Tomei Camshaft FOR VQ35HR
Old Apr 14, 2010 | 06:07 PM
  #101
GAMERMODZoCOM's Avatar
GAMERMODZoCOM
I have to order a set of the Tomei Cams for our VQ35HR build which should be done in a few weeks. This is a complete HR build from the ground up for our Redline Time Attack car. I will try and remember to come back here and update everyone about the cams.
Old Apr 14, 2010 | 07:35 PM
  #102
biggersNISMO's Avatar
biggersNISMO
Specs?
Old Apr 16, 2010 | 02:26 PM
  #103
GAMERMODZoCOM
Originally Posted by biggersNISMO
Specs?
Specs on what? The build or the cams?
Spoke with Tomei today to verify their cams will work with our Ferrea oversized valve train. They said they will be find however we will verify the lift. We will probably go with the 272's to be safe.
Old Apr 16, 2010 | 09:42 PM
  #104
biggersNISMO
Cams...
Old Apr 17, 2010 | 05:45 AM
  #105
Lakeside's Avatar
Lakeside
Exactly what is the goal for this build
A fully built HR with custom intake manifold and twin turbo's to do what?! To drive around with a Wrap to promote your company Something here just doesn't add up or look right.... Is this going to be for drifting? Track?
What drivetrain upgrades do you plan to make to support this kind of build?
Axles?
Diff?
Which clutch?
Add some Bing! Where's all the ARC goodies?! At least install their diff cooler lol
Good luck man! You obviously have no set budget More power to you. I would have just bought the GTR and modded that platform.
Old Apr 17, 2010 | 06:48 AM
  #106
nismomike's Avatar
nismomike
^ +1. I was thinking the same.
Old Apr 17, 2010 | 07:25 AM
  #107
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
It's a Time Attack car being built. While a GTR is certainly more than capable (as are several other platforms), it brings it's own level of complexity to the mix. In this case, I know the owners of the car looked to build what they had already, and with the people involved, it should turn out quite well.
Old Apr 17, 2010 | 09:59 AM
  #108
GAMERMODZoCOM
Adam, you are the man! lol
Honestly guys, I have purchased so much stuff from Adam and he is been a pleasure to work with. I HIGHLY recommend purchasing from Z1. If I can't get something from S&R Performance in Tampa, the only place I will ever go next is Z1.
If you all really want the list, here it is.
This is for the Redline Time Attack Series and NASA TT's. It is an 2008 NISMO 350Z and sponsored by S&R Performance and Greddy. It is also an "event" car for the company to take to things like MLG (Major League Gaming). Yes, there really hasn't been a budget however, without the sponsors, I am not sure this would have happened to the degree we have taken it. They have put a lot of faith in the car, and my capabilities on the track. The premise behind this was also that it's a NISMO on the track, not just any 350Z.
The GTR is capable and is an option for our 2nd car. I asked Sharif how much body roll he gets from the GTR on the track and his response was "None, it is that best handling car I have ever driven". So, in a nut shell, we are highly concidering the GTR as our next car because of all the input about the car from Sharif, the fact that is is AWD (completely differenct animal), and the power output it's capable of. I also would love to race both since they are so different.
Here is a list of everything on the car or waiting to be installed on the car. The only things in this list that we don't physically have are the rods, pistons, crank and Tomei CAMS (which we are still undecided if we really even need the cams).The pistons,rods and crank were supposed to ship last week but we have not verified if it has. That is all we are waiting on to start assembling it.
Motor:
VQ35HR Stroked to 4.2L
Greddy Twin Turbos (Two 20G Turbos) Ported & Polished
Arias Pistons
Brian Crower Rods
Brian Crower Billet Crank
Ferrea 2mm over sized competition valves, springs and titanium retainers
Ported, Polished and Reflowed Heads (Flowed 37% more than stock!)
Engine completely balanced and blueprinted
Tomei Cams (verifying valve clearance so they are unordered right now)
Block sleeved by Darton
Custom Designed 6061 T6 Aluminum Twin Throttlebody Plenum
All components have been Cryogenically treated in an SubZero Cryo unit
Injector Manufacture to be determined
Exaust:
Ported and Polished Headers
Ceramic Coated Headers and Exaust System
Straight Exaust Dump off with electronic valves for routing through the Greddy Ti-C exaust system while on public streets.
Suspension:
Tein SRC Dual Dampening Coilovers with External Resevoirs
2 Tein Electronic Dampening Force Controller (EDFC) Units cockpit mounted
Tein 16kg Springs Front and Rear
Tein Tie Rods
GTSpec 2 Point Rear Lower Brace
GTSpec Front 4 Point Ladder Brace
GTSpec Front Lower Tie Brace
GTSpec Rear Lower Tie Brace
GTSpec Rear Lateral Arm Brace
GTSpec Fender Braces
Hotchkis Adjustable Sway Bars
PowerGrid Swaybar Endlinks
SPL Adjustable A-Arms
SPL Adjustable Rear Toe Arm
SPL Adjustable Rear Trailing Arm
Stillen Core Support Bar
Whiteline Front and Rear Urethane Bushings
Whiteline Rear Traction Bushings
Whiteline Sub-Frame Bushings
Custom Roll Cage by SnR Performance
Brakes:
Greddy 8POT Front Calipers
Greddy 4POT Rear Calipers
Greddy 385MM Slotted Front Rotors
Greddy 335MM Slotted Rear Rotors
Greddy Stainless Steel Brake Lines
Stillen Master Cylinder Support Bar
Cooling and Fuel:
Altered Atmosphere Return Fuel System
Greddy Performance Radiator
Greddy Oil Cooler
Greddy Air Diversion Plate
NISMO Thermostat
Dual Walbro 255 fuel pumps
Custom Brake Cooling Duct System
ARC Belly Pan
Rear diff cooler
Transmission Cooler
Transmission:
OS Giken Triple Plate Racing Clutch
OS Giken Racing LSD
Rear Axle Brace
Electronics:
Haltec ECU with all sensors
Greddy Infometer Touch Complete System with all sensors
Greddy Profec B-Spec II Boost Controller
Greddy Profec Remote Switch
DashDaq Datalogging System with Accelerometers
Stillen Grounding Kit
Old Apr 18, 2010 | 07:53 PM
  #109
aloh's Avatar
aloh
Lots of money there...cant wait to see it when its done.
Old Apr 20, 2010 | 06:25 PM
  #110
GAMERMODZoCOM
Ordered a set of the Tomei 280 version from Z1 Performance. I will let you know how they work out for me.
Old Jun 4, 2010 | 08:03 PM
  #111
GAMERMODZoCOM
Just an update.
The Tomei 280 cams arrived Thursday. They are being cryo'd then installed. The motor should be done, in and tuned by the 19th.
I will let you all know how the cams did on the HR motor.
Old Jun 5, 2010 | 12:26 PM
  #112
0jiggy0's Avatar
0jiggy0
Thanks, we're all just waiting to do our own 1200 hp build. LOL
Old Jun 6, 2010 | 06:18 AM
  #113
GAMERMODZoCOM
Old Jun 6, 2010 | 09:13 AM
  #114
biggersNISMO
Just an update.
Cool, good luck bro. I hope they work well.
Old Jun 6, 2010 | 11:47 AM
  #115
Lakeside's Avatar
Lakeside
To put this much $$$$$ and HP into this platform will most likely be a fail... At least with the GTR you have AWD to better transfer the power to the wheels. This car will be a death trap. But hey thats my opinion.
I wish someone here would do a full NA HR build. Cams, pistons(increased compression) porting, possible stroker, etc etc etc. Those Dyno #'s would draw my interest.
Zim
Old Jun 6, 2010 | 11:52 AM
  #116
0jiggy0's Avatar
0jiggy0
Zim
A car doesnt need to be AWD to put power down. There are way more Very High HP cars that are RWD. And this isnt a street car, its a time attack purpose built car. I'm very interested to see what this car does myself.
Old Jun 6, 2010 | 05:46 PM
  #117
GAMERMODZoCOM
Um, the 350Z is a great platform and is why you see so many people run them.
If I wanted to be the size of a small bus and have a weight of nearly 5k lbs, I would have gone with the GTR. Also, do you think I would have spent less or more getting the same amount of power out of the GTR?
Oh and FYI, the dealership I found this Nismo at had one on the floor and I concidered but found the NISMO edition to be way more realistic for 60k less. I would have chosen a Z06 over the GTR as well and while we are even humoring the idea, for nearly the same money as he GTR I could have purchase the Porsche GT3 RS which makes the GTR look like a ford focus on the track. Even articles comparing the Nismo to the GTR state "if the Nismo had more power it would dominate the GTR on the track".
Sorry if it sounds like it's a sore topic but when you are spending 100k on a car, there are much better options than the GTR. just my opinion.
Old Jun 7, 2010 | 09:34 AM
  #118
nismonian's Avatar
nismonian
colin, your next platform should be an imported R34 from japan
Old Jun 7, 2010 | 12:02 PM
  #119
midz350's Avatar
midz350
Nissan GT-R (2009) best time in the Nürburgring = 7:26.70
Porsche 911 GT3 RS 997MkII best time in the Nürburgring = 7:33
Old Jun 7, 2010 | 12:26 PM
  #120
GAMERMODZoCOM
I don't buy that. The GT3 RS comes through the slalom at 76 or 77mph compared to the GTR's 72. The GT3 pulls 1.01G's on the skid pad where the GTR does .99. That's a big difference that should be seen on the track. Bad driving by the porsche driver?
