wheel weights
Old Jan 11, 2006 | 12:46 AM
wvz's Avatar
wvz
Default wheel weights
Hi All,
I found this site which lists a bunch of stock and aftermarket wheel weights and other specs. The stock 03-05 18" 350Z wheels weigh like 27 lbs, according to this
Here's the site... http://www.wheelspecs.com/specs/
Old Jan 11, 2006 | 12:57 AM
.Sin.'s Avatar
.Sin.
I'm surprise to see that "27lb" on stock 18....
Old Jan 11, 2006 | 07:53 AM
Thanks for the informative post.
Maybe 1 in 10 350Z owners care about weight. The other 9 go gaga over a 4 inch lip. Go figure.
Old Jan 11, 2006 | 11:04 AM
rbfd's Avatar
rbfd
damn track wheels weigh 8lbs less per wheel than a touring 18! Any one want to straight up trade some track wheels for some tourings
Old Jan 11, 2006 | 01:14 PM
bilinghm's Avatar
bilinghm
This is why I selected Enkei RPF1's, 18x 8.5s /9.5's are just over 18 lbs. each, This is a signicant difference. It makes a real world difference in how the car drives.
Old Jan 11, 2006 | 01:30 PM
sluggoZ's Avatar
sluggoZ
Can you post some pics?
Old Jan 11, 2006 | 02:11 PM
MarquisDeSam's Avatar
MarquisDeSam
I agree. I'm running 18 x 8.5/9.5 Volk TE37 and they weigh in at 17 lbs for the front. So much quicker off the line, compared to my old 19's.
Old Jan 11, 2006 | 02:13 PM
sq40's Avatar
sq40
Light weight wheels tend to bend easier dont they?
Old Jan 11, 2006 | 02:16 PM
ANXIOUZ's Avatar
ANXIOUZ
Enkei is terrible about giving their weights. I have 18" G'Spec GTV's and have no idea how heavy they are. One place said 24lbs but I can't confirm that.
Old Jan 11, 2006 | 09:39 PM
wvz's Avatar
wvz
I think if you could save 10 lbs or even 8 lbs per wheel it would make a noticeable diff in everything...mpg, accel, susp wear, etc. The stock 17s are pretty heavy too. I wonder if tire weights vary much?? The Nismo wheels only weigh like 18 lbs...that's a good thing...would like to pick some of those up eventually...
Old Jan 12, 2006 | 05:50 AM
Vamos_Rafael's Avatar
Vamos_Rafael
Go for BBS 17s or go for SSR 17s...
weigh like 15 lbs each...
cant go much lighter in terms of cost > performance
Old Jan 12, 2006 | 05:59 AM
No. Strength is related to the construction process, not weight. It is possible to make a strong lightweight wheel, and that wheel will cost you $500 plus.
Old Jan 12, 2006 | 07:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
My 19X9.5 LE37 weighs 19lbs. And my 19X10.5" out back comes in at 19.8lbs. VERY light for how wide these are. BTW-I def care about weight over lip as every mod I do is performance minded....
Old Jan 24, 2006 | 06:04 AM
sq40's Avatar
sq40
What do the Stock 17's Weigh? Is there a measurable difference in mpg and accel?
Old Jan 24, 2006 | 07:59 AM
The difference is not so much related to mpg, but acceleration. Simply it takes more power to turn a 20-pound wheel that a 18-pound wheel. How much more power? Don't know.
Old Jan 24, 2006 | 10:30 PM
J3rzeyFlip's Avatar
J3rzeyFlip
the Le37 i think is one of the best when it comes to looks and weight! U get the best of both! I chose the SF Challenge rims over the le37s cause they look so damn sexy! The way i look at it, is that i take out the spare on the trunk and other heavy things! I also mod up more to make up for that weight added!
Old Jan 25, 2006 | 05:06 PM
breakbeats's Avatar
breakbeats
Another good wheel weight site, http://www.wheelweights.net
Old Jan 25, 2006 | 06:17 PM
jjellyneck's Avatar
jjellyneck
Yes, but....it's the weight of the rotating mass that matters more than the weight of the car, at least proportionate weight difference. It takes more power to spin a 5 pound heavier wheel/tire combination that removing 5 pounds of groceries in the trunk. It's something like a 6:1 ratio for unsprung weight, but for wheels, it might be more.
Old Feb 2, 2006 | 07:17 PM
wvz's Avatar
wvz
Does anyone know what the 18s from the G35 weigh, and if they are an easy swap on an '05 touring? If they weigh much less than the 27.5lb touring wheels then I think I'll try to swap them out! I can't quite stand driving the Z with such heavy wheels...
Old Feb 2, 2006 | 07:21 PM
wvz's Avatar
wvz
What are the differences you noticed? MPG? Accel? Handling or steering feel? What about tracking? Seems like my 18s are a little tough to track (not racetrack) if there are any grooves in the pavement. Thanks for the info!!
