Tomei Camshaft FOR VQ35HR
Old Feb 10, 2009 | 04:53 PM
  #41
Crom's Avatar
Crom
Originally Posted by Z1 Performance
a built HR is not going to really perform significantly differently from a build DE - the difference is the HR is the stronger platform to start with (albeit, far more limited range of parts available)
also to the OP, I would skip the F Con and look for something that lets you manipulate cam timing if you are going to go for 272's +
Valcon ?....
Old Feb 10, 2009 | 04:58 PM
  #42
0jiggy0's Avatar
0jiggy0
Those GTM specs are pretty extreme. Does anyone have experience with them?
Or know anyone that has them?
Old Feb 10, 2009 | 07:28 PM
  #43
folgrz's Avatar
folgrz
if you were to do an n/a build i would stick with the 272's get some nice pistons some nice rods, gears, reflash, and then all the basic bolt on's I wouldnt be surprised if someone broke 350whp n/a on an hr
Old Feb 11, 2009 | 04:48 AM
  #44
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by Crom
Valcon ?....
Valcon is not sold in the US, so really isn't a viable option IMHO - it also requires ( think) that you use HKS's own cams - making the total package price very expensive, and really an unknown quantity (I don't even know if the software platform is in English)
Old Feb 11, 2009 | 05:07 AM
  #45
supra crazy's Avatar
supra crazy
Would osiris control cam timing? and what is your take on GTM cams? would there be much power differance in the stage 2 vs stage 3 or would it only bring the powerband forther into the higher RPM range? Im planning on raising the revlimiter to 8200-8500
Old Feb 11, 2009 | 05:10 AM
  #46
Z1 Performance
Former Sponsor
First, this is about an HR, not a DE
I have no take on GTM cams - we don't offer their products
You would have to ask UpRev about the features of their product - again, not something we offer
Old Feb 12, 2009 | 06:00 AM
  #47
shadykilla717's Avatar
shadykilla717
Can't argue with that now huh chris lol. I was always thinking about doing a setup like that. But why not add a 4.08 fd to the mix..
Old Feb 12, 2009 | 03:40 PM
  #48
0jiggy0's Avatar
0jiggy0
Pretty sure he meant that when he said gears.
Old Feb 12, 2009 | 05:17 PM
  #49
rtiid22's Avatar
rtiid22
Originally Posted by GooDy151
I actually have AAM test pipe I'm not sure what size but it should be 2.5"
then stock Y-pipe. Then Remus straight pipe(shold be 2.5" or bigger. It look huge). Then the Rumus muffler.
I was told by a lot of friends that I should get Y-pipe to complete the job.
To be hornets I don't really feel my car different in any mod I did.
I can tell it's louder and I got bogging during 2k-3k after I install test pipe but I don't really feel my car pick up better.
So it comes to question about Y-pipe. Is it worth $300 to try ?
Put HFC on my car once I already had a cat-back exhaust and I felt the difference!.. I think what happened with your setup is that you just moved the bottle neck a little further down the exhaust and that might be causing your bogging? Get a Y-pipe!
Old Feb 13, 2009 | 09:47 AM
  #50
folgrz's Avatar
folgrz
you sir...... win teh prize
Old Feb 13, 2009 | 10:09 AM
  #51
GooDy151's Avatar
GooDy151
I'm interesting to know what would you offer for HR?
If I wanna build good N/A. I'm not talking about Big-bore kit or anything llike we have to take the motor out of the car tho.
What would you say to pull out the best HR for middle class people.
Old Feb 13, 2009 | 10:35 AM
  #52
shadykilla717
my bad i didnt even see that lol
Old Jul 6, 2009 | 12:21 PM
  #53
Swimminggerman's Avatar
Swimminggerman
Originally Posted by supra crazy
Where did you come up with this number? I too am looking into getting Cam's for a NA setup I was thinking about GTM Stage3
Stage 3:
302/292 degrees @ .012”
256/250 degrees @ .050”
11.50mm/11.00mm Valve lift (intake/exhaust)
I could care less about a rough idle
Plus at a stop light people think hmmm, there's something happening in there that sounds fun
Old Jul 6, 2009 | 06:50 PM
  #54
biggersNISMO's Avatar
biggersNISMO
^^^^I would be satisfied with the 272's....
Old Jul 7, 2009 | 11:05 AM
  #55
JK_HRZ's Avatar
JK_HRZ
I'm going to be a test pig for the tomei 272/10.8 (in & ex) cam's. I plan on purchasing the 11.0mm lift tomei valve springs as well. As for proper ecu tuning, I have a Greddy E-manage ultimate hardwired into the factory ECU. It can control fuel and advance/retard timing as well (Works awesome with my 125 shot, so I'm positive it'll work fine with these cams). However it does not control VTC.
Z1 stated that the highest lift the HR pistons could take was 11.0mm; So I'm pretty positive the rest of the internal's should be fine. The lift difference is only going from 10.5mm(oem) to 10.8mm(tomei). I have all the breathing mods to compensate for the extra breathing that my HR will be doing (intake, full exhaust; no cats)
However, Im currently saving up and awaiting a couple of paychecks. I'll definately keep everyone updated whoever's interested. I'm about halfway there.
Old Jul 7, 2009 | 11:09 AM
  #56
Z1 Performance
Former Sponsor
if you have no control over VTC, and have no headwork planned, you're better off going with the 264's
Old Jul 7, 2009 | 11:19 AM
  #57
JK_HRZ's Avatar
JK_HRZ
The only headwork I plan on getting done would be the higher lift valve springs compensating for the higher lift.
Could you go into detail as to what other kind of headwork should be done and why? The only lift difference is .3mm
Old Jul 7, 2009 | 11:22 AM
  #58
Z1 Performance
Former Sponsor
it would end up being a dissertation which would take far too long to write
you're best bet is researching online and speaking to a machinist about how cams work - it's far more than "just"a lift difference
the worst thing you can do is pick cams because they sound cool on paper - get the right ones for the job, and they reward you. Get the wrong ones, and they are paperweights
Old Jul 7, 2009 | 02:05 PM
  #59
Ataru074's Avatar
Ataru074
but you have to admit that isn't easy to find out what works and what doesn't.
not so many people have done that kind of job and actually even tested the reliability of the system (that is quite critical if you track the car).
because one thing is 3 or 4 dyno pull with the engine temperature stable... one thing is driving the **** out of the car on a road course starting with the engine mildly warm and ending up really hot, with all the associated changes in a/f, air density, timing adjustment to avoid knock and so on...
I agree that on a stock engine is pointless going with extreme cams or pure "competition cams" unless they are ground just to run on a stock block, with stock pistons and stock heads...
bottom line or you get the right information before starting the work.. or you'll spend way more money than buying immediately a newer and more powerful car.
you cannot beat the factory or the factory official racing team (if there is a class involving that car and that engine)
Old Jul 7, 2009 | 02:58 PM
  #60
JK_HRZ's Avatar
JK_HRZ
Anyone know if the 11.0mm tomei valve springs will work with the oem valves?
Just talked to my engine builder and he said if the springs are too stiff, the valves could break.
