VDC after Intstall of Toys
Old Jul 10, 2005 | 12:27 AM
GSpot's Avatar
GSpot
Default VDC after Intstall of Toys
Alright, so I just installed Alphawerks headers, Stillen Sways, GReddy Evo II, and a UT Polished Z tube... Now my NAV is telling me I have a VDC problem and to take it to an Infiniti Dealer.... Does anyone have any idea why it would be saying this? I don't know exactly what the VDC is hooked into, but I don't think I touched anything that would make it kick the warning.... NEED HELP!!! I reset the ECU twice now, and it keeps coming back. How can something mechanical like sway bars affect something electrical/sensors like VDC?? HELP ME OUT!!!
Old Jul 10, 2005 | 12:33 AM
westpak's Avatar
westpak
SFZCC
Is it coming on for no reason or is it during driving.
Old Jul 10, 2005 | 12:38 AM
GSpot's Avatar
GSpot
it comes on for no reason, different conditions all the time... no extreme driving. I will be driving for no more than 2 min and the VDC off and Slip light will turn on and it will kick on my Nav screen s well. It stays on as well.
Old Jul 10, 2005 | 04:05 AM
westpak's Avatar
westpak
SFZCC
Sometimes a set of sways depending on how stiff they are might cause it in the sense that if you take a corner or mayne even bumps, I don't know, the car is stiffer now and might tend to cause one of the wheels to lift, but yours seems to be an extreme case, unless that maybe during the install of the exhaust and relocation of the evap some connections were messed up. Does it kill the engine or just the light comes on.
If it is just the light then it seems like it might be electrical and need to recheck what was done in the rear during the install of the exhaust and relocation of the evap that is required by the EVO 2.
Old Jul 10, 2005 | 08:24 AM
King Tut's Avatar
King Tut
Header install eh. Sounds to me like they disconnected the steering and might not have put it back exactly as it was which messes with the VDC and will cause it to be on all the time. I've seen that a couple times.
Old Jul 10, 2005 | 09:30 AM
GSpot's Avatar
GSpot
King Tut... thanks for the input. I found that out last night. I realized my steering was off and I was looking in the manual and the steering angle sensor kicks the VDC light. So I'm fixing the steering today. These cars are just too smart
Old Jul 10, 2005 | 11:21 AM
GSpot's Avatar
GSpot
Def was the steering. PROBLEM SOLVED! Thanks.
Old Nov 20, 2007 | 04:58 PM
SoCal Piliguy's Avatar
SoCal Piliguy
Can you explain in detail how you fixed the problem.
Thanks!
Old Nov 20, 2007 | 09:28 PM
Thanks!
The last time that GSpot visited was over 2 years ago.
Old Nov 20, 2007 | 10:21 PM
SuperBlack350z's Avatar
SuperBlack350z
lol
Old Nov 21, 2007 | 02:17 AM
j-velocity's Avatar
j-velocity
I have the same problem just after I installed my rims..
Any one got an idea what's going on?
Thx
Old Nov 21, 2007 | 07:39 AM
GSpot's Avatar
GSpot
Luckily I was still subscribed to this thread and it e-mailed me. I am not sure why you are getting the problem after installing wheels. My problem was the fact that I had to undo my steering arm and when I put the splines back in, I was off by like 30 degrees (my steering wheel was turned sideways when I was going straight). In essence, my car thought I was always turning at like 45 mph (hence the VDC kicked in). All I had to do was remove the steering arm, and have someone hold the steering wheel perfectly straight when I put the steering arm back in. Hopefully this helped. If not, let me know. It's been a long time since I've done it. I can picture it in my head, but it's hard to explain I guess.
Old Nov 21, 2007 | 10:26 AM
j-velocity's Avatar
j-velocity
So it should be somthig wrong about the steering parts??
Old Nov 21, 2007 | 10:29 AM
06Gcoupin's Avatar
06Gcoupin
Thx
Youre tires could be the culprit, what are your tire sizes? Incorrect tire sizing is one of the main causes of VDC freaking out
Old Nov 21, 2007 | 11:13 AM
Miami-Z's Avatar
Miami-Z
yea i have the same issue, my car now does not start right away, it takes a few seconds then when it does turn on the VDC and SLIP are already on plus the car moves really slow. i have 275/30 rears and 245/35 fronts. it has been happening everyday now for a 2 weeks, before it would go weeks without the VDC kicking off. it really sucks
Old Nov 21, 2007 | 01:33 PM
j-velocity's Avatar
j-velocity
I have 245/35R19 and 275/35R19....
Old Nov 21, 2007 | 01:41 PM
Miami-Z's Avatar
Miami-Z
iguess i need to chenge my rears to 35's. kinda sucks since they are new
aarrgghh
May 1, 2022 11:04 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
audball
Oct 21, 2002 12:00 PM
schindem
Oct 10, 2002 02:11 PM
