HELP! AXIS Milano Rims not mounting on front
on
I need help! I was unable to mount my front axis milano rims becuase of a bolt that sticks out that holds the from hub in. The picture shows the bolts that hold the rim on and then there is a bolt in between them that sticks out. That bolt is actually blocking the rim from mounting . Do you guys think the rim is defective?? I did purchase them from an ebay store and they stated that the wheels were specifically for 350z. I guess I should contact the seller and see if I can change them.Sucks cuz I already mounted the tires.
on
Is that it?? take the bolt off? OMG hope that will work.I didn't have the right tools so I did not try that. I got the rims for $1229 shipped and the tires for around $960. toyo t1s 275/30/20 and 245/35/20.
I'll try it tomorrow, thanks.
Originally Posted by nitrouz
at least you didn't drill a groove on the back of the rim to try to fit it on.
https://my350z.com/forum/showthread.php?t=120607
on
I don't have them on yet. I got some tuner lugs that have a special tool to fit them in the holes. You can prob pick them up at any import or tuner shop. I am going to be lowering on tein s-tech in a week or two when I find time to get them installed.
Originally Posted by need Z
People actually do that?!?!?!?!?!?
I know, you could have knocked me over with a feather
on
I had the same problem when mounting my Enkei RPO3's. Called Nissan Service and they said it's OK to remove the bolt and sleeve--"just don't lose it, because when you change front brake pads it needs to be re-installed (and then removed again) to make sure everything lines up properly" Although that makes NO sense to me, I swear that's what they said.
Imakecopies
on
I think thats a load of crap
04-04-2016 07:52 AM
Tonyz_2004_350z
South East Marketplace
10-04-2015 12:53 PM
