Unofficial Enkei Wheels Thread
Old Feb 24, 2014 | 08:43 AM
  #2021
NA&CH's Avatar
NA&CH
Did you swap a 370 roof
Really like the color combo. Nice work!
Chris
Old Feb 25, 2014 | 01:05 PM
  #2022
Underscore_Hero's Avatar
Underscore_Hero
Found a set of RPF1's for sale, needs new tires.
18x9 +35 all around. http://honolulu.craigslist.org/oah/pts/4347177818.html
I'll probably get 245/40/18 in the front, and 255/40/18 in the rear. Sticking with stock suspension, don't need too aggressive of a stance (daily driver). Also notice many members need to run different series tires on the rear/front, why?
Any issues with vdc? rubbing? handling? need spacers? clear brakes?
Old Mar 2, 2014 | 06:52 AM
  #2023
Fillipe's Avatar
Fillipe
Talking
Not sure im worthy of this page but here it is lol
18x9.5et0 245/40
18x10.5et-1 275/40
Size:  162.0 KBName:  52E29E38-2886-4B07-9313-767923565018_zpsav8effeq.jpg
I still need an aligment to correct the stupid amount on negative camber I had. And then prob have to pull the rears to clear.
Old Mar 2, 2014 | 07:29 AM
  #2024
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Dual calipers, nice homie!
Old Mar 2, 2014 | 09:25 AM
  #2025
2004Black350z's Avatar
2004Black350z
Exhaust Whore
+1 on cool brakes -2 bc that's not meaty tires
Old Mar 2, 2014 | 10:15 AM
  #2026
ap2_S2Kyle's Avatar
ap2_S2Kyle
Anyone running 245/40/18 and 265/40/18 on RPF1's 9.5 +15 and 10.5 +15? In dropped on pro kits and d spec shocks 1/2 inch cut on rear bump stops.
Old Mar 2, 2014 | 11:22 AM
  #2027
KingBaby's Avatar
KingBaby
Hardest Setting
The look yea but the numbers no!
Looks crazy nice man!
More on your setup car wise
Old Mar 2, 2014 | 12:47 PM
  #2028
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I had those sizes when I was on S-Techs.
Old Mar 2, 2014 | 02:38 PM
  #2029
ap2_S2Kyle's Avatar
ap2_S2Kyle
Doesn't look bad.. Slightly stretched.. Did you have to roll the rear fenders? Do have a picture when you were lowered
Old Mar 2, 2014 | 02:43 PM
  #2030
AdvanZ33's Avatar
AdvanZ33
I went to a 265 because I wasn't rolled yet and the 275s rubbed.
Old Mar 2, 2014 | 08:12 PM
  #2031
Fillipe's Avatar
Fillipe
Thx. As far as tire size I can't fit anything wider. I'm already rubbing on the rear and it's at like -5 camber. I was into the whole stance **** with stupid camber but thts done. Now I want to start drifting so I'm doing things the right way the first time I guess. The dual caliper set up is a bracket from patinka I got second hand here on the forum. Need to get the pbm hydro brake lever welded up and run the lines.
I'm getting the car aligned Friday so then I will c wht kind of trouble I got myself into :/
Old Mar 2, 2014 | 10:49 PM
  #2032
Waiz's Avatar
Waiz
I honestly give up
That is also not even close to being aggressive
Downsize to 35 series and you can easily go 305's
Old Mar 3, 2014 | 03:34 AM
  #2033
Fillipe's Avatar
Fillipe
Originally Posted by Waizzz
I honestly give up
how the hell am I gonna start drifting with a 305 on stockish power?
Old Mar 3, 2014 | 04:04 AM
  #2034
terrasmak's Avatar
IMO, 245/40 front and rear is the perfect tire for an NA drift Z.
Old Mar 3, 2014 | 05:03 AM
  #2035
Fillipe's Avatar
Fillipe
I got nitto nt05 245/40 front and nt555 275/40 rear. The plan is to grab another set (or at least a pair) of 9.5 rpf1 and use those as rear drift wheels. The 10.5 I have now is for dd and occasional sideways action I guess.
the whole problem here is cuz I fcked up and posted this on the fat tire thread and pissed off some ppl in the process. sry...
Old Mar 3, 2014 | 05:32 AM
  #2036
terrasmak's Avatar
I would probably just get XXR 9.75w wide wheels just to beat up drifting, depending how serious you are.
Old Mar 4, 2014 | 05:31 AM
  #2037
Fillipe's Avatar
Fillipe
im not tht serious at all. I just want to play around with the car for a little. Good looks on the xxr suggestion. thx
Old Mar 7, 2014 | 10:00 AM
  #2038
ap2_S2Kyle's Avatar
ap2_S2Kyle
I'm getting my rpf1s installed Tommorow.. Will the stock tpms work with these? Can these attach to the enkei valve stems they sent with the wheels? Thanks
Old Mar 7, 2014 | 10:02 AM
  #2039
AdvanZ33's Avatar
AdvanZ33
OEM TPMS will fit and they act as your valve stem as well so you don't use the blue ones at all. You should be able to use the blue valve stem caps on the OEM TPMS if you want to add some color though.
Old Mar 7, 2014 | 11:11 AM
  #2040
scotts300's Avatar
scotts300
If you bought black or SBC RPF1s, I suggest painting the TPMS from the stock wheel as it will stand out.
