question please help..... wheel is touching the caliper
Old Aug 9, 2007 | 06:34 PM
galant350z's Avatar
galant350z
Question question please help..... wheel is touching the caliper
Hello All,
Got a question guys. I bought BBK for my Galant but the wheel(18 inch) is touching the caliper . So I decided to use 5/16 spacer and it will solve all the problems but my friend told me is dangerous because the car will be putting too much force on the spacer. Is that dangerous or is it fine?
Thanks
Old Aug 9, 2007 | 06:48 PM
THE TECH's Avatar
THE TECH
Should be ok assuming your wheel studs are long enough.
Old Aug 9, 2007 | 06:50 PM
SuperBlack350z's Avatar
SuperBlack350z
just make sure you 7-8 turns on the lug nuts before they get tight. If lower, it's unsafe.
Old Aug 9, 2007 | 06:55 PM
Lug nut torque is approximately 80 pounds right?
So how could you be putting more than 80 pounds of force on the spacer?
galant350z's Avatar
galant350z
thanks for the answers,
Old Aug 9, 2007 | 08:21 PM
galant350z's Avatar
galant350z
to be real honest with you, i dont know a lot about cars and i have no idea if i could put more than 80 pounds of force on spacer! would you make it a little more simple for me, thanks
Old Aug 9, 2007 | 08:24 PM
InZomniac's Avatar
InZomniac
Make sure the spacer is hubcentric! Plus I HIGHLY recommend extended studs beyond 3mm spacing.
Old Aug 9, 2007 | 10:26 PM
galant350z's Avatar
galant350z
if i dont have 3 mm, can ET lugs solve the problem?
Workshop12
Mar 23, 2020 01:45 PM
issyz
Jul 2, 2017 03:04 PM
seagrasser
Oct 11, 2015 03:27 PM
Mattg350z
Oct 2, 2015 06:51 AM
