Good Spacers to use with stock 17's?
Old Sep 24, 2007 | 12:43 AM
05Redline's Avatar
05Redline
Default Good Spacers to use with stock 17's?
Well I searched for about a half an hour to see if i could find any info on my own but everyone is running aftermarket wheels, so i decided to give up and ask. Is anyone out there running stock 17's with spacers? If so what are the biggest spacers i can run on these wheels. If you have Pics of your wheels with spacers to attach then please do.
Old Sep 24, 2007 | 12:45 AM
gregtotheb's Avatar
gregtotheb
^^for the 350z the biggest spacers i have seen are 25mm. brands such as project kics, h&r, and ichiba offer those sizes.
Old Sep 24, 2007 | 12:48 AM
05Redline's Avatar
05Redline
So 25mm in front and back then you think? Will i have any problems with rubbing if i go that big?
Old Sep 24, 2007 | 12:58 AM
DanZmanAZ's Avatar
DanZmanAZ
I like your powdercoated rims. ths the exact setup I intend to run but I am going to go +20mm front and +25mm rear, and my car is LeMans Sunset
Old Sep 24, 2007 | 01:01 AM
gregtotheb's Avatar
gregtotheb
i dont know about the front but heres some pics of 25mm rear and 20mm fronts.
https://my350z.com/forum/showthread....t=25mm+spacers
Old Sep 24, 2007 | 02:04 AM
05Redline's Avatar
05Redline
Yeah i think i'm going to go with 20mm in the front and 25mm in the rear also. Thanks for the compliment on the wheels.
Old Sep 24, 2007 | 02:05 AM
05Redline's Avatar
05Redline
Awesome... This is the setup i'm going to go with for sure. Thanks a lot for the pics.
Old Sep 24, 2007 | 10:58 AM
evolved326's Avatar
evolved326
Project Kics 20mm all the way around. With Kics, you do not need to remove the lugs.
Old Sep 24, 2007 | 11:32 AM
redlude97's Avatar
redlude97
the 17's have higher offsets and thus are more sunken than the anniversery 18's though, so 25mm all around would be a better size
Old Sep 24, 2007 | 11:37 AM
Nexx's Avatar
Nexx
powdercoating + spacers = might as well spent that money on aftermarket.
but whatever floats your boat.
from what ive read 20mm front and 25mm rear. ichiba has some good ones at very reasonable prices. check the vendor section under wheels.
Old Sep 24, 2007 | 11:40 PM
05Redline's Avatar
05Redline
I was going to go with aftermarket wheels, but from what i've found the aftermarket wheels that i'm interested in, that are in my budget are all extremely heavy and will make my car noticeably slower. If i could afford a set of volks i definately would, but i just don't see myself spending that much money on wheels. I'm more of a performance kind of guy. And i got a deal on the powdercoating a buddy of mine works at a shop. ($100 for all four wheels while he was off the clock). I couldn't pass it up.
But thanks for the info on the spacers i think i am going to go with the ichiba's i've heard a lot of good things about them.
Old Sep 24, 2007 | 11:41 PM
05Redline's Avatar
05Redline
[QUOTE=evolved326]Project Kics 20mm all the way around. With Kics, you do not need to remove the lugs.
Thanks i'll check them out.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
seagrasser
Oct 11, 2015 03:27 PM
FromGtoZ
Sep 20, 2015 03:41 PM
