up to 7200 rpm with unichip module?
Hello, can increase the rpm module unichip?
6600 at 7200 rpm
thanks.
my English bad, sorry
6600 at 7200 rpm
thanks.
I raise my rpm for short z with 3.9 and in group launched in 5 solo 220kh and 6, z very lento.con 7200rpm in 5 to get 240kh
my z has collectors, suppressors, ypipes, intermediate, Plenun, Light Weight Crank Pulley Polished, Box 2006 admission K & N filter with direct air intake, ngk iridium sparkplugs, unichip, omp seat, volk cn28n 18.
328cv a 6470rpm and 1420K.
thanks
thanks
Dastek have tried to increase the rpm of the 350Z 280 HP with Unichip and although you can do this action turns off the communication to the instrument panel when serving in the post at 6500 revolutions per minute (to go to 7000 revolutions per minute) thanks CAN bus system. The board only works again after turning off the contact and put it back not found a solution to that problem, sorry!
you have an answer to this?
thanks
thanks
thanks
thanks
As such it is not able to raise the rev limit.
However the Utec ecu (which can be purchased quite cheaply 2nd hand) is able to be programed to rase the rev limit.
(I am not sure if it can do it on all model Z's)
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
