is this guy smart or stupid???
Old Sep 18, 2006 | 08:19 AM
imonlykidden's Avatar
imonlykidden
Default is this guy smart or stupid???
a guy i over heard talking to his friends said he didnt want to spend 120beans to get wheel spacers so he went to lowes and got nut's, or washers (i forget) and put them on the bolts then put his tire on....i mean wtf? i had to share this with you. by the way it's not a 350z...go figure its a hoopty but is that even safe or anything?
sounds like the wheel won't have much bolt to hold onto if you put nuts or washers on the other side of the tire to make the tire stick out...
hahahaha..(w/e u might think its me, but i would never do that to my 350. to much money in my car to put nuts behind the tire to make it stick out)..
anyway....
he smart - for going around the 120 beans for spacers..
or stupid - for going around the 120 beans for spacers and getting (nuts or washers)..
i gotta hear some of your comments...hahaha!!!!
Old Sep 18, 2006 | 08:30 AM
Jason021174's Avatar
Jason021174
i think the guy is retard. like you said, he will lose threads on his stock studs.
Old Sep 18, 2006 | 08:52 AM
moforeynolds's Avatar
moforeynolds
this shouldnt even be a question, thats beyond stupid. Universal spacers need to be put on pretty carefully or they will throw off your wheel balance. Spacers that are wide enough to warrant their own studs are usually easier to line up since the screw in to your existing lugs, but going that wide is not very safe.
To be fair, I don't see how a washer or two would hurt anything--it isn't going to make a visual difference though, either. Not that I would ever do it anyway. But having 2" of washers is pretty scary, I wouldn't want to be any where near that car. Tell your friend to buck up and buy spacers, they aren't that expensive.
Old Sep 18, 2006 | 09:18 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Wrong on many levels all mentioned above.
Old Sep 18, 2006 | 10:33 AM
davidf's Avatar
davidf
Hopefully no one else will be killed because of it.
Old Sep 18, 2006 | 11:33 AM
MustGoFastR's Avatar
MustGoFastR
Wow. Just wow...
First, spacing the wheel out just about any amount means the wheel will be off center b/c it won't be seated on the hub (same as like getting spacers that are not hubcentric and using them without centereing rings). Second, all the forces applied under cornering and such will be applied directly to the luttle nuts or washers or whatever as well as the lugs, and not distributed over the surface of the hub b/c the wheel is no longer seated on it. Third, as mentioned, you lose threads without swapping lugs... Jeez; hope this guy has good insurance and roadside assistance...
Old Sep 18, 2006 | 12:00 PM
Q45tech's Avatar
Q45tech
Even with some spacers the entire hub is not covered so that the rotor heat is not properly conducted to the wheel to aid cooling. Same with those funky plastic hubcentric matching rings.
The wheel mass adds [partially] to rotor mass in determing final [peak] rotor temperatures in mountain braking.
Old Sep 18, 2006 | 01:22 PM
Pac Man's Avatar
Pac Man
Darwin award candidate!
Old Sep 18, 2006 | 01:49 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
i second the nomination
Old Sep 18, 2006 | 01:51 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
+1 I would look at him with a serious face, and tell him to go back to stock. This is definitely not a good idea for SO MANY REASONS
Old Sep 18, 2006 | 04:41 PM
ATL_Red_G35's Avatar
ATL_Red_G35
that guy is in big trouble.
Why used "beans"?
Old Sep 18, 2006 | 04:44 PM
BlackZero6's Avatar
BlackZero6
if youre too cheap to get real parts, you shouldnt be modding
Old Sep 18, 2006 | 05:29 PM
TSG-Z's Avatar
TSG-Z
I want to see how his car looks!
TSG
Old Sep 19, 2006 | 07:05 AM
imonlykidden
haha, i never said i knew this fool. i over heard....obviously this guy doesnt have a nice car or even a Z. or just being stupid...
ur asking about why i said beans? haha..same as money. sorry i say beans. like jack and bean stalk..he got beans for his sale...nevermind...
i wanna see him take a corner drive by and throw some new nutts or washers at him..hahah...
anyway..
i'm guessing stupid is the answer! - thanks
-kevin
Old Sep 19, 2006 | 07:16 AM
GSXR-Z's Avatar
GSXR-Z
Tell you what, i am going to do this to test the theory. I will buy nuts AND washer to put on all 4 tires of my Z. To make things interesting, i am going to buy differnt sized nuts and washers for each tire and not even worry about tightening the lugnuts. i will just put them on hand tight. Then i will videotape myself while i attempt to drift in the Z. Once videotaped, i will putmyself on the worlds stupidest videos tv show, if there is one.
Old Sep 19, 2006 | 12:20 PM
imonlykidden
cant wait to see it..haha
Old Sep 19, 2006 | 04:50 PM
slinksZ's Avatar
slinksZ
Holy Sh** Batman, Is this man sucidal or just lacking the brain cells to realize he is not only putting himself in harms way, but others.
Obadabot
Jun 18, 2023 11:31 PM
Alexreyes
Sep 30, 2015 11:30 PM
