Can i run a +22mm offset?
Old Dec 13, 2007 | 10:29 PM
J-ROZ33's Avatar
J-ROZ33
Default Can i run a +22mm offset?
Just wondering if its possible to run a +22mm offset on my z since its a 11mm difference from factory wheels.
Old Dec 13, 2007 | 10:32 PM
project_drift's Avatar
project_drift
yes, there are people on this forum who run a lot more aggressive offsets than that...check out the wheels and tires section for more insight
Old Dec 13, 2007 | 10:46 PM
J-ROZ33's Avatar
J-ROZ33
I will, Thanks ^_^
Old Dec 13, 2007 | 11:11 PM
r_seng's Avatar
r_seng
22 is the norm.
Old Dec 14, 2007 | 01:59 AM
terrasmak's Avatar
depends on the width of the wheel and if you want the "Hella flush" lowryder stick out look , flushed , or just about flush look.
Old Dec 14, 2007 | 12:37 PM
J-ROZ33's Avatar
J-ROZ33
im getting 18x8.5 +30 in the front and 18x9.5 +22 in the rear i just didnt know if i could run +22 offset. and stock offset for the rear is +33
Old Dec 14, 2007 | 01:55 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Dec 14, 2007 | 01:59 PM
cwest350's Avatar
cwest350
noway!!!!!!!!!!!!!!!! thats suicide bro
Old Dec 14, 2007 | 02:05 PM
He wants to live life on the edge!
Old Dec 14, 2007 | 02:15 PM
z33allme's Avatar
z33allme
That offset will work.. Size tires & drop??
Old Dec 14, 2007 | 03:42 PM
Triple8Sol's Avatar
Triple8Sol
+22mm offset? Whoa...easy tiger!
Old Dec 15, 2007 | 01:52 AM
J-ROZ33's Avatar
J-ROZ33
tire size is 245/45/18
and im running on stock suspension for now, so basically im on stock hight.
Old Dec 15, 2007 | 02:55 AM
badkarma85's Avatar
badkarma85
Just take note of rubbing issues @ the rear if u run 10.5" widths +22 offset if you are dropped.
Old Dec 15, 2007 | 08:46 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Old Dec 15, 2007 | 04:05 PM
taurran's Avatar
taurran
Those will be tucked slightly as they are 8.5" and 9.5" wide wheels.
Old Dec 15, 2007 | 09:57 PM
bbs350z's Avatar
bbs350z
i have +22 w/15mm spacers up front, and 25mm in the rear. the rears rub.
Old Dec 15, 2007 | 11:51 PM
Volk350Z's Avatar
Volk350Z
Master
im running 19x10.0 +20 & 19x11.0 +15
Old Dec 16, 2007 | 10:27 PM
kaoskrayola's Avatar
kaoskrayola
I'm running that setup.
apex locator
Jul 23, 2021 02:27 AM
