Unofficial Enkei Wheels Thread
Old Sep 12, 2010 | 02:40 AM
  #521
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Originally Posted by arsey51
Try this next time:
Old Sep 12, 2010 | 05:41 AM
  #522
Nick-VTR's Avatar
Nick-VTR
OK, I don't get it - where did I go wrong -was going to mount the new PF01's (with +15, similar to a lot of the RPF01 setups I've seen on this thread)and look how much they stick out from flush -here are shots or rear 10.5 +15
front
rim sizes are 9.5 front and 10.5 rear +15 on all four. Isn't this size and spec similar to mosrt oif the RPF01s on this thread - and they don't appear to stick out anywhere near to what are doing. Obviously have to have these exchanged, very disappointing day.
iffest, and before tires got mounted,
Wheels should come in when you drop the car down and it settles, however - fairly aggressive offsets, here is a pic of my enkies with the following offsets:
Front: 19 x 9 +18
Back: 19 x 10 +22
Stock camber, needed to roll fenders in the rear as it was rubbing. Stock height.
Old Sep 12, 2010 | 05:44 AM
  #523
AdvanZ33's Avatar
AdvanZ33
^^^ What size rear tires?
Old Sep 12, 2010 | 05:54 AM
  #524
Zivman's Avatar
Zivman
Front: 19 x 9 +18
Back: 19 x 10 +22
Now, I run the same exact offsets/width without rubbing... but an 18" wheel.
295/35/18 rear
265/35/18 front
a little more average photog pic with a dusty car
Old Sep 12, 2010 | 07:51 AM
  #525
03threefiftyz's Avatar
03threefiftyz
Wow, car looks awesome man. What model tire are you running? R888s?
305/30 Kumho Ecsta V710.
Old Sep 12, 2010 | 08:59 PM
  #526
mr. sparco's Avatar
mr. sparco
OK, I don't get it - where did I go wrong -was going to mount the new PF01's (with +15, similar to a lot of the RPF01 setups I've seen on this thread)and look how much they stick out from flush -here are shots or rear 10.5 +15.....
As others have stated. You didn't compensate for negative camber after the car is back on the floor. The suspension needs to be reseated and springs compressed to get an accurate idea of what the car will look like.
Old Sep 12, 2010 | 09:59 PM
  #527
Phenom's Avatar
Phenom
Toasty
Don't get them exchanged. I have +15 offsets all around with 285 rears and 255 fronts and I think it's perfectly flush.
Old Sep 13, 2010 | 07:56 AM
  #528
scotts300's Avatar
scotts300
Thanks! Mike (03threefiftyz) is correct VVVVVVVVVVVVV.
255 is certainly a stretch on a 10.5. Some 275s look stretched on a 10.5, and some don't. I think 285 is the minimum one should run on a 10.5. Here is my same Z with another set of RPF1 wheels that I have that are 18x10.5 +15. All have 285/30/18 Hoosier tires on them:
Old Sep 14, 2010 | 01:14 PM
  #529
costilla's Avatar
costilla
Got the new PF01's dropped off the other day......will put on this weekend......
Dude..lets see the outcome..I want to see the matte blacks on the car..
Old Sep 14, 2010 | 01:16 PM
  #530
costilla's Avatar
costilla
yes..I had the rpf1 with the same ofsets as the pf01 and once the car is lowered from the jack, it will flush out..dont worry..mine were sticking out like that also when discount tires were trying them out..
Old Sep 14, 2010 | 01:32 PM
  #531
terrasmak's Avatar
Well off to the shop to mount my RPF1's , kinda suck i have to run mismatched wheels at the time attack this weekend. But after this race time to order some new front 17x9.5 +18 RPF1's to match.
Old Sep 14, 2010 | 01:48 PM
  #532
Zazz93's Avatar
Zazz93
Did you go silver, black or other?
Old Sep 25, 2010 | 01:03 PM
  #533
jamesdean's Avatar
jamesdean
Originally Posted by ppwpz33
Thought I'd join in!
Lol gonna have to delete that post your rockin my old Oems now !
Courtsey of PPWPZ33 my new to me RPF1's 18x10.5 +15 w/ 265/35/18 all four corners.
Now jsut need some coilovers to remove the 4x4 look
Old Sep 25, 2010 | 02:07 PM
  #534
Waiz's Avatar
Waiz
Nice wheels dude.
It will be a nice setup after you drop that bishhh
Old Sep 26, 2010 | 03:10 PM
  #535
cipric76's Avatar
cipric76
Front: 19 x 9 +18
Back: 19 x 10 +22
Could you please share what tire sizes are you using? I got same wheel sizes and offsets and I got some serious rubbing both front and rear. I was wondering if a fender roll will solve my problems. I am using 275/30-19 and 295/30-19 tires.
Thanks
Old Sep 26, 2010 | 03:12 PM
  #536
AdvanZ33's Avatar
AdvanZ33
Thanks
Wheel sizes and offsets?
Old Sep 26, 2010 | 03:18 PM
  #537
cipric76's Avatar
cipric76
Any rubbing on front? According to my calculations you should have 2mm extra clearence on the fender side compared to what I have and my setup rubs?
TY
Old Sep 26, 2010 | 03:21 PM
  #538
cipric76's Avatar
cipric76
19x9 +18 with 275/30-19
19x10 +22 with 295/30-19
Nismo springs and shocks
TY
Old Sep 26, 2010 | 03:25 PM
  #539
terrasmak's Avatar
I should get my matching front wheels this week. Full set of RPF1's for the track and my NT03's for the street.
Old Sep 26, 2010 | 03:36 PM
  #540
AdvanZ33's Avatar
AdvanZ33
TY
Unless you're running spacers, a 10.5+15 is much more aggressive than your setup. +22mm further on the fender side and +16mm on the inside rim.
