Unofficial Enkei Wheels Thread
Old Dec 12, 2013 | 09:22 AM
  #1961
ZoneMaster's Avatar
ZoneMaster
They'll sit just at the fender, maybe just a touch inside. Flush, but no poke.
I run the same offsets on 19" RP03 RCs and they sit just about perfect.
Old Dec 12, 2013 | 10:02 AM
  #1962
Itzcashew's Avatar
Itzcashew
This. But if you are planning to go lower than 1" they will camber in so it wouldn't be as flush as say +15 would be.
Old Dec 19, 2013 | 01:53 PM
  #1963
Bmurray350z's Avatar
Bmurray350z
Joined the club...
Enkei RPF1
18x9.5/10.5 +15
255/40
275/40
Old Dec 19, 2013 | 01:56 PM
  #1964
pyshin's Avatar
pyshin
w00t Welcome!
Wait why is this thread in "Maintenance & Repair"..?
Old Dec 19, 2013 | 02:02 PM
  #1965
Bmurray350z
lol i just noticed that too...
so is it "cooler" to not run center caps with these wheels?
Old Dec 19, 2013 | 02:25 PM
  #1966
pyshin's Avatar
pyshin
^^^ Honestly I havn't seen many with center caps on any vehicle...
Mine came cap-less but I'm going to order a set soon.. imho a wheel looks naked without a cap, quality lugs.. hell even a clean valve stem/cap; it's all about attention to detail for me.
Old Dec 19, 2013 | 02:56 PM
  #1967
mr. sparco's Avatar
mr. sparco
I PD'ed mine black.
Old Dec 19, 2013 | 02:59 PM
  #1968
Bmurray350z
that looks good.
Old Dec 20, 2013 | 03:20 AM
  #1969
2004Black350z's Avatar
2004Black350z
Exhaust Whore
I like Nextcores Center cap. More info please?
Old Dec 20, 2013 | 07:05 AM
  #1970
VengefulHitman's Avatar
VengefulHitman
Default RPF1 Center cap alternative
Recently got some gunmetal 18x9.5 +15 RPF1, and was wondering if there were any center cap alternatives. Not a fan of the RPF1 center caps, i would try a cheap flat DIY center cap but it looks like the axle nut and cotter pin stick slightly farther out on than the wheel face on the rear.
was wondering if anyone has tried the PF01 center cap on the RPF1? i think the diameter is roughly the same but not 100% sure.
Old Dec 27, 2013 | 03:27 PM
  #1971
nismofreak1208's Avatar
nismofreak1208
Finally picked up a set of enkei rpf1 18x10.5 +15 in a square setup, was wondering what would be a good meaty size tire to run? My nismo is lowered with rolled fenders. Trying to change setups from my current work wheels 19x9.5 +15 (235/35/19) front and 19x11 +5 (265/35/19). Thanks guys!
Old Dec 27, 2013 | 03:44 PM
  #1972
pyshin's Avatar
pyshin
^^^ 285/35 square, do you have FUCA's? You'll need to run ~-2.75-3.0 degrees of camber to fit them in the front, but the rear will be fine since you're already rolled.
I have 18x10.5 +15 square myself and plan on running 285/35 square when my current Sumi's run their course.
Old Dec 27, 2013 | 04:00 PM
  #1973
Barnabas's Avatar
Barnabas
National Z Club President
+1 on 285's all the way around thats what i ran
Old Dec 28, 2013 | 07:23 PM
  #1974
terrasmak's Avatar
Camber will depend on tires and ride height, my RS3's require a bit more front camber to clear. I run -3.3ish and slightly rub on the outside.
Old Jan 15, 2014 | 07:02 PM
  #1975
Rev_Night's Avatar
Rev_Night
Ok, so I see people here with my similar setup, but I want knowledgeable people (aka not myself) to confirm that my intended setup will work. Please note, that my car's suspension/coilovers are KY V2s, but it is still the stock height. And my fenders are not rolled. Are spacers needed?
Current OEM 2007 350z Touring V2 Rims:
Front
Offset: +30mm
Tire: 225/45/18
Rear
Offset: +33mm
Tire: 245/45/18
New Setup: Enkei RPF1s with Michelin Pilot Super Sports
Front
Offset: 15
Tire: 265/35/18
Rear
Offset: 15
Tire: 285/35/18
Old Jan 15, 2014 | 07:43 PM
  #1976
pyshin's Avatar
pyshin
Here are the approximate measurements of the tires you're proposing (I say approx. because all tire brand/models vary in actual size):
Front:
Rear:
Instead of 265/35 in the front which would make the width of the tire ~1" wider than the wheel width of 9.5"... I would suggest running 255/40 which puts it at ~.5" wider with the rear 285/35 being ~.75 wider than the 10.5" width.
255/40 and 285/35 also have similar side profile measurements, less than .2 of a difference
You could also run a 255/40 f and 275/40 r setup which would give you a slightly taller side profile in the rear...
If you want to play around with sizes search here: http://tire-size-conversion.com/tire-size-calculator/
In all honesty your first proposed size estimate would work fine, just wanted to provide some input into alternatives.
And you don't NEED a rear roll at stock height, but I would get one if you are able.
Old Jan 16, 2014 | 02:14 AM
  #1977
terrasmak's Avatar
Front
Offset: +30mm
Tire: 225/45/18
Rear
Offset: +33mm
Tire: 245/45/18
Front
Offset: 15
Tire: 265/35/18
Rear
Offset: 15
Tire: 285/35/18
You may need a slight pull/roll up front, WetdreamZZZ car run that combo , lowered with stock control arms and slightly rubbed. I pulled the front by hand in about 2 minutes and he cleared. He ran RS3's that could have slightly more of less clearance.
The rear will need a roll. No going around that.
BTW, the tire combo I mention is perfectly matched, no added understeer, no issues with ABS/VDC or TCS. You speedo will be off about 1.5 to 2 MPH do to them being slightly shorter than stock.
Old Jan 16, 2014 | 01:28 PM
  #1978
Rev_Night's Avatar
Rev_Night
Is there any difference in street performance with a front of 255/40 vs 265/35? The tires cost the exact same. And I'm fine with rolling the back fenders, as I have a heat gun and access to a fender roller.
The final question I have why I would even need to roll fenders in the first place? Is this only because of the +15 offset of the enkeis? If RPF1s came in +30/+33 like stock, I wouldnt need to roll at all?
Old Jan 16, 2014 | 01:37 PM
  #1979
pyshin's Avatar
pyshin
^^^ If the price is the same go with your original plan of 265/35, it's a wider tire. But as terrasmak said you will probably have to roll/pull up front if you ever lower your Z
The only reason you would need to roll your fenders at stock height is if you hit a bump or any road hazard that caused your rear shock/spring to compress more then it normally does, your 285/35 tire would rub the fender (285 is a fairly wide tire). It's more of an issue if you are lowered; but again since you have the means, do it.
And don't settle and get more positive offset, your 18x10.5 +15 with 285/35 in the rear will be a perfect match with no sunken look.
Old Jan 16, 2014 | 01:43 PM
  #1980
Rev_Night's Avatar
Rev_Night
sweet **** man, thanks. I'll post pics when I put them on the car. Since they are being paired with summers, even here in VA, I have another month+.
