R35 gtr maf be used for a 350z?
Old Sep 27, 2013 | 05:59 PM
350zjason350z's Avatar
350zjason350z
Know it all
Default R35 gtr maf be used for a 350z?
I'm wondering if the r35 maf can be used on a 350z for a turbo set up? instead of buying the hpx maf, a used gtr maf is much cheaper on ebay..
Old Sep 28, 2013 | 02:47 AM
T_K's Avatar
T_K
GT-R MAF isn't special. It's the same exact sensor that comes in all Nissan from ~2007.
Old Sep 28, 2013 | 01:44 PM
350zjason350z
Know it all
Oh.... Dang I guess I'll have to spend up I guess...
Old Sep 28, 2013 | 10:58 PM
Unbootable's Avatar
Unbootable
Is the 03-06 MAF different than the 07-08, Or are they all the same ?!!!
Old Sep 29, 2013 | 12:14 PM
T_K's Avatar
T_K
It officially has a different Hitachi part number, but the newer one might just be an updated version with the same specs.
Old Oct 20, 2013 | 05:51 AM
djamps's Avatar
djamps
gtr mafs need to run in pairs if you want any kind of increased flow. otherwise they flow similar to single maf stock setups.
Old Jan 1, 2014 | 07:43 AM
rcdash's Avatar
rcdash
djamps, do you know if anyone tried splicing a MAP and temp sensor into the MAF wiring and retuning using UpRev? Both 0-5 volt signals, so I think it could work - completely different sensor curve, but should still be able to be tuned.
Old Jan 3, 2014 | 06:17 AM
djamps's Avatar
djamps
Although we do have a temp sensor, the 'corrections' are mostly handled by the MAF's reading itself (e.g. cold air gives higher MAF readings). A MAP setup requires far stronger AIT based corrections...With no ability to adjust compensations in uprev I don't think it can work well if at all, assuming the electrical isn't a problem.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
