I know this will sound dumb but.....
Old Dec 20, 2006 | 06:59 AM
DanielW's Avatar
DanielW
Default I know this will sound dumb but.....
I am getting some used 19" volks that are already on tires. Do I need to take them somewhere to get them put on, or can i bolt them on myself? I'm pretty sure i need to take them but i was just checking to make sure. I asked a few places what they would charge me to mount them and they said they wouldn't do it. I didn't know if they were thinking that I meant mount them on the tires or mount them on the car. Thats my next question? Where would be a good place to do this without scratching the rims and how much should it cost?
Old Dec 20, 2006 | 07:11 AM
jtabraham's Avatar
jtabraham
I would take them to get balanced at the least...most shops will put them on the car for free if you get a balance done.
If they want to charge you, just get the appropriate hub-centric rings (if needed), and put them on yourself. Nothing hard about it...as long as your careful not to scratch the wheels
Old Dec 20, 2006 | 07:14 AM
pesci's Avatar
pesci
Are you getting the rims and tires seperate or are they comming together ?
OR are you asking if you should have someone put them on for you ?
Old Dec 20, 2006 | 08:16 AM
THE TECH's Avatar
THE TECH
This seems like a no brainer. If you can change a tire, you can put the wheels on your car.
Since you are asking though, I guess you probably can't. Next best thing is take them to any tire place to have them do it for you.
Old Dec 20, 2006 | 10:18 AM
Good suggestion. You cannot be certain that the wheels are balanced.
Old Dec 20, 2006 | 10:20 AM
plumpzz's Avatar
plumpzz
Check if the wheel has been balanced. There are small plastic pieces on the inside of the rim that are glued on so they can make it perfectly balanced. If they are there, its balanced. If its balanced, you can just put it on.
Old Dec 20, 2006 | 12:21 PM
TSG-Z's Avatar
TSG-Z
Where in NC are you?
Old Dec 20, 2006 | 03:44 PM
Russ@Z1's Avatar
Russ@Z1
If you're buying those TE's of BigDaddy, just use the hubcentric rings he's providing and put them on yourself. It's not complicated, requires attention not to scratch the wheel, and no special tools are needed.
Old Dec 20, 2006 | 04:55 PM
DanielW's Avatar
DanielW
I'm from charlotte
Old Dec 20, 2006 | 04:57 PM
DanielW's Avatar
DanielW
I think I'm just going to get meineke to do it for 60 bux and make sure they're balanced
Old Dec 20, 2006 | 05:34 PM
Exclamation
Once you find a responsible shop to work on wheels and tires stick with them. If you see a mechanic take a air gun to your beautiful wheels, you know you are in the wrong place.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
Alexreyes
Sep 30, 2015 11:30 PM
samansharif
Sep 25, 2015 12:31 PM
