Highest mileage HRs
Old Nov 2, 2008 | 07:11 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
07 NISMO 350Z
11k
1) Recall on Slave
2) Flywheel Chatter
Otherwise no issues.
Old Nov 2, 2008 | 07:58 AM
singh's Avatar
singh
_______________
07 6-speed Enthusiast (15,000 miles)
1) Even after recall work completed, clutch still gets stuck to floor (only when
launching very aggressively)
2) Uneven tire wear (straight from factory)
3) Passenger side window rolls down slower than driver side, and it sounds like
it's going to stop working any day now.
4) RPM tach needle bounces and lacks firmness.
5) I also got the slight stuttering when I floored the car once, but it only
happened once. I would say it's due to the aftermarket cats.
Old Nov 2, 2008 | 09:47 AM
stylett9's Avatar
stylett9
07 with 35700 miles.
have had the stuttering issue since 20k and can already tell my windows are starting to slow down. Oh and every once in awhile my tach will freeze for a few minutes. Good luck getting these fixed before warrenty is up right?lol
Old Nov 2, 2008 | 11:39 AM
A.H's Avatar
A.H
07 Touring 5AT with 16K
No problems from the factory to date
Old Nov 2, 2008 | 01:26 PM
SlowCoupe's Avatar
SlowCoupe
bring it in asap so they would have it on file just in case is malfunctions after the warranty period ends. sometimes the dealer "goodwill" the bill.
Old Nov 2, 2008 | 01:31 PM
JZK's Avatar
JZK
Old Nov 2, 2008 | 01:33 PM
JZK's Avatar
JZK
08 enthusiast 6mt 11,200 miles
1. Driver side window motor retarded, when using automatic - it rolls all the way up then comes back down and stops halfway.
2. Loud pushout bearing & flywheel chatter.
*For all of you with the vibration/ stutter noises coming from your car; There is a bracket that is held with 4 bolts that connects from your test pipes/cats to the bottm of your tranny. 2 bolts into the tranny, 2 bolts supporting your test pipes. Make sure all the 4 bolts are tightened very well, the bracket will make noises when it vibrates against the bottom of the tranny because of all the vibrations from your test pipes/ high flow cats. Mine started making stuttering noises; I tightened the 4 bolts and the problem was solved. It's very easy to fix, just jack up your car and tighten the bolts.
Old Nov 2, 2008 | 03:19 PM
itsjiggajames's Avatar
itsjiggajames
the flywheel chatter you guys complain about is normal.. every Z i've had been in chatters when the clutch isn't fully depressed.. nothing to worry about, and hardly a problem. Annoying? Yes...
Overall I feel is the HRs are reliable. No major problems what not...
for the people that feel the stuttering after HFC, it IS the HFCs.. been in 3 different HRs, before and after and ALL of them will sort of stutter around 2-3rpms.. (after HFCs are installed, no stuttering prior to install) i'm guessing the ECU doesn't really familiarize itself with the A/F ratio changes from the HFCs.. but after a while it isn't as bad.
This isn't the same stuttering as people like Stylett has, the stuttering he explains is way different..
Ghsing, im surprised you still have the early model year uneven tirewear.. have you brought it in? My car wore perfectly even dropped on GF210s for 22k miles.. (day I bought my car I drove directly to install my springs)
Stylett I feel you on getting all the nooks and crannies fixed before 3 year 36k.. i'm planning on going in at 35,999 miles to get my tach replaced because i'm such a procrastinator. I'll probably go to Tim at performance (service center) because he's the only one that takes me seriously and listens to me.. never had a bad experience from him. Great guy too.. highly recommend him. I feel bad that you never got your **** handled..
Old Nov 2, 2008 | 03:25 PM
JZK's Avatar
JZK
Hm, the stuttering im talking about is something vibrating, like something under the car was loose and rattling, I heard it when i went full throttle or slowing down in gear from 4k-2k rpms. It was the bracket for me. It started happening after i installed my test pipes, my problem was that either the bolts got loose or i didnt tighten them enough. Anyways, that's my story, it went away after
Old Nov 2, 2008 | 03:28 PM
itsjiggajames
Well at least it isn't related to nissan.
Old Nov 2, 2008 | 04:12 PM
Sensi09's Avatar
Sensi09
Works Concepts
Got my '07 in January 2008.
Have ~19,000 miles. Have started to get intermittent 5th gear grind and sometimes grinding into 2nd. Also shift linkage does not feel very smooth while in neutral. Have not yet done the slave cylinder recall.
Exhaust has some type of metallic sounding vibration on cold-startup. Goes away when warm. Just had an oil change and asked them to check for anything loose, but nothing was found.
Old Nov 2, 2008 | 05:58 PM
07JimmyZ's Avatar
07JimmyZ
07 in may
23-24 miles
slave recall- clutch still sticks 3 or 4 times
tach got stuck 3 times to date
5th gear grind when cold-the only problem that really bothers me
Old Nov 2, 2008 | 07:03 PM
FastZ33's Avatar
FastZ33
08 14k miles, nothing wrong ......well jus a bog at 3k coz of test pipes haha
Old Nov 2, 2008 | 09:06 PM
trinityracer's Avatar
trinityracer
08 Base 1011 miles
Needs to not be stock!!
Old Nov 2, 2008 | 09:41 PM
itsjiggajames
Originally Posted by trinityracer
08 Base 1011 miles
You sir cannot read. Why that's such high mileage for a HR.
So I guess highest mileage HR is 35.7k? damn.
Old Nov 3, 2008 | 04:54 AM
baspence's Avatar
baspence
26k on mine.
had recall on slave at 23k
about to have the air bag recall completed
no real complaints yet besides it's not fast enough
OH and stock tires suck!
Old Nov 3, 2008 | 06:17 AM
shadykilla717's Avatar
shadykilla717
Originally Posted by 08black350
11k on my 08... Driver window motor went out. noisy throwout bearing. 5th gear grinds when cold.
The throwout bearing is verrrry loud. ANd my motor sumtimes dsnt go up and down. I gotta push it a few times.. It's annoying. but w.e..
Old Nov 3, 2008 | 06:43 AM
  #38
BenchTT's Avatar
BenchTT
Originally Posted by 350Zimo
I have a starter problem but it still hasn't been fixed because the dealership has to replicate the problem. It does it once a blue moon. Well anyway I have a year and a half left of My warranty
I have that too, I thought it was the JWT flywheel I put in though. Happens once a month or so.
Only problem is the ALWAYS present sound of a dumptruck from 1-2k rpms.
Old Nov 3, 2008 | 07:09 AM
  #39
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Grind, high rpms 2nd gear. I thought it was me, but guess it might be a issue with the car. Hmm.
Old Nov 3, 2008 | 07:39 AM
  #40
Mansmind's Avatar
Mansmind
38k here on an 07. I've had the slave recall done with no clutch problems since (I was one of the first to have the problem). I still get the "stuttering" issue when the car is warming up but it hasn't gotten better or worse.
Other than that.. no problems.
