Unofficial Enkei Wheels Thread
Old Apr 20, 2013 | 10:38 PM
  #1721
2TH PWR's Avatar
2TH PWR
I am cross posting from my build thread so sorry for the double post... but I mounted these beauts up today. Can't wait to get them on the car and try them out.
Old Apr 21, 2013 | 09:38 AM
  #1722
terrasmak's Avatar
Originally Posted by reuben350z
That's a beast set up. Any rubbing in the front? Did you have to add more camber or anything?
No rubbing, but it is a track alignment. I run the front at -3.2 camber.
Old Apr 22, 2013 | 12:39 PM
  #1723
Get Your Wheels's Avatar
Get Your Wheels
Vendor - Former Vendor
The 295's look meaty mounted up on the Black RPF1s 2TH PWR!
Old Apr 22, 2013 | 06:13 PM
  #1724
amoney90's Avatar
amoney90
Default Opinions on this RPF1 deal
Hey guys, I've been stewing on this set of wheels/tires I've found locally and endlessly searching for pics of this specific setup to see how it would work on my car. I have an 04 performance stock suspension and non brembo brakes, but looking to drop it .5-.8".
Anyway, I found a set of RPF1's in a 17x9.5 +38 with 255/40 falken Azenis RT615 for $1200. I autocross and do some occasional track days locally. Not really looking for a "flush" look but like more rubber than wheel personally. Any thoughts on that deal if its worth snagging or holding off for a different set up. Thanks in advanced for any thoughts and opinions.
Old Apr 22, 2013 | 06:22 PM
  #1725
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Well I would buy 20-25mm spacers and run a 285 all the way around
Old Apr 22, 2013 | 06:26 PM
  #1726
amoney90's Avatar
amoney90
Well due to fund reasons I would be running the tires on them until they were worn out, only have 2k miles on them now. Just curious if that wheel size is WAY far off than desirable for a Z, all I can find is people saying run lower offsets but is that just for looks or functionality?
Old Apr 22, 2013 | 06:59 PM
  #1727
sofa king's Avatar
sofa king
just save until you can buy what you want without compromise.
Old Apr 22, 2013 | 07:02 PM
  #1728
amoney90's Avatar
amoney90
I guess I don't know what "specs" I WANT. I guess thats more my question. I want RPF1's without a doubt. They have been my "dream" wheels since I've been into cars. I don't mind having 17's because the tires are a little more affordable as well, I just need to know if that setup will physically fit a Z well without any rubbing or anything like that.
Old Apr 22, 2013 | 07:04 PM
  #1729
2004Black350z
Exhaust Whore
Do you understand offset? Not being a dick simply asking. Took me a while to understand it
Old Apr 22, 2013 | 07:25 PM
  #1730
amoney90's Avatar
amoney90
I do somewhat, I probably should better than I do, I'm a dealer tech for a living lol +38 meaning the wheel bolts on 38mm from the center of the wheel towards the front face of the wheel correct?
Old Apr 22, 2013 | 07:31 PM
  #1731
drvqz33's Avatar
drvqz33
38 will tuck in the fender more
i believe 30 is stock
20-22 imo is a good flush look
Old Apr 22, 2013 | 08:13 PM
  #1732
terrasmak's Avatar
Wait for wheels with better specs
Old Apr 23, 2013 | 07:14 AM
  #1733
amoney90's Avatar
amoney90
Thanks for the input guys, I'm just going to hold off for a set of 18's.
Old Apr 23, 2013 | 08:44 AM
  #1734
MonkeyMagic72's Avatar
MonkeyMagic72
I run RPF1's f/r 18s 9.5/+15 245-40, 10.5/+15 275-40 with 2" and 2.25" drop without rubs. Save for the 18's you can run larger in width for more tires, therefore more surface contact between the rubber and ground. RPF1 18s are very light. Last time before I mounted the tire, I put them on scale, and 9.5 weight 18.4 lbs and 10.5 weight 18.8 lbs. These are the best track wheel you can get for the money. Good luck on hunting one
Old Apr 23, 2013 | 10:26 AM
  #1735
ronn1's Avatar
ronn1
Since you've been waiting for these wheels, I don't see why you can't use them and a 20mm spacer all around. In order maintain the proper stagger, you might want to consider 245/40 and 275/40. That's what I used on my 18 wheels. You will have more gap though...lowering will help. BTW, that's a very good deal.
Old Apr 23, 2013 | 01:23 PM
  #1736
Waiz's Avatar
Waiz
That's not really a deal if you then have to pay $250 for spacers on top of purchasing the wheels.
I would expect to pay around $1,500 to $2,000 max for a set of RPF1's in the proper sizing (with tires)
Old Apr 23, 2013 | 03:10 PM
  #1737
2004Black350z
Exhaust Whore
Where do you guys find center caps for the rfps
Old Apr 23, 2013 | 03:31 PM
  #1738
ronn1's Avatar
ronn1
I had these when I had my other wheels...$120 for all four>>>
http://www.ebay.com/itm/HUBCENTRIC-BOLT-ON-20MM-WHEEL-ADAPTER-SPACERS-PATTERN-5X114-3-CB-66-1MM-12X1-25-/150988134621?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ANissan%7CModel%3A350Z&hash=item23279818dd&vxp=mtr
Old May 1, 2013 | 10:14 AM
  #1739
reuben350z's Avatar
reuben350z
Just ordered my RPF1s matte black staggered set up
Still contemplating which tire set up to go with..
Hankook V12
255/40/18 275/40/18 or..
265/35/18 285/35/18
So stoked.. This week is prob gonna go by super slow /:
Old May 1, 2013 | 10:19 AM
  #1740
Bmurray350z's Avatar
Bmurray350z
Either of those tire setups will be good, if you're not lowered the 40 series will fill in the wheel gap a little more if that matters to you.
I am hopefully trading my varrstoens for some some black rpf1s here within the next week or so.
