front rotors
Old Oct 26, 2005 | 03:47 PM
benchi445's Avatar
benchi445
Default front rotors
Hi, I need to replace my front rotors to pass a state inspection. I was quoted they would be $69.95 a piece. Anyone else who bought front rotors what did you pay? Also my drivers side window only rolls down occasionaly and they said it was either the motor, the switch, or the regulator, Has anyone else have this happen to them, and how much was it to get fixed? I just missed it under warranty by a month.
Thanks
Old Oct 26, 2005 | 04:01 PM
absoluturq's Avatar
absoluturq
the window thing happened to me, it turns out it was the motor, warranty tho
Old Oct 26, 2005 | 05:00 PM
ericjackson's Avatar
ericjackson
dang, mississippi they are like. turn signals, low beams, high beams, brake lights... heres your sticker, that'll be $5, thank you
Old Oct 27, 2005 | 12:55 AM
the7ferret's Avatar
the7ferret
Thanks
I wouldn't trust those rotors...
OEM i beleive are like $200 a pair.
You can get good aftermarkets for like ~$100 a peice.
Old Oct 27, 2005 | 04:25 AM
benchi445's Avatar
benchi445
the rotors i would get for 69.95 are oem from the nissan dealership, its just that i get an employee discount.its $69.95 a piece
Old Oct 27, 2005 | 04:33 AM
CLETUS's Avatar
CLETUS
if you go to a nissan dealer and explain the situation (1 month out of warranty) they should fix the window. if not the motor is bad and it alone w/out labor is 260. they should take care of you though.
Old Oct 27, 2005 | 05:45 AM
xephiron's Avatar
xephiron
if I was gonna replace rotors... or anything brake system related, I would atleast just get the Stop-Tech stage 2 kit. $650 and comes with new rotors (drilled or slotted), SS brake lines, Motul synthetic fluid, and Hawk pads. not a bad deal.
Old Oct 27, 2005 | 08:59 AM
jt1213's Avatar
jt1213
F.Y.I. - When I had my window motor replaced (under warranty), the service department made a comment that out of warranty, it was approx. a $480 repair / replacement.
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
