Dynoed!...07 AT Berk HFC/Nismo Exhaust/Nismo Intakes
Old Dec 18, 2007 | 07:09 PM
quidproquo's Avatar
quidproquo
Need a Tune!!!
Originally Posted by Frostydc4
On a dynojet? I thought the HR's dyno in the high 260's/ low 270's stock on a dynojet.
You are correct... Clipdin dynoed 254 on a dyno dynamics dyno.
Old Dec 18, 2007 | 07:26 PM
itsjiggajames's Avatar
itsjiggajames
AT dyno a little lower. These are corrected numbers.. uncorrected would have put him at 270s.
Old Dec 20, 2007 | 02:22 PM
rynzy's Avatar
rynzy
my gains were a lot higher than that. did my pulls in 3rd. i'll see if i can find the sheet. i tested with only greddy catback on. now i have the fujita duals. intresting. too many factors here though
Old Dec 21, 2007 | 01:59 AM
itsjiggajames
Did you have a baseline and than an after? Because if you didn't it doesn't really mean anything. One dyno versus another is like apples versus oranges...
Old Dec 22, 2007 | 10:11 PM
aloh's Avatar
aloh
does your brother have an auto or a manual?
Old Dec 23, 2007 | 08:29 AM
Justin07Z's Avatar
Justin07Z
Those are good numbers for a AT. I'd bet if that car was a manual, you'd have put a good 10rwhp more down.
Old Dec 25, 2007 | 09:58 PM
jgregory124's Avatar
jgregory124
Nice numbers I lets see what I get in the next couple of weeks..........
Old Jan 5, 2008 | 08:47 PM
nismology1's Avatar
nismology1
Originally Posted by quidproquo
As Chebosto and VitViper have stated before, Nissan has programmed the ECU to start closing the throttle bodies for the HR at 7000 (even at WOT) to keep the driver from wanting to exceed 7500... Technosquare has been able to bypass this throttle body programming, and their reflash will allow better use of the higher RPMs (hence the increase to 8000 redline).
Was this discovered by monitoring TPS voltages directly or through the data port?
Old Jan 10, 2008 | 04:57 PM
baspence's Avatar
baspence
x2 very interesting.... I didn't know that, I'm going to be getting a reflash from AAM in a month or so after they finish tweaking there tune. I'm sure they know and have thought of this, but I wonder if they didn't. they mentioned alot of stuff that the reflash did but didn't mention this.
apex locator
Jul 23, 2021 02:27 AM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
