How does the stock speed limiter actually work?
Old Nov 28, 2006 | 08:42 AM
350Z_LMS's Avatar
350Z_LMS
Default How does the stock speed limiter actually work?
just curious. I know the UTEC still can't raise the rev limit on revup engines. so I was wandrering why. then, I asked myself how the stock system works (revup or not doesn't matter). is it just a rev signal period? in this case it's a rev limiter as opposed to a speed limiter. but the manufacturer says it's "limited" to 250km/h (even though the display on mine has read 262 without a sign of a limit). any guru care to explain this? thanks a million
Old Nov 28, 2006 | 02:12 PM
undrgnd's Avatar
undrgnd
I'm no guru, but I suspect when your speedo was reading 262 you must have been very close to hitting your limit, unless someone has altered the ECU. I believe our cars have a fuel cutoff at the redline, plus a speed limiter at 155mph.
Old Nov 28, 2006 | 02:14 PM
rocks's Avatar
rocks
I have got too 159mph in my car and 158 in a testdrive 06z. Mine would not go over 159mph. This was on the digital speedo so i have no idea how accurate it is...
Old Nov 28, 2006 | 11:50 PM
350Z_LMS's Avatar
350Z_LMS
so it would be 2 different measurements then? revs AND speed? could be I guess, just curious to find out exactly. no, my ecu is stock (+UTEC, but that cannot alter the speed limit on my revup)
Old Nov 29, 2006 | 11:55 PM
350Z_LMS's Avatar
350Z_LMS
ok, so let me rephrase: how does the UTEC change the rev limit on non revups? Can the UTEC (or any other piggyback) get rid of the speed limiter?
Old Nov 30, 2006 | 08:03 PM
blueper4mancez's Avatar
blueper4mancez
you could get your speed limiter off at technosquare i believe it call lm spec flash .
Old Nov 30, 2006 | 08:12 PM
redman333's Avatar
redman333
Yeah, I called technosquare, they said they will take off my speed limiter for $365. My utec can control the rev limiter though.
Old Dec 1, 2006 | 08:33 AM
KhanMan's Avatar
KhanMan
doesn't that also take of the rev limiter.
Old Dec 1, 2006 | 11:02 AM
350Z_LMS's Avatar
350Z_LMS
my question is: how is it done? and what is the difference, if indeed there is one, between the rev limiter and the speed limiter?
Old Dec 5, 2006 | 11:18 PM
350Z_LMS's Avatar
350Z_LMS
people here are talking about reflashes, UTEC, emanage etc and noone has a clue as to the difference between the speed and rev limiter...that's weird...
Old Dec 6, 2006 | 01:43 AM
undrgnd's Avatar
undrgnd
^^^ It's called the internet.
Old Dec 6, 2006 | 04:19 AM
350Z_LMS's Avatar
350Z_LMS
and it probably means there are fewer gurus than I thought...shame on me!
Old Dec 6, 2006 | 04:22 AM
undrgnd's Avatar
undrgnd
I think there are several members here that can answer that question off the top of their heads, but have not chimed in. It may be in the FSM, but it's not very user-friendly, and I'm not in an FSM-friendly mood.
Old Dec 6, 2006 | 04:35 AM
350Z_LMS's Avatar
350Z_LMS
what do you mean by FSM? SM=service manual?thanks
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
hardkicks
Sep 20, 2015 12:28 PM
Shane86
Sep 17, 2015 05:33 PM
torchkc
Sep 11, 2015 08:26 PM
