Stillen Supercharger Question
I have an 07 Z. I was at my local nissan dealer getting the oil changed and the service manager comes over and talks to me about my z. He basically tells me that they are an authorized Stillen dealer and that i can put a Stillen Supercharger on my 07 z. He even tells me that they are made for the 03-06 but they can make "modifications" to fit the dual intake on the 07. My question is, is this possible? To fit a stillen supercharger(with "some modification) from an 03-06 on an 07-08 z?
edit: i read this thread before and couldnt find the answer
https://my350z.com/forum/vq35hr/3774...ercharger.html
Most likely, the service manager doesn't know what he's talking about. Call Stillen if you want to verify: http://www.stillen.com/page.asp?contactus
Anything is possible but its going to cost ya!
First the elbow on the rear of the blower would have to be modified for dual intakes, not too complicated b/c that piece simply bolts on to the blower and can be removed.
Then you would need some sort of engine management since the split second box comes pretuned for 03-06 engines only (unless Stillen tunes it for ya in shop.)
This is all assuming that the new lower plenum for the Stillen s/c bolts up in the same locations as the 03-06, not sure?
But the biggest problem I see is the lower accessory pulley (maybe called something else?), its the large one above the crank pulley on the 03-06, didn't they remove that on the 07's? Reason this is a problem is b/c with the Stillen kit that pulley gets replaced with a larger one that attaches another belt to it which travels upward and spins the blower.
If you can get around all that then sure do it but I think you should just go for a Nitrous or TT setup, you will end up spending just as much and make less power with the Stillen kit.
Originally Posted by Blk03G35
Get it in "Writing" that they can make it work and if they **** up make them pay for it. The STillen supercharger gives the VQ the much needed torque it needs
Roots blower = garbage.
Originally Posted by warmmilk
considering a bolt on + tune hr can make as much power as a stillen with all the bells and whistles, putting a stillen on an hr would be pretty useless
Point is the HR stock makes more power then the DE stock.
It would be different if you had said that bolt ons on an hr make more power then a Stillen s/c on an HR but considering no one has done it im guessing you have no clue on what your talking about.
He wants to add the Stillen s/c on an HR, it should make more power then with bolt ons if you can get around everything I mentioned above.
350Z_Al
Oct 29, 2020 07:44 PM
