HR DIYs???
Old Mar 12, 2009 | 07:37 AM
midz350's Avatar
midz350
Red face HR DIYs???
Hey guys
can someone plz show me where can I tap for the boost gauge and oil catch can ? I think I know where but not really sure TO MUCH FREAKEN LINES THERE
I searched a lot but I find the threads only for the DEs.
WE NEED MORE DIY FOR THE HR SECTION PEOPLE
Old Mar 12, 2009 | 10:38 AM
neverenough's Avatar
neverenough
Originally Posted by midz350
Hey guys
I drilled and tappped a port on the rear of my intake by the brake booster port. It not very hard to get the intake off and only about 10 min to drill and tap a new port. I had to change out the injectors so I did it while the intake was already off. I am not running a catch can so not sure on that one.
Old Mar 13, 2009 | 11:28 AM
BlueZ33's Avatar
BlueZ33
has anyone done a diy for a grounding kit?
Old Mar 13, 2009 | 01:21 PM
Tomek350Z's Avatar
Tomek350Z
check out stillens website, they have instructions for it
Old Mar 13, 2009 | 02:39 PM
Peak350's Avatar
Peak350
Hey guys
Are you wanting to run a vacuum pump based catch can or a recirculation based catch can. You'll need a pair of check valves and to tap into the intake manifold (assume this is where the stock PCV system connects to) with a one way so it doesn't boost into the crank, and put the other one way going into one of (or both) of the pre-turbo pipes. Those two act as your "vacuum source", connect them to a "T" and the output of the T goes to your catch can, which then pulls from the crankcase breather.
Old Mar 13, 2009 | 04:47 PM
midz350's Avatar
midz350
There is a line running in the back of the engine that's connect the intake tubes after the throttle body's!! is it good to tap the boost gauge there??
Old Mar 15, 2009 | 12:29 PM
midz350's Avatar
midz350
Any one? plz
Old Mar 16, 2009 | 05:25 PM
midz350's Avatar
midz350
Bumb? pleeeez
Old Mar 17, 2009 | 05:08 AM
MDHRZ's Avatar
MDHRZ
Contact GTM
Old Mar 17, 2009 | 08:28 PM
fstrnldr's Avatar
fstrnldr
basically the port you have circled is one of the two ports for the purge valve. These will work for your gauge if you want to "T" into them. It is often cleaner to add another port in manifold for your gauge/boost controller. When i do them i use an 1/8npt fitting (hose barb size can be whatever you need). I also put a bit of super glue around the inside of the hole after i tap the threads in. This seems to soak into the composite manifold and build a bit more strength in the threads.
As far as the catch can, i agree w/ peak350, other than calling the turbo's intakes a "vacuum source" since they really won't have any vacuum to them. They will work for the situation, just calling it a vacuum source is a bit misleading.
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
NFAC
Sep 26, 2015 10:11 PM
