Need Opinions! 255/35/18 or 255/40/18 on Touring rims?!
Old Jan 13, 2006 | 01:37 AM
Acree's Avatar
Acree
Default Need Opinions! 255/35/18 or 255/40/18 on Touring rims?!
Just as the title says, I need to figure out what kind of profile I should run on the stock 18 inch Touring wheels. I know that I will run 255's all the way around, but I need to know which profile looks better and performs better. Pics would VERY appreciated. Thanks.
~Acree
Old Jan 18, 2006 | 05:57 AM
Sportec's Avatar
Sportec
fr 255/40 , 275/40 rear. Dont change the wheel diameter.
Old Jan 18, 2006 | 06:01 AM
Sportec's Avatar
Sportec
if u are going to have 255 rear make it /45 and u are going to be only +9mm off spec. 255/40 is going to be -17mm off spec and it is a lot!
try this
http://www.tyresave.co.uk/tyresize.html
Old Jan 18, 2006 | 10:53 AM
Acree's Avatar
Acree
try this
Can you please elaborate when you say 17 mm "off spec?"
Old Jan 18, 2006 | 12:38 PM
barthelb's Avatar
barthelb
Master
Get the combination that is closest to stock Wheel Diameter. Stock wheel diameters are:
25.8"Front
26.8"Rear
Old Jan 18, 2006 | 01:17 PM
Acree's Avatar
Acree
25.8"Front
26.8"Rear
Why exactly does it matter? I'm not worried about extra space in the wheel well. I'm already dropped an inch. I do not have VDC. Is there any other reasons to not run 255/40/18 all the way around?
Old Jan 18, 2006 | 01:31 PM
barthelb's Avatar
barthelb
Master
If you don't have TCS or VDC then the only thing it will affect may be your speedometer. But it won't be affected that much so I wouldn't worry.
Old Jan 18, 2006 | 01:36 PM
Acree's Avatar
Acree
Awesome. Thanks for the info. The tires will be mounted Saturday. I will be running BFG g-Force KDW-NT 255/40/18 on all four corners. This thing should grip!
Acree's Avatar
Acree
ok.. Double post, not cool.
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
