Inexpensive TRACK ONLY wheels/Tires that I can rotate
Old Dec 17, 2007 | 05:30 AM
laze1's Avatar
laze1
Default Inexpensive TRACK ONLY wheels/Tires that I can rotate
Help!
I want a set of relatively Inexpensive TRACK ONLY wheels/Tires that I can rotate WITHOUT using spacers....i.e., a "square" setup. likely 17x9...something like the MB Weapons or 5Zigen..I want to run 255/40/17 or 275/40/17 R-comps...
OK, What would you guys recommend today?
Car setup today: 2006 350Z Grand Touring w/Brembo, Hotchkis springs and sways, max camber with stock suspension parts. Not planning to install any Camber kits....The stock fronts GT wheels 18x9 +30 Offset 245/40 barely fit...I can't even slip my bird finger between the tire and upright....but that is why I am asking this question of people who have run this setup before. I have read every damn article on the Net and none of them agree..pretty funny!
Old Dec 17, 2007 | 05:44 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
5zigin is really the only company that makes anything like that its the fn01r-c they arent cheap though but they come in a very wide size. I think i would go with a non staggered set up though if you want to be able to rotate them. When i buy track wheels im going to run 275 all way around because it gets rid of most the understeer and i can rotate them i if i need to.
Old Dec 17, 2007 | 05:54 AM
laze1's Avatar
laze1
Agreed with that about the 5zigin ...now just need to know what offset??????????????? to run with the 17x9
+35 or +25 or +15..........I'm loosing my mind over this....right now +25 appears to be the winner....I don't care about color...
Old Dec 17, 2007 | 06:10 AM
1nate7's Avatar
1nate7
I think you listed the 2 best choices. The MB Competition/Weapon in 17 x 9 +27 would be the cheapest option.
The Falkens are a couple pounds lighter. I ran the +35 with 275/40 all around without issue. The wheels are tucked similar to stock, but if it's a track only setup then I wouldn't worry about it. +25 would be ideal, but I don't see that offset available in 9" width.
Old Dec 17, 2007 | 06:14 AM
1nate7's Avatar
1nate7
Also, Enkei RPF1. Probably the lightest wheel out there that is fairly inexpensive. I see they have a 17 x 9 +22 (15.9 lbs) out that would work really nice, around $1k for the set. http://www.edgeracing.com/wheel/6082/
Old Dec 17, 2007 | 06:53 AM
laze1's Avatar
laze1
What wheels did you run with the +35 17x9 w/275/40s?
But to me, if my stock 18x9 30ET 245/40/18 almost rub to upright. I would think that 35 ET wheels would surely rub.....
Old Dec 17, 2007 | 07:10 AM
1nate7's Avatar
1nate7
FN01R-C. It was very close but it cleared even with -3 degrees of negative camber with Cusco A-arms. If you can find something closer to +25 that would be better, but +35 will work.
Old Dec 17, 2007 | 07:17 AM
Z33_kid's Avatar
Z33_kid
rota's ftw
Old Dec 17, 2007 | 10:23 AM
terrasmak's Avatar
Mb , +27 works great , but i run a 10mm spacer in the rear just because i have it.
Old Dec 17, 2007 | 12:09 PM
z-u-later's Avatar
z-u-later
I have 17x9 (+35mm offset) all around with 275/40s mounted. I have 10mm spacers in front & 25mm in rear. No rubbing issues whatsoever. I had to roll the rear fenders though. My 17x9 rims are only 16lbs & they were only $129 each at Tire Rack!
Old Dec 17, 2007 | 12:23 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
What are they?
Old Dec 17, 2007 | 02:26 PM
laze1's Avatar
laze1
Is this the cheapest way to go for RComps using a 17x9 "Square" setup?
Discount Tire
(4)
MB Wheels
Weapon
17X9 5-114.3 27GM
$140.00 $560.00
(1)
Wheel Installation Kit
for MB Wheels Weapon
$45.00 $45.00
Horizontal Line
(4)
Nitto
NT-01
255/40ZR-17 BLK
$178.00 $712.00
(4)
Valve Stems
$3.00 $12.00
Horizontal Line
FREE UPS Ground Shipping (Other Shipping Options) $0.00
Horizontal Line
Total "Out the Door" Price $1329.00
Old Dec 18, 2007 | 05:07 PM
z-u-later's Avatar
z-u-later
What are they?
Kosei K1 TS (Gunmetal) 16lbs!!!
Old Dec 18, 2007 | 05:15 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
OOOOOOOOOoooooo how do they look and fit without the spacers?
apex locator
Jul 23, 2021 02:27 AM
