installing new studs
Old Jan 17, 2007 | 04:07 PM
brandonanix's Avatar
brandonanix
Default installing new studs
hey guys, performance nissan quoted me $290 bucks just t install my new studs, is it that hard to do? Has anyone done it themself on a 2006? any info is much appreciated!
thanks
brandon
Old Jan 17, 2007 | 04:09 PM
ZCARBANDIT's Avatar
ZCARBANDIT
which studs, there are a lot on the z.
Old Jan 17, 2007 | 05:12 PM
brandonanix
WHEEL STUDS GENTLEMEN!! please put as much effort into an answer to my question as you all did with posing and FINDING bbm pictures! LOLOLOL
Old Jan 17, 2007 | 05:26 PM
Your mechanic will most likely be able to remove the studs without removing the hub by using a tool such as this:
Instead of beating in the hubs with a hammer, I recommend that you leave the job to a mechanic.
Old Jan 17, 2007 | 05:35 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
To install the hub bolts... (*wheel studs*)
Remove Wheel
Remove Caliper
Remove Brake Rotor
Press out old studs
Pull Through new studs
Re-install caliper torque to spec
re-install wheel torque to spec
Repeat for each wheel.
Once installed it is best to test drive (which we do) and then re-torque wheels to make sure they are set... It is also recommended to re-torque after 100 miles which the vehicle can be brought back here and we will re-torque...
Considering there is more work involved in changing a wheel stud then brake pads and the labor being charged to you is less then the amount of changing front and rear pads & rotors... For a certified technician to do the work... its a deal...
If I was charging regular "Menu" labor price (for customer other then one of my web customers) we would be looking at $355.88
The price quoted to you was $290, Should actually be $270... I used the wrong labor rate when doing the math on the phone...
Old Jan 17, 2007 | 05:40 PM
ofl0926's Avatar
ofl0926
speaking about wheel studs. i just broke two, one on each side in the rear. i am so pist. the bolts were on soooo tight. i am guessing that when i got my rear tires replaced, they over torqued the bolts. i bet they used an air gun and max torque.
Old Jan 17, 2007 | 06:05 PM
davidf's Avatar
davidf
I've done it, no it's not a bad job, just a little time consuming.
Old Jan 17, 2007 | 07:44 PM
05-Z's Avatar
05-Z
One of these days I'll replace that broken stud from ZDays
One of these days...
Old Jan 17, 2007 | 09:47 PM
Lawn Dart's Avatar
Lawn Dart
Bah! That sucks. They also could have broke from being crossthreaded. Impact guns cause more problems then they solve.
Old Jan 18, 2007 | 05:53 AM
sam30540's Avatar
sam30540
Like one post above said, its really easy to do just time consuming. Unless performance nissan is charging $100 an hour i don't see how the cost is justified.
Old Jan 18, 2007 | 08:21 AM
bofa's Avatar
bofa
DIY, definitely. Follow the instructions above. You don't really need any special tools, although that will make it a lil easier.
So... did you over-torque them?
Old Jan 18, 2007 | 08:56 AM
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
Perhaps this might be of help to you guys. http://www.flsportingnews.com/zwiki/...ud_Replacement
