How to connect AEM Uego to computer.
Old Apr 14, 2008 | 11:24 AM
jining's Avatar
jining
Damnit thanks for the info. Guess ill find another route
Old Apr 14, 2008 | 09:58 PM
jining's Avatar
jining
hmm so I did it and hooked it up, (im using UTI 3.5beta) but its not reading anything from my wb... went and made sure my ground was good and still nothing. Just sits at 9.0 a/f, any ideas?
Old Apr 15, 2008 | 02:36 AM
KPierson's Avatar
KPierson
Does it work with hyperterminal?
Old Apr 15, 2008 | 06:09 AM
jining's Avatar
jining
You mean is my hyperterminal working? Yea works normally. I am assuming that my usb/serial adapter must be the problem?
Old Apr 15, 2008 | 06:58 AM
KPierson's Avatar
KPierson
So you can see the correct A/F values in Hyperterminal but you can't see them in the UTI software? If that is the case I would think it would be in the UTI software.
Old Apr 15, 2008 | 07:53 AM
jining's Avatar
jining
oh... no actually I didnt check that. Can hyperterminal see the wideband? I thought that was the point of UTI, to basically put the wideband and the utec log together? Maybe im wrong, thanks for your help by the way.
I did notice that in uti on the top of the dashboard there is a line which looks like its taken from the utec logger display, which does display an a/f ratio. Hmmmm is that not usually there?? LOL... I thought it was the narrow band or something?
Old Apr 15, 2008 | 09:37 AM
KPierson's Avatar
KPierson
You're best bet would be to get the wideband working in hyperterminal, that way you will know your connection is correct. If you can't get it to work in hyperterminal you most likely won't get it to work in the UTI.
Old Apr 15, 2008 | 12:02 PM
jining's Avatar
jining
How do I get the wideband to work with hyperterminal? I didnt know that was possible?
This area is where it was displaying the utec logger line, i thought I saw an a/f in there but im not sure, could have been timing I didnt think to check.
Old Apr 15, 2008 | 05:43 PM
KPierson's Avatar
KPierson
Follow the instructions included with the AEM wideband. It actually walks you through connecting it and reading the data in hyperterminal.
Old Apr 15, 2008 | 07:12 PM
jining's Avatar
jining
ok let me check it out ill let you know, thanks again kpierson
Old Apr 15, 2008 | 07:17 PM
jining's Avatar
jining
holy hell it works! ok so... hmm i guess uti doesnt work? Any ideas how to go about this problem?
Old Apr 15, 2008 | 08:10 PM
jining's Avatar
jining
Update: I tried using UTI version 2.75 instead of the 3beta5 and it works!! Sweeeeet
m_0g
Jun 3, 2021 10:05 AM
Workshop12
Mar 23, 2020 01:45 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
