Highest mileage HRs
Old Nov 3, 2008 | 07:45 AM
  #41
Calvin@CRG's Avatar
Calvin@CRG
Temporary Disablement - Billing
07 HR @ 11.2k miles.
Only problem was the slave cylinder recall.
I know it isnt a high mileage HR or anything but yea just wanted to chime in. I had my slave recalled at around 5-6k miles I believe?
Old Nov 3, 2008 | 08:25 AM
  #42
Darg2er's Avatar
Darg2er
07 HR @ 19K miles
broken MAF on left intake (stock)
broken MAF on stock cat
Old Nov 3, 2008 | 04:52 PM
  #43
whoopazz1's Avatar
whoopazz1
07 with 21K miles,
Slave cylinder replaced,
tranny notchy when cold... doesn't bug me yet...
I think I'm gettin tire feathering at the front... they are starting to growl under breaking...
Old Nov 3, 2008 | 07:36 PM
  #44
hiz-n-herz's Avatar
hiz-n-herz
07 z with 19k miles. No major issues at all.
The - - - Z - - - Panel on the rear strut tower brace vibrates on rough pavement. I need to take it apart and put some sticky foam or something on it.
I had some creaking when turning the wheel in a parking lot. Turned out to be the front cross-member underneath needed to be torqued down.
Overall, I am very impressed. The list of issues on my previous 06 was pretty long.
One think I hate about the current gen Z's is the brake-pad knock-back that you get if you take some corners at high g-force. When you get back on the brakes after a hard corner, the engagement point is much lower until you pump it once. That's just sad. My 06 GT did it and my 07 GT does it too.
Old Nov 4, 2008 | 02:15 AM
  #45
JZK's Avatar
JZK
Oh. I also forgot to mention that my rotors are warped like ****, while slowing down from a high rate of speed, feels like a roller coaster, but that's my fault of course D:
Old Nov 4, 2008 | 04:27 AM
  #46
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I race my car and have no issues with my rotors even with them getting red hot at the track. Make sure your lugs are torqued properly and in a star method.
Old Nov 4, 2008 | 08:47 AM
  #47
singh's Avatar
singh
_______________
Originally Posted by Darg2er
07 HR @ 19K miles
wat
Old Nov 4, 2008 | 11:26 AM
  #48
Zrealsoon's Avatar
Zrealsoon
08, 11,000 miles.
No broken things... just nice chips on the bumper from rocks etc.
I do notice the drivers door handle has some chips in the rubber paint.. sort of like a dude on here... but not nearly as bad.
HOWEVER: I haven't seen a thread about this... but dunno what the hell is up:
Sometimes When I am in ANY gear or even Neutral... and I slow for a stop with a moderate turn of the wheel... like parking in my garage, I press the breaks and the car seems to stutter.. almost like the ABS is activated... only happens when I am going <10MPH. Does not happen all the time. Makes a farting noise or something...
I am still as in love with this car as I was when I wanted it 5 years ago. :-)
Old Nov 5, 2008 | 06:16 AM
  #49
6894kevin's Avatar
6894kevin
07= 23K
1-slave recall
2-Streaks on both windows (not a big deal)
3-Shutter after hard start with the aftermarket intaks!
4- PAINT CHIPS ON FRONT SUCK (Big issue to me)
Old Nov 5, 2008 | 07:21 AM
  #50
trodis's Avatar
trodis
19k on mine - nothing major.
Rocker panel driver side sort of pulling away.
All other creaks and sounds are coming from aftermarket parts.
Old Nov 5, 2008 | 11:56 AM
  #51
zettahertz's Avatar
zettahertz
22K miles
1. Slave cylinder recall at 16K
2. Rear axle click (or some kinda clicking sound) when turning left at slow speed. Going to take it to dealer to fix this soon.
3. Window makes a tapping noise when they're down and going through bumps. Anyone else got this?
Old Nov 5, 2008 | 12:24 PM
  #52
solo_element's Avatar
solo_element
19k bought in Nov last year one ann is coming up
nothing major so far
what up james how you been bruh?! you and your bro still in SD for skool
Old Nov 8, 2008 | 09:12 AM
  #53
JZK's Avatar
JZK
My car has been acting up recently, it has very abnormal idling. I'm not talking about a cold start either, when the engine is warm and im in neutral, the idle will bounce up and down from 900rpm - 1200rpms, then it'll stop for a while and settle at about 1000rpm, then it'll go crazy again and start bouncing up and down, can't figure out what it is. I tried reinstalling my intakes, that didn't work
Old Nov 8, 2008 | 08:24 PM
  #54
singh's Avatar
singh
_______________
The stuttering problems are coming from your intakes buddy. My brother's car also did the same thing as you described..
I know because my brother also had AEM intakes on his RX8 and his car would stutter violently at stoplights when idle. It became so annoying that he literally took them out and threw them in the garbage. He put the OEM intakes back in and the stuttering stopped..
Sure they may sound cool, but I will never put aftermarket intakes on my car..
Old Nov 8, 2008 | 10:30 PM
  #55
JZK's Avatar
JZK
Kay I just cleaned my MAF sensors and both my intake filters, just gotta wait for them to dry and see if the problem stops.
Old Nov 8, 2008 | 10:35 PM
  #56
vnarang's Avatar
vnarang
My window went out too, and so did the endlink on my sway bar.
YAY for warranty! freaking stealerships
Old Nov 9, 2008 | 11:00 AM
  #57
carlili4190's Avatar
carlili4190
07 with 7200 miles
no problems yet..
Old Nov 9, 2008 | 12:17 PM
  #58
Peak350's Avatar
Peak350
07 with 18k. New window regulator, tranny, clutch, flywheel, and slave cylinder. Clutch/flywheel were my fault, rest were car issues. Tranny chunked a synchro shortly after I got the car and it felt bad new.
Old Nov 9, 2008 | 03:16 PM
  #59
T-dizee's Avatar
T-dizee
check your MAF's, and the vaccum lines from the intake to the intake manifold or just around that area. all it takes is one little hose that came off from just messing around the intake manifold area. im not sure if there is any kind of idle air control valve on the HR's or not. but thats usually what that kind of thing is.
Old Nov 10, 2008 | 07:36 AM
  #60
Z33_kid's Avatar
Z33_kid
07 with 9k not problems yet
