Osiris from Uprev
Old Sep 29, 2007 | 02:46 PM
  #461
krnzzang84's Avatar
krnzzang84
Originally Posted by mikead_99
Won't work. It ties it's license to the first ECU s/n it connects too. That probably wouldn't be yours and if it was you would be screwing the original purchaser over as it would be unusable on his ECU.
ahh i c thank you, i didn't know it gets license to the first ecu
Old Sep 29, 2007 | 07:30 PM
  #462
__jb's Avatar
__jb
Z + Rear Seat
Originally Posted by Frostydc4
One last question before I order this. Since I have an 03 if I sent my AFR charts to you via e-mail would you be able to tweak the preloaded maps (or would you need datalogs)? Thanks.
Jared has mentioned updating Cipher to work with other wideband sensors, but as yet it doesn't.
The original "generic" tune from UpRev made a big difference for me before I ever got my first "custom" map based on the Cipher log. Unless you plan to get a real time dyno tune, the Osiris generic maps will probably still be your best bet.
Old Sep 30, 2007 | 12:10 PM
  #463
ssnake86's Avatar
ssnake86
Just had my car tuned on the Osiris at Church Automotive. can read about it here.
https://my350z.com/forum/engine-and-drivetrain/304798-dynoed-and-osiris-tuned-my-car-with-all-my-new-mods-graphs.html
Old Sep 30, 2007 | 06:30 PM
  #464
UpRev's Avatar
UpRev
Originally Posted by poorbastard
can they tune FI cars with this yet?
Osiris Rom Loader, the version we mail out, does not support FI vehicles.
If you can get your vehicle to one of our Osiris Pro Tuners (L.A. or Houston) or to us in Austin, then a custom tune can be made for your FI vehicle.
Matt.
Old Sep 30, 2007 | 06:31 PM
  #465
UpRev's Avatar
UpRev
Nah, that was Jared inside the car.
Originally Posted by __jb
Great job, Matt! Is that you inside the white Z in the video?
I can't believe you guys crashed an ECU in the video just to show that Osiris can repair it. Osiris' new repair feature is very cool!
Old Oct 1, 2007 | 07:43 AM
  #466
05Z33's Avatar
05Z33
If you don't have cruise control are there any options for multiple maps?
Old Oct 1, 2007 | 04:22 PM
  #467
Marshall2K's Avatar
Marshall2K
Just wanted to check in. Things are running great on my G so far.
I stopped by the local 1/8 mile track and ran a 9.3 on the generic tune (intake, spacer, hfc, 93 oct).
That's with the extra weight of a spare, jack, and sub.
Old Oct 1, 2007 | 07:22 PM
  #468
SergEK's Avatar
SergEK
Any previous runs?
Sounds like a 13.9 run 1/4 wise????
Old Oct 5, 2007 | 07:11 AM
  #469
tywinter's Avatar
tywinter
Default Tune Questions
Jared and/or Matt
I am very pleased with the power I gained from my OSIRIS, a couple questions though.
What do you set the A/F targets at on the NA tune?
Do your NA tunes apply any advancing of the timing?
Old Oct 5, 2007 | 06:04 PM
  #470
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Originally Posted by tywinter
Jared and/or Matt
I would be interested in knowing the same thing.
Are you guys bumping the timing 2 degrees or nothing at all. And what are you guys setting the A/F target at.
Let us know
Todd
Old Oct 5, 2007 | 07:42 PM
  #471
rocks's Avatar
rocks
I set my target a/f ratio to 13.0 and then tuned it as close as possible for it. The nissan timing is not like normal timing so its around 26-32 degrees.
Old Oct 6, 2007 | 04:54 PM
  #472
PunKidd's Avatar
PunKidd
Originally Posted by SunsetSunrise
Ok I just read all 22 pages on Osiris.
Whew!
1. For '03 what is the additional cost for extra parts?
2. If i purchase a used Osiris, do I get the ownership of the original License?
3. If decide to sell Osiris, I must remove the upgrade/tune from my ECU?
Thank you
1. About $300 if you go w/ the Innovate WB
http://www.innovatemotorsports.com/products/kits.php
2. Yep.
3. Osiris doesn't have the ability to get the license off of the ECU as the system stands right now. We can work w/ you to get the license off so that the system could be resold, but yourself as well as the receiving party would have to work w/ us so that we can get them set up w/ the proper compatible ROM.
We would need the AFR log/chart as well as a Cipher log that was run at the same time... hope you have more than one USB port .
Jared and/or Matt
Typically we target ~12.6 below 4400RPM then taper out to ~13.
There is most definitely advanced timing on the tuned maps. That is the primary difference between the low and high octane tuned maps.
Well… we haven’t tested this yet, but in theory you should be able to wire up some cruse control switches directly to the ECU. As far as we’ve been able to tell, the ECUs still supports cruse control even when the cruse option is not on the vehicle. So not only would maps switching work, you could probably use the cruse control as well. Not sure if the gauge cluster will have the LEDs for feed back.
Jared@UpRev.com
Old Oct 6, 2007 | 06:37 PM
  #473
XIceDragonX's Avatar
XIceDragonX
what if your ecu already has a custom tune? Would this just write over it and completely ignore it? And is there really that big of a power difference available runnin between 91 and 93 octane gas? I try my best to always run sunoco super 93 but I am just wonderin if 91 and an octane booster would suffice?? Or should I always run the gas the tune is made for no matter how short on cash I am at the current time? I ask cause my current tune says supposedly 92 or better octane.
Old Oct 6, 2007 | 07:22 PM
  #474
GolfinZ's Avatar
GolfinZ
Jared, I sent Matt a pm and Chung an email...could you hit me up when you can. Thanks-Brian
Old Oct 6, 2007 | 07:23 PM
  #475
PunKidd's Avatar
PunKidd
If you already have a reflash from TS or AAM then it will be overwritten.
The HP difference from 91 to 93 is pretty small, but you will defiantly lose HP if you run fuel of a lower octane than what it is tuned for. If the ECU detects any knock or ping, it will pull all kinds of timing and the HP will fall flat on it's face. That's why it's nice to have map switching w/ both a high and low octane tune .
Old Oct 6, 2007 | 07:54 PM
  #476
dovla's Avatar
dovla
Jared, if ECU doesn’t monitor knock above 4800 rpm, would it make sense to keep ignition advanced in high rpm but running richer AFR? Thanks
Old Oct 6, 2007 | 08:05 PM
  #477
PunKidd's Avatar
PunKidd
Running to 13 is not enough to make it ping. We can run the about the same advance at 13 as we can at 12.6, but it does make a bit more power when it's leaned out a bit. It doesn't make any more power down low w/ the leaner mix so that's why we leave it on the rich side down low.
But yeah, if you're not worried about the extra couple of HP then running 12.6 accross the board will keep things a little cooler.
Old Oct 6, 2007 | 09:41 PM
  #478
Peak350's Avatar
Peak350
Is there any way that you can set up a an e-mail list to let us know when the 07 ECU gets cracked?
I'm torn between UTEC and reflash, would like to be able to work with the tune on my own a bit and the map switching is definitely a good option.
Just curious, would it be possible to get an 87 map that just pulls an assload of timing. During bad storms (at least once a year lately) all we have for gas is 87 and I either have to never drive, or buy gas cans worth of premium in advance (had a BMW with mods before) to get through the 2-3 week premium drought.
Old Oct 7, 2007 | 11:19 AM
  #479
__jb's Avatar
__jb
Z + Rear Seat
I had a 87/89 Octane Tune on my first set of maps. I don't know if they could make a straight 87 octane map, but I don't see why not.
I've since swapped that 87/89 Octane Tune map out to add more tuned maps.
Old Oct 7, 2007 | 11:25 AM
  #480
Peak350's Avatar
Peak350
Yeah, thinking about it today, if they can play with throttle body opening, and rev limiter (by map) it would be great to have a low octane map that only allowed say 2/3 throttle and a 4,000 RPM redline (maybe 4,500 or something even) because I find myself driving the car harder than I should at times, and I could watch my fuel consumption that way as well. I'd only need 3 maps, a street tune (just improved from stock) the 87 economy tune, and the ***** out tune for drag/autocross.
