Vibrations after wheel spacers install
Old Mar 2, 2007 | 04:53 PM
bonusfrag's Avatar
bonusfrag
Default Vibrations after wheel spacers install
I did a seach on this issue and found little result. Maybe you veterans can help.
I am currently running on stockers while other wheels are being painted. I had some Ichiba 15mm spacers installed last weekend (longer studs and all). And I have been getting wheel vibrations ever since. I have checked the following:
1) Lug nuts - They are secure and tight
2) Hubcentric-ness - The hubcentric spacers fit the stock wheels perfectly, so there's no play there.
Here's what I found:
The holes on the spacers which the wheels studs go through are larger in diameter than the studs. So although the spacer sits dead center on the hub, it does have some play and can rotate slightly to the left and right (a few degrees each eay). In other words, they are not stud-centric (is that an actual term?)
I think this is the cause of the vibrations. Anyone concur? How do I go about fixing it?
Thanks in advance
Old Mar 2, 2007 | 05:06 PM
cubu's Avatar
cubu
that shouldn't matter because the wheel isn't bolted to it, as long as its hubcentric its fine, its probably the stockers, maybe they wore down funny or maybe they are deformed from being stored a certain way
Old Mar 2, 2007 | 05:07 PM
cubu's Avatar
cubu
... or maybe the installer messed something up
Old Mar 2, 2007 | 05:09 PM
Hella's Avatar
Hella
id re-check the install or its the wheels.
Old Mar 2, 2007 | 05:12 PM
ObiRedKenobi's Avatar
ObiRedKenobi
The lugs shouldn't matter unless the lug nuts you are using do not have a tapered end to them.
Old Mar 2, 2007 | 05:24 PM
DavesZ#3's Avatar
DavesZ#3
Vibration should only be caused by an out-of-balance condition around the axis of rotation (hub). If the spacers have play in them about the studs, but it's only rotational, that shouldn't cause an unbalance condition, unless they spacers themselves are not balanced. They would be useless if that was the case.
It is possible that the spacer is not getting bolted on flat (parallel to the surface of the rotor and studs)? That would cause your wheel to be mounted at a slight angle to it's rotation and would cause a wobble.
Old Mar 2, 2007 | 06:28 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
could it be your wheels? Something may be wrong with the wheels and just happen to come up right after your spacer install.
Old Mar 2, 2007 | 08:11 PM
z-u-later's Avatar
z-u-later
Can you provide additional information?
1. Where's the problem? Front or rear? Left or right?
2. Is there noise also? Or do you just feel the vibration?
3. Is the vibration all the time? Or only on certain speeds?
4. Is it just during straight line or curves also?
Make sure the lug nuts are torqued correctly? It may not be tight enough, which may be what's causing the vibration.
Old Mar 2, 2007 | 09:01 PM
bonusfrag's Avatar
bonusfrag
1. Front for sure. I feel the left side is more pronounced
2. There's noise, but not metal sounds. More like louder road noise (which I thought was just the stock potenzas... I had falken fk452s on my other wheels which are much quieter)
3. The vibration is pretty constant. but it is much more pronounced at 50-60+ mph
4. both.
Old Mar 2, 2007 | 09:03 PM
bonusfrag's Avatar
bonusfrag
Very unlikely. The installers were very careful (these are very reputable guys even within the my350z community). And I haven't put the car through anything where the wheels could become damaged. I have been driving on thse stockers for the last 4 weeks, even before the spacers. I did not have vibrations then.
Old Mar 2, 2007 | 09:43 PM
tware's Avatar
tware
15mm further out, weak wheel bearing finally gave out? wouldnt be the first time.
Old Mar 2, 2007 | 11:57 PM
z_roadster's Avatar
z_roadster
4. both.
+1, sounds like im having the exact same problem, let me know if you find the cause of the vibration. I started getting it about 2 months after I installed my springs. I'm probably just gonna get my alignment done and see if that fixes it.
Old Mar 3, 2007 | 05:20 AM
DavesZ#3's Avatar
DavesZ#3
I assume if you take the spacers off the problem goes away, right?
Old Mar 3, 2007 | 05:05 PM
Barmats's Avatar
Barmats
Try swapping the front spacers. Does the side with more vibration switch?
Old Mar 3, 2007 | 05:20 PM
Eazzy's Avatar
Eazzy
Off the wall --but, theres not a possibility that the right was put on the left and Visa Versa?----Rediculous, but happens. Other than that, What Dave says was my first thought, A poor mate on the two Flats ( Spacer to Rotor Face )
Foolish to spend too much time, since u will be getting ur Regs back soon. If u spent time and maybe money, do it on the fresh rims, Mite just be a fluke.
Long as ur lugs are tite ---ur cool for now
Old Mar 3, 2007 | 05:25 PM
VN_350z's Avatar
VN_350z
Z suspension is not designed for spacer.
Old Mar 3, 2007 | 06:41 PM
DavesZ#3's Avatar
DavesZ#3
Care to elaborate?
Old Mar 3, 2007 | 06:44 PM
Eazzy's Avatar
Eazzy
Originally Posted by DavesZ#3
Care to elaborate?
Little curious myself
Old Mar 3, 2007 | 06:46 PM
Barmats's Avatar
Barmats
I haven't heard about problems with spacers before. There are several members here who use them.
Old Mar 3, 2007 | 07:15 PM
bonusfrag's Avatar
bonusfrag
Yes, please do elaborate. Your one line response wets my apetite for (more) useful information.
