NEED Help!! TCS VDC "slip" light
Old Apr 29, 2007 | 06:06 PM
madtrixx8's Avatar
madtrixx8
Default NEED Help!! TCS VDC "slip" light
whats up guys my uncle just bought his daughter a Z. Roadster equipped with VDC TCS, any ways he says that when it rains the car starts bogging out/ no power (as if it was in safe mode) and a "SLIP" light comes on in the dash and it also happen to him on the highway (not raining). He said that when he turns the Traction control off the car is fine. any idea?? my Z is BASE so i dont know about the TCS stuff... just trying to fond the prob. dont want my lil cousin drving around w/o traction control. (girls cant drive as it is)
Old Apr 29, 2007 | 06:10 PM
xyberai's Avatar
xyberai
If VDC and TC are on and the tires start to slip, that light will come on and it will cut power. Sounds like in the rain the tires are slipping and TC or VDC is kicking in, hence the bog and the light.
For the record, if its the stock tires, they are awful in the rain and if the car is used the tread might be low as well. First thing i did was invest in new tires.
Old Apr 29, 2007 | 06:50 PM
Korki Buchek's Avatar
Korki Buchek
Yep. Tell him to try to burn out and see if it does the same thing.
Old Apr 29, 2007 | 07:40 PM
Very difficult to second guess what the driver is or is not doing.
Old Apr 29, 2007 | 07:42 PM
diwun67's Avatar
diwun67
Take your cousin's Z out for a drive to verify and report back.
Old Apr 29, 2007 | 07:46 PM
blaukal's Avatar
blaukal
I'd guess it has aftermarket rims/tires that violate the rule of 3%
https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
Old Apr 29, 2007 | 08:19 PM
iceagetlc's Avatar
iceagetlc
Any idea what? You just answered your own question.
Old Apr 29, 2007 | 09:31 PM
ZgoodLife's Avatar
ZgoodLife
put on F&R swaybars.
My car used to constantly disengage the power due to VDC/TC. I took it to the dealer and they said everything was fine, but it kept on disengaging power on most turns going over 25mph. I solved that problem with the sway bars.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
