350Z with Kinesis wheels...need help!!
Old Oct 21, 2007 | 09:15 PM
drewb612's Avatar
drewb612
Default 350Z with Kinesis wheels...need help!!
What is your opinion on these kinesis supercup wheels on a Z...also would
Diameter: 18in.
Width: 9 .5in (Front), 10.5in (Rear) (Staggered fitment)
Bolt pattern: 5 x 114.3mm (5 lug)
Offset:
(F) +50mm offset (6.75" backspacing),
(R) +44mm offset (7.25" backspacing)
fit a track model (brembos) Thanks!
Old Oct 21, 2007 | 09:20 PM
mr. sparco's Avatar
mr. sparco
Prob won't clear your brakes but like dave079 said the offsets are all messed up for a Z. You want closer to 0 not further away.
fairladyinit's Avatar
fairladyinit
+50!?
Old Oct 21, 2007 | 09:21 PM
drewb612's Avatar
drewb612
Originally Posted by dave079
Do you realize how horrible those offsets are?
actually to be honest I am completely unfamiliar with wheel sizing and fitments, i assume these wheels will not then then correct? Is there a certain offset I should be looking for? Thanks!
Old Oct 21, 2007 | 09:34 PM
black06z's Avatar
black06z
I just don't see these working at all with the Z.
Old Oct 21, 2007 | 09:35 PM
2TH PWR's Avatar
2TH PWR
Yeah wrong size. I am not feeling the styling on a Z either
Old Oct 21, 2007 | 10:32 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Definitely those offsets are for 996 Porsche 911s. Kinesis are nice wheels but you need way better offsets. For a 10.5" wheels you should look for +18 (aggressive) to +24 (well fit / not as aggressive but still flush to the fenders)
If you want ultra aggressive you can go for an 11" wide rear wheel with +17 which is the most aggressive you can go without running too much negative camber.
Old Oct 21, 2007 | 11:15 PM
terrasmak's Avatar
You are looking at an offset in the +20 to +24 range normally depending on the rim.
Closer to 30 if your looking to get the most in tire size on them.
Old Oct 22, 2007 | 02:45 PM
They might work if you turn them around.
Old Oct 22, 2007 | 05:24 PM
terrasmak's Avatar
No most aftermarket rims you see here are in the +20 to +24 range.
Correct , but if you want to put the larger width tires and not need them streched to clear you need what i said.
Old Oct 22, 2007 | 05:33 PM
terrasmak's Avatar
People are putting 285 fairly easily on a +24 9.5 without stretching.
Bet it would rub , remember 9.5 is his front , and 285 is about the limit for what we can put on the front of our cars.
Old Oct 22, 2007 | 05:39 PM
terrasmak's Avatar
Im not talking about those rims. I am just talking about rims in general on the Z. He has the option of putting any rims he wants on it now that he knows those wont work out. He can do a 9.5 rear with a 285 or 275 easily and a 8.5 front with a 245 or 255.
Well if he wants to stay with a 9.5 and 10.5 combo like he's interested in ( if you notice above thats what he was looking at ) i'm just letting him know what he would need. For narrow wheels , guess what , Yes you are right.
Old Oct 22, 2007 | 05:47 PM
mr. sparco's Avatar
mr. sparco
Thumbs up
Might want to clarify what you mean by the "most" in tire size to the OP.
Old Oct 22, 2007 | 10:26 PM
groovy4's Avatar
groovy4
Wow, those rims are screaming early 90's.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
