My clutch dampener is gone
Old Nov 11, 2007 | 04:19 PM
VitViper's Avatar
VitViper
Default My clutch dampener is gone
And good riddance! Also ran Motul RBF600 through the clutch line and my clutch actually feels like a clutch between shifts. No more annoying lag between redline shifts.
Old Nov 11, 2007 | 04:31 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Any pics?
Old Nov 11, 2007 | 04:38 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Some details on how you did it and pics would be great.
Old Nov 11, 2007 | 04:41 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Old Nov 11, 2007 | 04:47 PM
VitViper's Avatar
VitViper
Originally Posted by Jarred@Z1
Any pics?
Sure:
Dampener on the line:
Deleted:
Dampener itself:
The dampener is not a valve... it's a restrictor. The clutch line internal diameter is "X" size, but the dampener internal diameter is "Y" size (about 2/3 smaller than the clutch line). It's a 2-way restrictor: engagement and release. As you can see, we just put in a simple coupling where the dampener was (internal diameter on the coupling is slightly larger than the ID of the clutch line) and now I get full hydraulic pressure to the slave. Clutch definitely has a bit more kick to it, and no more annoying lag. Clutch doesn't seem to heat up really bad after hard redline runs through the gears.
Old Nov 11, 2007 | 04:48 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
Im assuming this is behind the driver side fender well? Also where did you get that connector?
Old Nov 11, 2007 | 04:51 PM
VitViper's Avatar
VitViper
Yes it's in the driver side fender well. I have a friend at a transmission shop that's got a friend at the Nissan dealership across the street. He mentioned that he had a Z guy with mods wanting to delete the clutch dampener and the Nissan tech knew exactly what he was talking about right away and supplied him with a few different fittings. We didn't get the exact thread match in the fitting, but as you can see it threaded onto the male connectors just fine (nice and tight) and no leaks (pic was after we bled the clutch line checking for leaks).
Old Nov 11, 2007 | 04:53 PM
VitViper's Avatar
VitViper
Oh yeah, top male connector was dried into the dampener... had to use vice grips to break it loose, the ****er was in there TIGHT :/
Old Nov 11, 2007 | 05:04 PM
Mike Wazowski's Avatar
Mike Wazowski
damn, we need sizes. maybe you should become an inventor and sell them on the boards?
Old Nov 11, 2007 | 07:12 PM
Gooey's Avatar
Gooey
thats exactly what my installer did to mine I believe hehad to thread the couplin himself
Old Nov 11, 2007 | 07:16 PM
Fingers's Avatar
Fingers
Could the dampner be drilled to a larger diameter, is there clearence in the side wall.
Old Nov 11, 2007 | 07:21 PM
diwun67's Avatar
diwun67
Sounds like a good idea
Old Nov 11, 2007 | 07:33 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
i have done the same thing on a 300zx and 240sx and its much easier i wonder why nissan put these in you really dont get that much more pedal pulsation without it installed.
Old Nov 11, 2007 | 07:47 PM
JasonZ-YA's Avatar
JasonZ-YA
anyone get the size for this?
threading etc,
-j
Old Nov 11, 2007 | 07:55 PM
VitViper's Avatar
VitViper
Bad idea, you'll destroy the flaring and it won't seal tight. The coupling we used had a flare to match the clutch line, just with a larger opening so it wouldn't restrict the flow like the dampener.
Old Nov 11, 2007 | 07:57 PM
VitViper's Avatar
VitViper
What pedal pulsation? I don't feel anything though the pedal -- in fact the pedal feels a lot better with the Motul fluid and dampener gone. Clutch definitely feels better now as well (mind you I have a new clutch/pp/flywheel from Nissan since they replaced my original leaking slave cylinder).
Old Nov 11, 2007 | 08:08 PM
warmmilk's Avatar
warmmilk
how much did they charge u for this?
Old Nov 11, 2007 | 08:26 PM
VitViper's Avatar
VitViper
$0
I made a new friend
Old Nov 11, 2007 | 08:32 PM
warmmilk's Avatar
warmmilk
can i be his friend too (thats sounds so wrong)
Old Nov 11, 2007 | 09:14 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Part numbers would be great on this!
