Would these fit to a stock 350z?
Old May 25, 2007 | 10:37 AM
HINZIR's Avatar
HINZIR
Default Would these fit to a stock 350z?
I am thinking of gettin some new wheels and tires
currently have a stock suspension 04 350z without brembo brakes
Current stock setup is
Front
Wheel Size: 17x7.5
Offset: +30mm
225/50/R17 94W
Rear
Wheel Size: 17x8.0
Offset: +33mm
235/50/R17 96W
New setup
Front
Wheel Size: 18x8.5
Offset: +30mm
245/40/R18 93w
Rear
Wheel Size: 18x9.5
Offset: +30mm
275/35/R18 95w
Do you think new setup would fit without any problems?
Thanks
Old May 25, 2007 | 12:38 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
With 18" wheels, I think the correct size for the rear tire is 275/40.
Old May 25, 2007 | 01:20 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old May 25, 2007 | 01:34 PM
Also the front tires are taller than the rear.
Old May 25, 2007 | 03:19 PM
terrasmak's Avatar
Should be fine , but you may wont 275/40 rears . You could also do 255/40 fronts if you want.
Old May 25, 2007 | 06:03 PM
HINZIR's Avatar
HINZIR
thanks for the replies.
i didnt think about the front tire being taller than the rear. i am going to change that to 255/35/18 instead.
i wanted to go 275/40/18s in the back but cannot be certain if the it will work without trying and dont have the time ship back tires and stuff.
255/35/18 up front and 275/35/18 in the back is wht i am gonna go with at this point.
i hope the change wont affect the TCS / VDC adversely. I've tried to calculate the change but it looks to be minimal from stock so I hope the ECU or whatever is controlling the TCS, does not think that I am slippin all the time...
Thanks again for the comments.
Cheers,
Old May 25, 2007 | 06:22 PM
Cheers,
You drive an Enthusiast. No VDC to worry about. 255/35/18 up front and 275/35/18 will be fine.
Old May 25, 2007 | 11:08 PM
terrasmak's Avatar
Cheers,
275/40-18 fit no problem , thats what is ont he back on mine. With a 255/40-18 front.
m_0g
Jun 3, 2021 10:05 AM
Mattg350z
Oct 2, 2015 06:51 AM
_koubie_
Sep 20, 2015 06:34 PM
EnjukuRacing
Sep 11, 2015 08:30 AM
NYGiants0186
Sep 8, 2015 10:37 AM
