hr test pipe non fouler fix
Old Jul 17, 2009 | 02:42 PM
  #121
0jiggy0's Avatar
0jiggy0
Originally Posted by NY350zG
When the light is on the car begins to run richer from the low threshold code.. It's odd but for some reason the car burns more fuel.
And JIGGY! When I do eventually meet you.. Im gonna hurt you, hahaha. I had originally thought that maybe the stock gaskets were broken or worn.. So relaxxxxxxx, Looks liek im going to an auto parts store and getting a diffrent kind of gasket. I also want to put some copper silicone gasket sealer on them F^&kers.
It was early in the morning and I was cranky.
Get the ones that are like a grey composite material around a metal ring. 1 side has a hole the other side has a slot. Match it up and tighten it down. You wont need copper spray because the stuff kind of crushes when you tighten down. Ive taken my exhaust off like 3 times when redoing my wannabe TDX exhaust, and they still hold up.
Old Jul 17, 2009 | 02:45 PM
  #122
0jiggy0's Avatar
0jiggy0
Originally Posted by anyjuan
^ LOL damn OjiggyO!! Easy on the coffee.
Mind giving me some advice? Is my "hrisstle" from the gaskets then? I didn't get gaskets from turboxs so the shop used the stock ones somehow. Please help, my car sounds awesome when its not making that rattling noise aka *hristtle.
*copyright anyjuan 2009
Its the gaskets, see above. You will probly still get a bit of *hristtle* because thats rasp, but a lot should go away.
Old Aug 2, 2009 | 01:53 PM
  #123
IsDatIt's Avatar
IsDatIt
WOW, you guys are still getting SES lights?
just buy some god D*** Brillo pad for $1.19 rinse the soap out ,and stuff that Motha in there. ive had HFC's and now Resonated TP's with no lights for alot of miles,......
and FYI i get no Hesatation or misfires and my car is not eben tuned yet.
Old Aug 6, 2009 | 09:33 PM
  #124
kramykram's Avatar
kramykram
lol some people just won't listen. i was going to sell my car but since i have decided to keep it. im going to try and go ahead and make the peice i was planning on to give it a try.
Old Aug 6, 2009 | 09:56 PM
  #125
IsDatIt's Avatar
IsDatIt
Thanx for all your help KramyKram...if it wasnt for you i would have never figured it out!!
Old Sep 14, 2009 | 02:25 PM
  #126
BigMo350z's Avatar
BigMo350z
http://www.scangauge.com/
I never got around the check engine even with extended 02 bung done at One Six in the past.. So I started becoming careless of it... My friend gave me a scan gauge. It only works for about 60-100 miles before the cel comes on again. It only takes like 30 seconds to clear out. LOL I used it right before my nissan oil change they did a 100 pt inspection lol and said everything was perfect :-).
Old Sep 14, 2009 | 02:27 PM
  #127
Hexxus's Avatar
Hexxus
I doubt they really did.
Old Sep 14, 2009 | 02:39 PM
  #128
BigMo350z's Avatar
BigMo350z
I know.. just like emission testing..lol
Old Sep 14, 2009 | 10:17 PM
  #129
jace350z's Avatar
jace350z
The non fouler fix works for me. 07 HR Z No brillo pad in mine.
Old Sep 15, 2009 | 08:43 AM
  #130
fabcas311's Avatar
fabcas311
where did you get it?
Old Sep 15, 2009 | 10:04 PM
  #131
jace350z's Avatar
jace350z
I made it. From checkers part number 42009. I don't have the link but its out there, 350ztech I think. 4 non foulers drill out 2 half inch and screw them together. Let you know drilling them out so 02 will fit is a pita.
Old Oct 2, 2009 | 04:31 PM
  #132
Persians07350's Avatar
Persians07350
So can you feel a notice with the install of test pipes on an HR? and what do they sound like with stock exhaust?
Old Oct 3, 2009 | 02:18 AM
  #133
kramykram's Avatar
kramykram
hell no lol they will cause rasp galore. but you will definatly notice the difference. i would suggest going high flow cats if you want to keep rasp down.
Old Oct 3, 2009 | 06:12 AM
  #134
fabcas311's Avatar
fabcas311
i have the turbo xs tp........installed an 02 simulator from z1 and stuffed with ss wool...........200+ miles no cel!
Old Oct 4, 2009 | 11:09 AM
  #135
jace350z's Avatar
jace350z
Yeah I noticed a difference, I lost 12.8 pounds of torque and lost 11 hp with my testpipe install. This was with a dual exhaust that was to restrictive. Retuning today with new better dual exhaust.
Old Oct 4, 2009 | 06:20 PM
  #136
kramykram's Avatar
kramykram
wow which dual exhaust was that?
Old Oct 4, 2009 | 09:01 PM
  #137
fabcas311's Avatar
fabcas311
+1
coz mine on a butt dyno gained alot with hks exhaust!
Old Oct 5, 2009 | 12:55 AM
  #138
jace350z's Avatar
jace350z
It was a local shop that made it. Come to find out it was 2.5 before X pipe, then they reduced it to 2.25 with crush bent bends. No good
Old Oct 6, 2009 | 01:29 AM
  #139
kramykram's Avatar
kramykram
Wow yeah I would just purcahse a premade one.
that exhaust shop = fail
Uriyo_
Sep 8, 2021 08:46 AM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
