 80 0 19.41 13.2 11.28 11.20
002.41 6016 +13.2 100 80 0 19.07 13.2 11.37 11.20
002.52 6060 +13.3 100 80 0 19.17 13.2 11.37 11.20
002.61 6127 +13.1 100 80 0 19.15 13.5 11.39 11.20
002.72 6093 +12.4 100 80 0 19.14 13.9 11.33 11.20
002.81 6195 +11.8 100 80 0 18.71 14.1 11.23 11.20
002.92 6253 +11.8 100 70 0 18.38 15.0 11.18 11.40
003.02 6265 +11.3 99 70 0 18.45 14.9 11.14 11.40
003.11 6373 +11.0 100 70 0 18.02 14.9 11.12 11.40
003.22 6349 +11.1 99 70 0 18.31 15.0 11.11 11.40
003.31 6447 +11.0 100 70 0 18.19 15.2 11.08 11.40
003.41 6574 +10.9 100 70 0 17.80 15.3 11.02 11.40
003.52 6510 +10.5 100 70 0 17.86 15.4 10.96 11.40
003.61 6587 +10.7 29 70 0 17.91 15.6 10.93 11.40
4th gear Wierd pull???
000.00 3862 +2.7 101 20 0 11.71 16.8 12.37 12.00
000.09 3930 +3.7 101 30 0 12.40 16.4 12.11 11.80
000.20 4074 +4.6 101 30 0 12.96 15.7 11.71 11.80
000.33 4140 +5.8 100 40 0 14.09 15.0 11.39 11.60
000.42 4246 +7.1 101 50 0 15.15 15.1 11.11 11.50
000.53 4462 +8.4 101 50 0 15.68 15.7 10.90 11.50
000.63 4585 +9.8 101 60 0 16.70 15.6 10.93 11.50
000.72 4734 +11.0 100 70 0 18.00 14.9 11.11 11.40
000.83 4837 +11.7 100 70 0 19.10 14.5 11.33 11.40
000.92 4945 +12.0 101 80 0 19.27 14.4 11.52 11.20
001.02 4901 +12.2 101 80 0 19.73 14.1 11.61 11.20
001.11 4930 +12.7 99 80 0 19.89 14.0 11.43 11.20
001.22 4952 +12.8 100 80 0 20.06 13.8 11.14 11.20
001.31 4967 +13.1 101 80 0 20.12 13.7 11.01 11.20
001.41 4967 +13.2 101 80 0 20.54 13.7 10.99 11.20
001.52 5005 +13.3 100 90 0 20.79 13.5 10.99 11.00
001.61 4775 +13.6 100 90 0 20.51 13.4 11.01 11.00
001.72 4591 +13.9 101 90 0 20.23 13.4 11.02 11.00
001.81 4566 +13.9 101 90 0 20.32 13.4 10.96 11.00
001.92 4522 +13.9 100 90 0 20.73 13.2 11.02 11.00
002.02 4541 +14.0 98 90 0 20.48 13.1 11.05 11.00
002.11 4541 +14.1 96 90 0 20.69 13.1 10.96 11.00
002.22 4559 +14.1 61 90 0 20.69 13.2 11.01 11.00
3rd gear MAP 32,27,20 cut out open
000.00 3875 +2.5 102 20 0 11.46 16.9 12.53 12.00
000.11 3898 +3.4 101 30 0 12.34 16.4 12.49 11.80
000.20 4035 +4.7 100 30 0 13.20 15.6 12.21 11.80
000.31 4120 +6.0 100 40 0 14.27 15.0 12.00 11.60
000.42 4203 +7.5 101 50 0 15.62 15.0 11.67 11.50
000.52 4368 +9.2 101 60 0 16.37 15.4 11.42 11.50
000.63 4492 +10.6 102 70 0 17.55 15.0 11.52 11.40
000.72 4572 +11.8 100 70 0 19.21 14.5 11.80 11.40
000.81 4662 +12.1 101 80 0 19.72 14.3 12.09 11.20
000.91 4761 +12.2 101 80 0 19.58 14.2 12.27 11.20
001.00 4844 +12.6 102 80 0 19.89 14.0 12.37 11.20
001.09 4938 +12.9 100 80 0 20.27 13.8 12.11 11.20
001.20 4930 +13.2 103 80 0 20.91 13.6 11.89 11.20
001.30 4997 +13.4 102 90 0 20.89 13.5 11.76 11.00
001.41 5104 +13.6 101 90 0 20.74 13.4 11.71 11.00
001.50 5128 +13.8 100 90 0 21.01 13.1 11.71 11.00
001.61 5200 +14.0 100 90 0 21.14 13.1 11.67 11.00
001.70 5241 +14.0 101 90 0 21.06 13.0 11.67 11.00
001.80 5316 +14.0 101 90 0 21.08 12.9 11.68 11.00
001.91 5402 +14.1 100 90 0 21.10 12.9 11.62 11.00
002.00 5428 +14.2 100 90 0 21.00 12.8 11.67 11.00
002.09 5491 +14.1 101 90 0 21.07 12.9 11.61 11.00
002.20 5564 +14.1 101 90 0 20.90 12.8 11.56 11.00
002.30 5611 +14.2 100 90 0 21.13 12.8 11.52 11.00
002.41 5668 +14.1 100 90 0 20.98 13.0 11.43 11.00
002.50 5757 +13.6 100 90 0 20.49 13.1 11.34 11.00
002.59 5807 +13.4 100 90 0 19.90 13.0 11.18 11.00
002.70 5847 +13.6 97 90 0 19.76 13.1 11.08 11.00
002.80 5868 +13.3 96 80 0 19.55 13.1 11.06 11.20
002.91 5931 +13.4 80 80 0 19.52 13.2 11.14 11.20
003.00 5920 +13.3 41 80 0 19.66 13.2 11.23 11.20
Continued
  #437
MardiGrasMax
[START][MAPGROUP1][MAPGROUP]
Map Name:-[Matt Turbo 27]
Map Comments:-[Pump Gas]
Fuel Map
[0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0]
[-14] [61.5] [96.5] [112.5] [125] [129.5] [142.5] [149.5] [156.5] [157.8] [160]
[-14] [62.5] [99.5] [114.5] [127] [130.5] [142.5] [151.2] [158.9] [161.1] [162]
[-14] [63.5] [101.5] [116.5] [129] [131.5] [143.5] [152.9] [161.3] [164.4] [164]
[-14] [67.5] [103.5] [119.5] [132] [133.5] [143.5] [154.5] [163.7] [167.7] [167]
[-14.5] [69.5] [104.5] [120.5] [132.5] [134.5] [144.5] [156.2] [166.1] [171] [176]
[-14.8] [71.5] [105.5] [121.5] [133.5] [135.5] [144.5] [157.9] [168.5] [174.3] [182]
[-15] [72.5] [108.5] [121.5] [133.5] [136.5] [145.5] [159.6] [170.9] [177.5] [187]
[-15] [73.5] [110.5] [122.5] [134.5] [137.5] [145.5] [161.2] [173.3] [180.8] [188]
[-15] [74.5] [110.5] [122.5] [136.5] [138.5] [147.5] [162.9] [175.8] [184.1] [193]
[-15] [75.5] [111.5] [122.5] [137] [139.5] [148.5] [164.6] [178.2] [187.4] [186]
[-15] [76.5] [111.5] [123.5] [137.5] [140.5] [149.5] [166.3] [180.6] [190.7] [184]
[-15] [77.5] [113.5] [123.5] [138] [141.5] [152] [167.9] [183] [194] [204]
[-15] [79.5] [114.5] [124.5] [137.5] [144.5] [155] [169.6] [185.4] [195] [205]
[-15.3] [79.5] [115.5] [124.5] [138.5] [147.5] [157] [171.3] [187.8] [198] [208]
[-15.6] [81.5] [116.5] [125.5] [141] [151] [161] [173] [190.2] [200] [210]
[-16] [81.5] [118.5] [126.5] [141.5] [152] [162] [174.6] [192.6] [203] [213]
[-16] [83.5] [119.5] [128.5] [143] [153] [161] [176.3] [195] [205] [214]
[-16] [83.5] [120] [129.5] [143] [153] [159] [178] [199] [208] [215]
[-15] [94.5] [120.5] [130.5] [144.5] [153.5] [161] [182] [198] [212] [219]
[-15] [84.5] [120] [131.5] [144] [152.5] [160] [180] [192.5] [209] [217]
[-15] [85.5] [119.5] [130.5] [143.5] [150.5] [161] [177.5] [189.5] [207] [212]
[-15] [85.5] [119] [129.5] [143] [147.5] [160.5] [175.5] [186.5] [206] [212]
[-13] [87.5] [118.5] [128.5] [142.5] [144.5] [160] [176] [188.5] [198] [200]
[-13] [87.5] [118] [127.5] [143] [143.5] [159.5] [178.5] [190.5] [192] [192]
[-13] [89.5] [117.5] [126.5] [142.5] [142.5] [159] [179.5] [184.6] [184.6] [184.6]
[-13] [89.5] [117.5] [125.5] [142] [142.5] [159] [177.8] [177.8] [177.8] [177.8]
[-13] [89.5] [117.5] [125.5] [140.5] [142.5] [159] [171.4] [171.4] [171.4] [171.4]
[-13] [89.5] [117.5] [125.5] [140.5] [142.5] [159] [165.5] [165.5] [165.5] [165.5]
[-13] [89.5] [117.5] [125.5] [140.5] [142.5] [159] [160] [160] [160] [160]
Timing Map
[-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100]
[-100] [16] [16] [15] [14] [14] [14] [13] [12] [11] [10]
[-100] [17] [17] [16] [15] [14] [14] [13.2] [12.5] [11.8] [11]
[-100] [17] [17] [16] [15] [15] [15] [14] [13] [12] [11]
[-100] [16] [16] [15] [15] [15] [15] [14] [13] [12] [11]
[-100] [16] [16] [16] [16] [16] [16] [15] [14] [13] [12]
[-100] [15] [15] [15] [15] [15] [15] [14] [13.5] [12.8] [12]
[-100] [16] [16] [16] [15.5] [15.5] [15.5] [14.5] [13.5] [12.7] [12]
[-100] [17] [17] [17] [16.5] [16.5] [15.5] [15] [13.5] [12.5] [12]
[-100] [18] [17.4] [17.5] [17] [17] [16] [15.5] [13.5] [12.5] [12]
[-100] [18] [18] [18] [17] [17] [16] [15.5] [13.5] [12.5] [12]
Old Dec 19, 2009 | 11:05 AM
  #438
ZeLiCiOuS350's Avatar
ZeLiCiOuS350
Default compatiable???
Is the utech piggy back system universal or make specific???
Old Dec 20, 2009 | 08:48 AM
  #439
El Verdugo's Avatar
El Verdugo
Make specific. Go to the website and you will see what I am talking about.
Old Dec 21, 2009 | 07:16 AM
  #440
Sparks03Max's Avatar
Sparks03Max
Can any of you N/A guys going above stock redline with MAF based open loop mode tell me what your fuel correction looks like up top? I'm adding as much as 20% fuel above 6900 RPMs and it's still getting into the low 13s from 7000-7200, when I'm wanting 12s. I'm not sure what else to do to get it to run a little richer. I highly doubt I'm limited by fueling at this point.
Actually, I've been looking at the UTEC manual and it says a "soft limiter" kicks in 250 rpms before my hard limiter. I have that set at 7200. So what's happening from 6950 until 7200 is a fuel cut? No wonder I'm having so much trouble tuning up there... lol
