Mating a piggyback with a TS ECU
Old Sep 18, 2007 | 04:58 PM
!prjctmax!'s Avatar
!prjctmax!
Default Mating a piggyback with a TS ECU
I've had the TS ECU for quite some time now and recently purchased an E-Manage Blue with a plug n' play harness. (long story short, if I would have known about UTEC fitting in a 6th gen Maxima a while ago, then I would have gotten that instead of both of these, but ya and I also wanted the speed limiter and raised rev limit from the TS...can the UTEC do those two?)
Also, how are you 350Z guys dynoing with an accurate AFR printout if you HAVE CATS?
Main concern being...I've heard that with any piggy-back system, the ECU will "eventually adjust" and alter the piggy-backs settings. Is this true or am I thinking of something in the wrong way?
Thanks, and any insight would be greatly appreciated.
dan
Old Sep 19, 2007 | 08:04 AM
Chebosto's Avatar
Chebosto
if you get the limited spec tune from TechnoSquare, you dont have to worry about the "eventually adjust" , they take that feedback value out so you can use piggy back systems such as the Emanage Blue/Ultimate
Old Sep 19, 2007 | 03:01 PM
!prjctmax!'s Avatar
!prjctmax!
How do I know if I have the "limited spec tune?"
Old Sep 19, 2007 | 03:36 PM
Chebosto's Avatar
Chebosto
if you have timing and AFR changes, thats Full Spec
if you just got Rev Limiter, Throttle body, and Speed limiter delete. that's Limited Spec.
Old Sep 19, 2007 | 04:49 PM
!prjctmax!'s Avatar
!prjctmax!
wtg? lol that makes no sense though. So if I had ALL of those done, then what?
Old Sep 19, 2007 | 08:17 PM
Chebosto's Avatar
Chebosto
if you have ALL that done, then obviously you have the Full Spec.
you can still alter the AFR and timing on top of the Fspec.
Old Sep 20, 2007 | 06:29 AM
!prjctmax!'s Avatar
!prjctmax!
Without the ECU "adjusting itself," correct?
Old Sep 20, 2007 | 09:56 AM
Chebosto's Avatar
Chebosto
yes
Old Sep 20, 2007 | 10:13 AM
!prjctmax!'s Avatar
!prjctmax!
yes
Sweet, thanks
hulkout
Tuning
Sep 30, 2015 12:33 PM
Katie93
Sep 15, 2015 05:57 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
