Those who are running 245/35 & 275/30
Old Jun 20, 2007 | 10:10 AM
tartman's Avatar
tartman
Default Those who are running 245/35 & 275/30
For those of you who are running 245/35/19 and 275/30/19, Does your traction control go nuts?? I see alot of people run this.... Would it be safer to run 235/35/19 in front. According to the tire calculatorthey woould have exact tire sidewall height.
275/30/19 3.2" sidewall
235/35/19 3.2" sidewall
245/35/19 3.4" sidewall
Old Jun 20, 2007 | 10:57 AM
The front tire is 6.50 mm taller than the rear. Not a good idea with VDC.
Old Jun 20, 2007 | 11:06 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no one can tell you what the sidewall will be, since its a % of the tread width and not every 275 width tire has the same physical width to it
those running 245/35 front and 275/30 rear are running the wrong rear
Old Jun 24, 2007 | 04:18 AM
You are welcome.
Old Oct 8, 2007 | 01:22 PM
Denver350z's Avatar
Denver350z
So 235x35x19 F and 275x35x19 R is a good set-up? Dont most people do 245x35x19 F with 275x35x19 R?
Old Oct 8, 2007 | 01:47 PM
OffsetZ33's Avatar
OffsetZ33
I have 265/30/19 F and 275/30/19 R with no problems
Old Oct 8, 2007 | 02:15 PM
redlude97's Avatar
redlude97
245/35/19 and 275/35/19 is the correct choice, 255/35/19 and 285/35/19 IMO is an even better choice
Old Oct 8, 2007 | 02:50 PM
Denver350z's Avatar
Denver350z
So 235/35/19 and 275/35/19 is a bad choice?
Old Oct 8, 2007 | 03:00 PM
OffsetZ33's Avatar
OffsetZ33
I would definitely go with a wider front tire than narrower to reduce the understeer. I would go at most 30mm difference between front and rear tire width, although I prefer a smaller discrepency. The car seems to behave more neutral when the tires are more similar in width front and rear I have noticed.
Old Oct 8, 2007 | 03:10 PM
Denver350z's Avatar
Denver350z
Well, if I was buying the tires right now, I would do that for sure. The problem is that I am buying a set of rims with the 235/275 tire set-up already on and want to make sure they will be drivable and I dont have to replace them right away.
So I will have some understeer issues with this set-up, it sounds like.
Old Oct 8, 2007 | 04:12 PM
redlude97's Avatar
redlude97
yes, and the front tire is pretty short and not provide as much protection for the rim in the 235/35/19 size
Old Oct 8, 2007 | 05:43 PM
terrasmak's Avatar
Yes it is , unless your a drag racer and want skinnies up front.
apex locator
Jul 23, 2021 02:27 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
