Highest mileage HRs
Old Nov 10, 2008 | 07:41 AM
  #61
NISMO355's Avatar
NISMO355
07 with 22,000 miles
Passanger airbag sensor replaced.
Old Nov 10, 2008 | 05:18 PM
  #62
The Almighty JB's Avatar
The Almighty JB
Default 07HR
32,507 miles on my HR. I got it March 25, 2007.
Probs:
Random vibrating creeking sound occuring once a in a while on the driver side dashboard. I just hit it a few times and it goes away.
5th gear grinds a lil with a quick shift
studder between 2-3k.
window makes a sticking sound sometimes.
rear passenger side hatch spring just fell out yesterday...
slight chas flex prolly from me getting sideways in my car tho
Old Nov 19, 2008 | 10:47 AM
  #63
powermark's Avatar
powermark
44000 on mine now.
Old Nov 19, 2008 | 11:03 AM
  #64
warmmilk's Avatar
warmmilk
2007 with 28k
1. tranny replaced, 6th gear synchro when out
2. window motor replaced, auto up feature was malfunctioning
3. repeat of #1
4. window motor controller reprogrammed and window adjusted, auto up feature was malfuctioning
then the slave recall was somewhere in there also, but it didn't make much difference
Old Nov 19, 2008 | 02:16 PM
  #65
shocka04's Avatar
shocka04
2007 with 23k
Only problem has been the slave recall
Old Nov 19, 2008 | 06:44 PM
  #66
wilsons780's Avatar
wilsons780
08 nismo (#687) 36000 miles
no real problems
just when pullng to a parking space with light breaking i get a really bad brake chadder from right rear break.
and of corse the noisey tranny but that doesn't bother me (because the noise is from the gear designe i'd rather have it strong and somewhat noisey than weak and quite)
Old Nov 19, 2008 | 08:09 PM
  #67
robertinmesa's Avatar
robertinmesa
2007 GT
slave cylinder recall
window sometimes stalls(wonders if grounding kit will fix)
dropped the clutch the other day around 1500-2000rpm and did not go...than i shifted and the problem persisted. After 30mins the burning clutch smell went away. this problem has not returned since, but i am now concerned for the first time about buying this car.
Old Nov 19, 2008 | 08:10 PM
  #68
mikez97's Avatar
mikez97
07 14k
its been in the shop forever
Old Nov 19, 2008 | 11:34 PM
  #69
JZK's Avatar
JZK
My car's been acting up..
1. Weird idling problem. Idle was radiating from about 900-1200 rpms up and down. I reset the ECU and it stays at normal rpm's now (600rpms or so) But now every couple seconds when Im at a stop in neutral, it sounds as if the car is about to stall, the rpm will drop too low and then go back up to normal and then repeat itself, f*cking weird I tell ya'.
2. This problem started happening tonight: Engine makes a loud clanking noise right when I start up the engine. Like something is hitting something. It's only when I start the engine and it does it only once right when the engine is turning on. I turned on and off my engine a crap load of times, but that didnt fix anything. lol My friend says it's my starter, but if its my starter, how come it started doing it recently? But it did start happening recently after I got my flywheel & clutch installed. I'm going to go back and have them look at it, hopefully they installed something wrong.
Here's a vid.
Listen carefully since its recorded with a crappy camera phone.. You can hear the loud click noise right before the engine gets gas
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/BK5mcdcNtQA&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/BK5mcdcNtQA&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Nov 20, 2008 | 10:02 AM
  #70
singh's Avatar
singh
_______________
Your car has many mods. Nothing surprising about your malfunctions..
Old Nov 20, 2008 | 11:28 AM
  #71
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I am sure its one of the mods making that clunk.
Old Nov 20, 2008 | 11:41 AM
  #72
warmmilk's Avatar
warmmilk
Originally Posted by mikez97
07 14k
nobody feels sorry for you, its tt'd
Old Nov 20, 2008 | 03:25 PM
  #73
JZK's Avatar
JZK
Kay, the idling I mentioned before has been fixed. We messed with the fuel/ignition timing at idle and it's normal now.
As for the loud click, the clutch and flywheel is fine. Supposedly its the starter disengaging, I'll just ignore it for now. If it gets worse then I'll look into it again..
Everything else is good!
Old Dec 3, 2008 | 08:41 AM
  #74
mr.elite's Avatar
mr.elite
Man~ all these problems. Im starting to get worried.
Old Dec 3, 2008 | 08:45 AM
  #75
Squeaky350's Avatar
Squeaky350
07 with 16k
Only issue is fuel door won't open half the time.
Old Dec 3, 2008 | 08:51 AM
  #76
KS0385's Avatar
KS0385
I'm not. Just compare these to the problems BMW and Mercedes have with their "low performance" cars.
Old Dec 3, 2008 | 10:37 AM
  #77
JR350z08's Avatar
JR350z08
Got my 08 last dec, im at 22k. Front Tires patching, Clutch getting stuck. Front rotors vibrating, airbag recall. thats it so far. Dealing with nissan now abut my clutch isusse
New parts:
Bfgoodrich Kdw's 245/40F 275/35R
New Front Rotors
Airbag Checked
Old Dec 3, 2008 | 06:57 PM
  #78
donkinuts's Avatar
donkinuts
New parts:
New Front Rotors
Airbag Checked
When you say "front tire patching"; are you referring it to the tire feathering issue that supposedly was fix in the earlier models? I also have an '08, which sits in the garage mostly. Hearing these issues on the 07+ model year, makes me worried.
Old Dec 4, 2008 | 07:17 AM
  #79
JR350z08's Avatar
JR350z08
Yes have nissan check it out for you...i had a big depute with a service writer, and parts manger. Nissan will replace tires and alinement under warranty up to 12,000 miles or within the first year which ever comes first......
So an update I go to other Nissan dealership Reen Nissan here in Orlando, FL. So they get my baby in the air to check the clutch and see why it;s getting stuck, With in an hour they come saying im getting a new tranny clutch and fly wheel. dont have the full details on the tranny yet. they'll let me know when they do the swap.
Old Dec 4, 2008 | 07:46 AM
  #80
GHOST1207's Avatar
GHOST1207
Originally Posted by The Almighty JB
Probs:
08 Touring with 2350 miles, I have these problems too, except the vribrating noise is coming from the passenger side dash and the window squeak is on the driver side.
