Widest Toyo R888 on 10.5" Rim; Questions before purchase..
Old May 16, 2008 | 05:24 PM
DRIFT's Avatar
DRIFT
All LASER LASIK
Originally Posted by JETPILOT
My car is pretty low... this is the 295/30/19 and a 255/35/18 18X9 +22/18X10 +25. The 295/s rub with less than -1.6 camber, but I use the car mostly on the track so I can definetly use the camber. These tires are very wide overall for their treadwidth. You can't use really aggressive offsets with these tires.
JET
JET, please clarify something for me. Are you running a 295/30/19 on an 18x10 +25 in the rear? Doesnt that mean its a 19" tire on an 18" rim?
Old May 16, 2008 | 05:40 PM
JETPILOT's Avatar
JETPILOT
Damn.... I meant 19X10 +25 rear. I have 18" fronts and 19" rears.
JET
Old May 20, 2008 | 04:22 PM
DallasZ's Avatar
DallasZ
** Ordered 255/35/18 for the front and 305/35/18 for the rear.
** 305's on backorder for a week so I have some time to change.
** Feel free to correct me.
** I understand that I'll have to roll/cut the fenders.
Old May 20, 2008 | 05:41 PM
JETPILOT's Avatar
JETPILOT
Wow... that a huge stagger 255/305. And the rear wheel is 1.38 inches larger than the front diameter.
275/305 is what you want.
JET
Old May 20, 2008 | 07:39 PM
DallasZ's Avatar
DallasZ
**Jet so this is the point where you tell me that I won't have an issue stuffing the 275 in the front....
** I was thinking I was being aggressive in the front; for example the Porche 911 Turbo runs 235/18 fronts and 305/18 rears.
** Is there other reasoning behind reducing the stagger besides preserving the VDC?
Old May 20, 2008 | 08:06 PM
Chebosto's Avatar
Chebosto
you can stuff the 265/35 on the +15 if you're cambered out to like -2.xx. should clear the front fender edge and the inner suspension arm.. remember the 265 R888 is like a 275 normal tire.
as for rears. well. with a +15 rear and 305s.. they're gonna stick out past the fender. so even if u get camber arms and dial in negative for the rear, its not going to help acceleration that much.
what engine mods do you have that warrants a 305 rear? just curious
Old May 20, 2008 | 08:25 PM
DallasZ's Avatar
DallasZ
** I think I need the 305 because I'm having traction problems now
** Turbonetics/Built 8:5:1/F-Con/Quaife
** The choice of the 305 size was because I can't get the R888 in a smaller size 35 profile; the R888 goes from 275 to 305; thought the 275 would not be enough; I could get a 285/30 or 295/30 nut anything smaller then a 35 profile on 18's looks horrible as some of the previous posts and pics point out.
** Was originally going to buy NT-01's but wanted a semi-slick with some ability to evacuate water; to my knowledge the R888 is the only tire that fit's the bill.
** There is a post in this thread of 305 R888 with similar offsets and they don't really stick out that far. Perhaps I'm missing something?
Old May 20, 2008 | 08:38 PM
TimeAttkZ's Avatar
TimeAttkZ
I would get the fronts a bit wider so that your not staggering the crap out of them.
Front 265/35/18
Rear 295/30/18
In my opinion the 305's looks ridiculous unless you have a 11.5 rear wheel. It will bulge out way to much. The 295/30 looks great on chestons Z.... he just needs to lower it some more
Unless your pushing 900hp you wont need 305's. The 295 in the R888 will be more than sufficient for anything the Z has got. These tires are nuts for the street already!
Old May 20, 2008 | 08:39 PM
JETPILOT's Avatar
JETPILOT
Well you have the same problem I had. I got a 19" rear wheel to fit the corrct size 295/30/19 tire. 911's have a rear bias weight distribution. That's the reason for the really wide rear tires.
JET
Old May 25, 2008 | 08:33 AM
DC350ZTrack's Avatar
DC350ZTrack
I don't want to beat this thread to death, but I have a simlar question as the OP.
I have 18/9.5 and 18/10.5 (both +22) track wheels and I just ordered Toyo R888s in 275/35/18 and 295/30/18. The difference in the overall diameter front to back is about .6 inches - am I going to run into any issues with this setup? Would I be better off running 305/35/18s in the back?
Old May 25, 2008 | 10:56 PM
JETPILOT's Avatar
JETPILOT
You'd be better off running the 305/35/18. That's going to cause problems with VDC and look weird.
JET
Old May 26, 2008 | 05:21 AM
DC350ZTrack
JET
Thanks for the help JET - I'm trying to change my tire order now.
Old Jun 8, 2008 | 07:46 PM
xcessiveskllzz's Avatar
xcessiveskllzz
so if i ordered the rpf1 18x10.5 rear +15 offset with a 275/35 rear and 18x 9.5 front +15 245/40..need to roll fenders? and will it clear coilovers? what offset should i get without rolling fenders?
Old Jun 8, 2008 | 10:34 PM
moforeynolds's Avatar
moforeynolds
Originally Posted by Crom
Do you have any side pics ?
follow his sig:
http://us.st12.yimg.com/us.st.yimg.c...g_2002_3582674
Old Jun 9, 2008 | 07:22 AM
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by moforeynolds
thanks
but thats actually old setup, in that pic i had T1Rs 285s
here is with the R888s (old pic with old breaks and suspension setup )
Old Jun 9, 2008 | 08:18 AM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Im running stock spec Camber and was running 265/35 285/35 on my RPF1's in the 9.5 10.5 +15. My rears are rolled and pulled slightly and had 0 problem front and rear.
HOWEVER, I hated the tire (Bridgestone RE01A PP) and have since switched to a KDW2 in 255/40 295/35 (exact same diameter around) A lot beefier tire, but way less beefy than my old 275/40 rear I was running, looks great IMO.
Also my 295 KDW does not buldge out like that and I think the website claims to be 11.7" wide. It does have a slight bubble to it.
If I were running a 305/35 in the rear I would want a 275/35 MIN in the front, but ideal would be 285/35 or even a 255/40 would look better than what you propose....
Old Jun 14, 2008 | 07:39 PM
DallasZ's Avatar
DallasZ
Quicksilver; seeing the 305's on the car makes me a believer.
Do they rub?
What offset are those rims.
Old Jun 14, 2008 | 10:57 PM
  #38
IIQuickSilverII
Originally Posted by DallasZ
Do they rub?
yes, i had to cut and pulll fenders to get them to fit...
this are 19x10.5 i believe the offset on them is +26
Old Jun 15, 2008 | 05:45 PM
  #39
thinking's Avatar
thinking
The 911 is a rear engine car. That is one reason why it has rear tires that are much wider than the front tires.
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
