Strange UTEC problem. Map Sensor?
Old Jul 31, 2007 | 12:20 PM
memphiss13's Avatar
memphiss13
Default Strange UTEC problem. Map Sensor?
The car is an 03 350z w/ a vortech kit with 3.12 pulley, kinetix intake, 650cc injectors, and walbro fuel pump. It is running the UTEC with map sensor. The problem that I'm having with it is that the UTEC is not seeing the boost. I haven't made it all the way through the rpm range yet, but we have gotten up to 5psi or so and the UTEC barely gets into the 10% column. This is very dangerous because up until about 4700rpm the car is running off of the ecu timing. What would cause a problem like this? The map sensor is hooked up to manifold vacuum off of the same port as the boost gauge so they should be reading the exact same but they are not. I also punched in the calibrations that are on the card that came with the map sensor. Have any of you guys experienced this? Maybe just a bad map sensor? I'm running the 2.8 software if that matters also.
Old Jul 31, 2007 | 01:10 PM
athenG's Avatar
athenG
Were did you see the 5lbs PSI? from UTEC or your gauge?
Old Jul 31, 2007 | 01:41 PM
memphiss13's Avatar
memphiss13
from the boost gauge. the utec barely gets to 1psi
Old Jul 31, 2007 | 05:43 PM
wtf no turbo's Avatar
wtf no turbo
Line is pinched or a leak
Old Jul 31, 2007 | 06:56 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i have had a few bad map sensors lately but they havent done that. i would redo your vacuum lines first of all. check those. then see what you have.
Old Jul 31, 2007 | 07:46 PM
memphiss13's Avatar
memphiss13
good idea on the pinched line. i'll have to check that out. didn't even think about that possibility. i'll probably just rerun it all. thats the part that sucks about tuning a car you didn't do all the work on.
Old Aug 1, 2007 | 07:24 AM
memphiss13's Avatar
memphiss13
check all the hoses and no problems there. any other ideas?
Old Aug 1, 2007 | 12:30 PM
rcdash's Avatar
rcdash
If the lines flow well, then faulty map sensor or faulty utec is all that would be left as options I would think...
Old Aug 1, 2007 | 01:12 PM
tabbott's Avatar
tabbott
I currently have the same problem with my UTEC. I have replaced the MAP sensor twice now and my UTEC still doesn't read any boost. I checked all of the lines and everthing is good to go. I don't know what to do except to call TXS and see if they will swap out my UTEC. Good luck and let us know if you get it figured out.
Old Aug 1, 2007 | 03:31 PM
i8acobra's Avatar
i8acobra
Did you guys turn on the MAP sensor. The UTEC doesn't automatically detect it. In one of the options tables, you have to change "MAP sensor" from 0 to 1.
Old Aug 1, 2007 | 03:46 PM
memphiss13's Avatar
memphiss13
yeah i'm thinking faulty parts as well. everything is right in the parameters and such so its got to be bad parts. i'll let you guys know when i get it worked out. tabbott, let me know if you get yours figured out too.
Old Aug 1, 2007 | 11:13 PM
tabbott's Avatar
tabbott
Yeah I made sure my MAP sensor is on, set up for MAP instead of GUAGE. Also changed the fueling to speed density in the parameters. Everything is good on the UTEC, its just like the MAP is not there. I called TXS and they are gonna swap me out with a new UTEC after I send my old one back. I will update you all on this thread when I get the problem figured out.
Old Aug 22, 2007 | 08:01 AM
memphiss13's Avatar
memphiss13
just an update on this issue. it turned out that the vacuum tee that was going to the map sensor somehow had some blockage inside of it. one of the absolute strangest things i've ever seen. thats why the map sensor was never seeing the pressure though. b/c it was basically blocked off. its all fixed now and the car put down 330whp and 277ft/lb in 102deg weather. pretty fun car.
Old Aug 22, 2007 | 08:10 AM
06MagneticZ's Avatar
06MagneticZ
Good to hear its all fixed. What are all the supporting mods for that Vortech?? Just wondering.
Old Aug 22, 2007 | 01:01 PM
memphiss13's Avatar
memphiss13
9psi pulley, walbro 255, kinetix intake manifold, and hks true dual. graph looks like a bit of belt slip or clutch slip up top though b/c it gets a bit wavy.
Old Aug 22, 2007 | 01:12 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
post the graph. I think your numbers are a bit low for 9psi. I made 338 @7psi on a dyno dynamics with vortech, 3.33, utec, walbro and 440cc injectors.
Old Aug 23, 2007 | 07:27 AM
memphiss13's Avatar
memphiss13
well to be honest i think its a bit low too. i'm thinking it has to be a belt issue b/c of the fact that the car never actually saw 9psi in the logs. barely got to even 8psi and that wasn't till the very end. the slippage seems to start around 5k rpm or so. lots of belt dust near the charger too. probably will try the timrod pulley setup. oh well we'll get that stuff worked out later.
Old Aug 23, 2007 | 02:36 PM
tabbott's Avatar
tabbott
After I read this response I checked out the vacuum T on my MAP sensor. Wouldn't ya know it, mine was clogged or blocked too. I was using the supplied black T that came with the sensor. I swapped that out for a different one and the MAP sensor seems to be working now. TXS should check out those cheapo vacuum T's before they send em out, might save them some money on replacement sensors.
Old Aug 23, 2007 | 04:26 PM
memphiss13's Avatar
memphiss13
wow. i guess they just got a bad batch.
liqalu04
Jan 2, 2022 12:58 PM
Uriyo_
Sep 8, 2021 08:46 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
