MAF voltage vs. Air Flow rate data anyone?
Old Feb 19, 2008 | 02:19 AM
blknblk's Avatar
blknblk
Question MAF voltage vs. Air Flow rate data anyone?
The maf sensor signal varies from 0 to 5v and from what I read is exponential in relation to the actual Air Flow. Does anyone have specific information on the MAF Voltage vs. Air Flow relation?
I plan on logging data using my UTEC to ultimately calculate the VE vs. RPM.
Old Feb 21, 2008 | 11:59 PM
blknblk's Avatar
blknblk
Any ideas where I might be able to find this information?
Old Feb 22, 2008 | 06:49 AM
gothchick's Avatar
gothchick
I think most people go the MAP route if they're trying circumvent the MAF...
Old Feb 22, 2008 | 08:21 AM
BigD2k5's Avatar
BigD2k5
Supply voltage Battery voltage (11 - 14)V
Output voltage at idle 1.1 - 1.5*V
Mass air flow (Using CONSULT-II or GST) 2.0 - 6.0 g.m/sec at idle*
7.0 - 20.0 g.m/sec at 2,500 rpm*
*: Engine is warmed up to normal operating temperature and running under no-load.
Also use this as reference/conversion table. Hope that helps.
http://www.stealth316.com/2-air-fuel-flow.htm
Old Feb 22, 2008 | 08:35 AM
syndacit's Avatar
syndacit
A mass air flow sensor is basicly a thermal measuring device. It has a pin or heated grid that air flows over. The computer measures how much voltage is required to keep that grid at a certain temperature. More air flowing over the grid more current is generated.
Old Feb 24, 2008 | 06:33 AM
Q45tech's Avatar
Q45tech
Unfortunately the device creates an exponential [nonlinear] voltage vs flow curve.
The equation is roughly X raised to the 2.5-2.7 power. Which means you must accurately measure using a flow bench to define the offset constant.
Important to use oem duct fore and aft as standing waves [at different rpms] can create errors.
Someone must bite the bullet and pay for an accurate flow vs voltage test using at least 3-5 to average out the errors [accuracy may only be 3-5%]
http://www.geocities.com/tech4tdi/pages/maf.html
Old Feb 26, 2008 | 12:54 AM
blknblk's Avatar
blknblk
Thank you for the helpful information Q45tech.
Old Feb 26, 2008 | 06:46 AM
Q45tech's Avatar
Q45tech
At WOT the ecu uses a excessively rich A/F to protect cats from melting and to cool combustion chamber [to not overload cooling system and work with low quality premium US pump gasoline] so MAF voltage accuracy may be immaterial unless it is so inaccurate as to LEAN the A/F too much and melt things.
The WOT at HP peak may be 10.5 A/F so whether 10.0AF or 11.025 A/F [+-5%] isn't very important unless you are trying to squeeze out every HP at the expense of durability [cats, exhaust valve seals]
The important thing is to measure the air flow restriction.....[a Q45 MAF creates a 6"-7" WC [H2O] or <1/4 psi restriction at redline] I would expect the same or a little less on a 3.5 MAF
Old Feb 26, 2008 | 11:18 AM
rcdash's Avatar
rcdash
Originally Posted by Q45tech
At WOT the ecu uses a excessively rich A/F to protect cats from melting and...
I believe running rich causes catalytic converters to heat up actually. So while it does run rich at WOT, this has nothing to do with the cats...
To the OP: you may get the data you want by contacting the folks at UpRev (the developers of the Cipher).
Old Mar 2, 2008 | 04:24 PM
Q45tech's Avatar
Q45tech
Measure the EGT with varing A/F you'll see how cool it gets richer than 12:1.
The cats cannot convert anything without oxygen
Old Mar 3, 2008 | 01:15 PM
rcdash's Avatar
rcdash
Actually reduction of nitrogen oxides to nitrogen and oxygen will produce oxygen - and is one of the three reactions that occur in modern catalytic converters. The oxygen produced can be utilized for the other two reactions.
And again, pretty sure I don't need to test this as it's well established that running rich will heat up, and potentially destroy a converter. Here's a quick google link with reference and quote from http://www.catalyticconverter.org/care/index.htm:
If a converter is operated too long at a high temperature, its substrate may "melt down" and turn into a solid mass inside the converter. The vehicle may seem sluggish, as if there were a loss of power. Again, an engine and/or fuel system malfunction is allowing a rich fuel mixture to reach the converter. If the problem is not diagnosed and corrected, future converter failures may occur.
The exhaust gas temperature may decrease due to the cooling effects of excess fuel vapor, but this pre-cat temperature reduction is misleading, and the subsequent chemical reactions in the cat downstream may well destroy them from overheating...
Old May 29, 2008 | 10:59 AM
Subninja's Avatar
Subninja
Default Maf
So is it possible that running 12-14psi with a vortech will send to much voltage to the MAF and harm it?
Old May 29, 2008 | 02:51 PM
UpRev's Avatar
UpRev
Yes. We have new Modified Nissan MAF sensors to allow keeping stock ECU and wiring while supporting up to 600hp. Please contact us via e-mail. We should have pricing on Monday/Tuesday for this part.
Old May 29, 2008 | 03:54 PM
App6MT's Avatar
App6MT
What injectors are you guys using in with the greddy kit?
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
