Will these wheels fit??
Old Dec 12, 2007 | 09:42 AM
Chasecbc's Avatar
Chasecbc
Default Will these wheels fit??
hey, i dont know much about wheels but i found a set i like and i want to know if they will fit or not, some one said the offset might not be right? so let me know thanks
Rears are 18x9.5 +43. Fronts are 18x8.5 +43. Bolt pattern is 5x114.3.
Old Dec 12, 2007 | 09:54 AM
InZomniac's Avatar
InZomniac
That offset is at least 2X what I would recommend.
Old Dec 12, 2007 | 09:55 AM
DustinZ33's Avatar
DustinZ33
you would need about a 30mm spacer, if not more, to bring this flush to the fenders
Old Dec 12, 2007 | 09:56 AM
Chasecbc's Avatar
Chasecbc
ok like i said i dont undersnad much about wheels - what does the offset mean? what will happen if i run them? can i fix it some how?
Old Dec 12, 2007 | 10:07 AM
DustinZ33's Avatar
DustinZ33
http://www.1010tires.com/WheelOffsetCalculator.asp
less offset, the more the wheels stick out. With a 9.5 rear you would need about a +0 to +15 to be flush with the fender.
Old Dec 12, 2007 | 10:22 AM
Chasecbc's Avatar
Chasecbc
so they are fine i just need a spacer to bring them out a little?
Old Dec 12, 2007 | 10:32 AM
Zivman's Avatar
Zivman
technically you could get them to fit, but you don't want them.
Old Dec 12, 2007 | 10:40 AM
DustinZ33's Avatar
DustinZ33
I would get something with less offset. Those wheels will be so tucked in. Stock wheels are +30 so that will give you an idea of what they will look like. NOT GOOD!!! It's pointless to get them with the intention of using a HUGE spacer when you can just get wheels with the right offset.
Old Dec 12, 2007 | 12:02 PM
Triple8Sol's Avatar
Triple8Sol
Those are sedan fitments
Old Dec 12, 2007 | 01:56 PM
Use a offset calculator to compare...
oh heck never mind.
Old Dec 12, 2007 | 02:28 PM
terrasmak's Avatar
a 25mm spacer would be needed to sit at a nice stance.
Old Dec 21, 2007 | 11:46 AM
datspeed77's Avatar
datspeed77
I wouldn't get it! Why spend money on wheels when their not the the right offset. "Wheels make or break your car!" At least in my opinion!
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
