Stillen HFC on 350Z HR 313hp Italy
Old Oct 11, 2009 | 12:30 AM
karletto66's Avatar
karletto66
Default Stillen HFC on 350Z HR 313hp Italy
Hi to all and sorry for quite "old" question but i made a lot of search and have no "sure" answer.
I live in Italy and have taken this year a nice new 350Z, with HR engine (313hp in my country)
I have the opportunity to get at a good price a couple of new Stillen HFC for my car (in Italy is a real PAIN to found hardware for these cars at good price...) and i have a small question:
with this HFC i got FOR SURE CEL light????
I take the car for mounting to a car shop, so the problem of dismounting the OEM is not mine...
But the CEL can a big question, my car is new and i don't want to have problems at the moment.
Thanks a lot from Italy and sorry again for "silly" question....
PS: someone has idea of good shop sellers to my country????
Thanks also for this !
Old Oct 11, 2009 | 01:07 AM
turtleboy's Avatar
turtleboy
good luck
Old Oct 11, 2009 | 02:13 AM
karletto66's Avatar
karletto66
Originally Posted by turtleboy
good luck
SO what?
CEL or non CEL, that's the question...
Luck is "another" question...as in all cars...
Old Oct 11, 2009 | 02:24 AM
turtleboy's Avatar
turtleboy
If you get a CEL, pac the o2 housing it with some brillo and you should be ok. Make sure you get it tuned for your mods so you do not get any CEL.
Old Oct 11, 2009 | 02:56 AM
karletto66's Avatar
karletto66
I have no other mods. Car is brand NEW...
So only this HFC for now& a lto fo time...
What you mean with "pac the o2 housing with some brillo" ?
Sorry but my english is quite InformationTechology or general oriented, not so good in car's and mechanical...
Thankssss anyway !
Old Oct 11, 2009 | 03:18 AM
turtleboy's Avatar
turtleboy
do some searching on here. You can pack the rear 02 sensor to make it think that it is working properly.
Old Oct 11, 2009 | 04:07 AM
Ataru074's Avatar
Ataru074
well if your english isn't that good... let's try in this way. (sorry guys)
le "brillo pads" sono spugnette metalliche MOLTO sottili abrasive... il trucco e' nel togliere il sapone che c'e' dentro, pulirle e pigiarne un pezzo dove si avvitano le lambda dietro i catalizzatori.
comunque non mi ricordo come fanno il controllo per delle emissioni in italia, ma la cosa piu' facile (e piu' sicura) e' ordinare una rimappata alla uprev (ti compri il cavo e quello che ti serve, cosi' puoi rimettere la mappa di serie quando ti ci vuole) e far disabilitare quelle lambda li. anche perche' ti va il rapporto stechiometrico a troie e non guadagni un emerico ca$$o.
se chiedi a me (e abito a Houston, quindi sta roba la trovo ovunque) non ne fare di niente... l'unico motivo per togliere i catalizzatori e' andare in pista e togliere un sacco di calore dalla zona motore. io ho avuto i berk e mi si e' sbriciolato l'interno dopo una decina di pistate, quelli di serie mi si sono aperti in due e gli stillen non credo che siano meglio dei berk...
se puoi vai di tubo dritto e officina amica per fare la revisione
il rumore aumenta poco quindi gli sbirri non ti rompono i coglioni.. ma la rimappata ti serve comunque... io con tutto lo scarico, niente catalizzatori, rimappata seria fatta sul banco ho preso una 30ina di cavalli alla ruota.
poi dipende di dove sei e in italia conosco un paio di posti dove possono farti un lavoretto per bene sia per lo scarico, sia per la centralina.
Old Oct 11, 2009 | 04:19 AM
TheMinel's Avatar
TheMinel
eheh not bad.. you of Italian origins I guess
Old Oct 11, 2009 | 04:24 AM
karletto66's Avatar
karletto66
Brillo !!???!!???
I was thinking about a lot of things but no one of this kind...!!!!
Teribbbileeee !!!!
So you don't think that for road usae a Stillen HFC is quite good?
I'm near Torino by the way...
Thanks for info, may be we can speak in PM !
Old Oct 11, 2009 | 06:37 AM
jumpin800agl's Avatar
jumpin800agl
8 to 11
Nice to see more Italians on here. Seldom do I see any nice Z's around here that are not owned by us Americans.
Old Oct 11, 2009 | 06:52 AM
Jay'Z's Avatar
Jay'Z
Us? U dont have a Z lol
Old Oct 11, 2009 | 06:57 AM
Lakeside's Avatar
Lakeside
You will not need Brilo!!! You haven't even instaled your HFC's yet! HFC's will not throw a CEL......
Old Oct 11, 2009 | 06:59 AM
Jay'Z's Avatar
Jay'Z
True, my UR HFC never threw a cel....
Old Oct 11, 2009 | 07:02 AM
kyle22's Avatar
kyle22
i thought the title meant you put on stillen HFC and got 313 whp without anything else done...i got a little excited...everyone gets the CEL after i installed my HFC i got the CEL now im just waiting to get tuned then it will be removed...so find a tuner near you (if any).
Old Oct 11, 2009 | 07:14 AM
Install the high flow catalytic converters. No need to fix a problem that does not exist.
Old Oct 11, 2009 | 07:21 AM
diablox1's Avatar
diablox1
I have stillen HFC on my '07 HR. It threw the CEL light (SES). I fixed that really quickly with some spark plug non-foulers. No more light for me.
Old Oct 11, 2009 | 08:06 AM
karletto66's Avatar
karletto66
Thanks to all !
So the CELL is comig quite for sure in 07 Z, a pity...
Ok i can fix it bun anyway is a kick in the ***... (rottura di palle in italiano! )
I also have some infos about bad A/F ratio after HFC (becoming too lean) and that is better to do a remap to fix A/F...
In this case i prefer to wait, my car has 300km!
A little too few for starting with "invasive" mods...
See you on streets boys !
Old Oct 11, 2009 | 09:43 AM
TheMinel's Avatar
TheMinel
then you mean "pain in the ***" in english
Old Oct 11, 2009 | 10:15 AM
jumpin800agl
8 to 11
I had a TT Z longer than you have. Don't worry thought the G37TT will be better.
Old Oct 11, 2009 | 11:49 AM
karletto66's Avatar
karletto66
A kick is quite painful...
Any infos about A/F ratio too low wiht HFC?
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
codek
Sep 28, 2015 03:03 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
