I need someone to confirm Kics Spacers:
Old Feb 29, 2008 | 10:49 AM
Motormouth's Avatar
Motormouth
Default I need someone to confirm Kics Spacers:
What does your adapter look like that you use to secure the spacer to the hub studs?
is it four pronged? the little cone shaped bolts is what I am talking about.
I am trying to see if these are universal or unique to each set. I sold a set and someone stole the key out of the package.
thanks!
Old Feb 29, 2008 | 10:51 AM
Motormouth's Avatar
Motormouth
< four holed anchors.
Old Feb 29, 2008 | 11:04 AM
first350's Avatar
first350
here's mine...I started a thread w/ more pics in it, search my SN for it.
*I got a 10mm and 15mm set, both adapters are identical.
top view:
Old Feb 29, 2008 | 11:10 AM
Motormouth's Avatar
Motormouth
that is all I needed, thanks a lot man!!!
The package was open when my buyer got it and the tool was gone. hopefully a local has a set of spacers he can borrow the key from!
/Tom
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Not sure if the Kics are universal to every wheel. I had shave off 1/4 inch of my stock studs in order for my spacer to sit flush with the wheel hub.
The "tool" youre talking about is just a spark plug installer.
nvm ... well I guess mine didn't come with the 4 prong key.
Old Feb 29, 2008 | 11:12 AM
Motormouth's Avatar
Motormouth
mine didn't sit flush with the 15mil, it's better to have more thread showing.
I am talking about the adapter key, nothing else dutchie. do you have a set of them?
Old Feb 29, 2008 | 11:14 AM
dutchboy350Z
Finally some go
yeah I just realized that. I have a set of kics on my rear wheels, but I didn't need a special 4 prong tool to tighten them.
Old Feb 29, 2008 | 11:17 AM
Motormouth's Avatar
Motormouth
how did they attach?
Old Feb 29, 2008 | 11:48 AM
dutchboy350Z
Finally some go
Same type of rounded lug nut. I just used and ratchet wrench to tighten them.
edit: when I mean "rounded", I mean tapered one side and hexagonal on the other.
http://www.evasivemotorsports.com/me...de=KICS-5120W3
Old Feb 29, 2008 | 11:51 AM
first350's Avatar
first350
FWIW - each set I got, had 2 of those adapters....so plenty of ppl should have at least an extra laying around.
Motormouth's Avatar
Motormouth
impossible.
Old Feb 29, 2008 | 01:12 PM
noodleman's Avatar
noodleman
20mm spacers doesn't use the 4 prong adapter...it has some other hex shaped adapter to mount the nuts.
I'll try to get a pic of the adaptor when i get home.
Old Feb 29, 2008 | 04:15 PM
anotheraznguy's Avatar
anotheraznguy
i used to sell kics spacers alot and isntalled alot
10-15mm use the 4 prong spacer
that 4 prongs are the same between kits
the 20-30mm use the socket style piece.
Now depending on the back of the wheel' if you have a cavity you may not need to shave the studs.
if you have no hole or are running a 15mm or less spacer you may need to hack the lugs slightly
Old Feb 29, 2008 | 08:58 PM
Sick Z's Avatar
Sick Z
hey motomouth, did you sell those 15mm spacers already?
Old Feb 29, 2008 | 09:07 PM
Motormouth's Avatar
Motormouth
yeah and when I shipped the bolt tool the package arrived ripped open and no tool so I was trying to help out bryce while I file a claim with Fedex.
spacers are useless if you can't attach them
If anyone has an extra key I can borrow or have, please PM me, thanks!
Dr.Paulyy
Jul 29, 2019 07:45 AM
350z82
Oct 1, 2015 06:25 PM
