285s on 19x10
Old May 17, 2007 | 05:08 AM
Kimosabe's Avatar
Kimosabe
Default 285s on 19x10
I need to replace my rear tires and I have 19x10 inch rim. Will 285/35/19s fit? it was either that or the 275/35/19s... I would to like the wider tire look, but whats ur take on this guys? thx in advance
Old May 17, 2007 | 05:59 AM
redlude97's Avatar
redlude97
it will fit fine, I run a 285/35/19 on a 9.5
Old May 17, 2007 | 06:25 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
you'll be fine
Old May 17, 2007 | 06:49 AM
sry110's Avatar
sry110
It should look good. I have 275/35's on a 19x10 wheel and they are ever so slightly stretched (sidewall is almost vertical), so 285's should look a little more muscular.
Old May 17, 2007 | 09:35 AM
___DJK___'s Avatar
___DJK___
Just be careful if you are lowered and have a low offset on your wheels. Not all 285s are the same width so just make sure you have enough clearance.
Old May 17, 2007 | 11:24 AM
Kimosabe's Avatar
Kimosabe
thx for the advice guys, much appreciated. Well im getting falkens, on 21 offset or 26 can't remember. I'll post pics when i get them installed next week
Old May 17, 2007 | 11:39 AM
___DJK___'s Avatar
___DJK___
Falkens are pretty narrow so you should be good
Old May 18, 2007 | 12:28 PM
Rob10_99's Avatar
Rob10_99
Here is what I just got,
BFG 285/30zr20
replaced some smaller
Toyo 275/30zr20
After driving around for a few days now, I think the ride is a little smoother.
Mostly from the tire not being stretched, the bfg's seem to be slightly taller.
More traction for sure!
doublej32
Wheels Tires
Sep 25, 2015 05:05 PM
silver&black03
Mar 3, 2004 05:57 AM
havabooz
Jul 16, 2003 02:42 PM
WP Gaston
Apr 25, 2003 09:46 PM
