19" Tire Pressure Question
Hey guys,
Really simple question. I just wanna make sure I don't under inflate the tire. But can anyone tell me the correct psi to have the tire set at for 19" rims? I have all 4 set at 37 psi right now (what manual says for the 18" stocks).
Tires are 245/35 & 275/35
Originally Posted by whitecel
Hey guys,
Originally Posted by davidv
19 inch tires are bigger than 18 inch tires so you have to add one more inch of air pressure.
I did get the joke, but others might take this seriously and have a misunderstanding.
Just so that it is clear, tire pressures remain the same, independent of the wheel size. 35-37 psi is a good starting point no matter what wheel size or tire size you have on your 350z car.
--Spike
Hey guys, thanks for the info on tire pressure. I do have a question for you though.. I have z-rated tires on 20'' wheels and was wondering what the correct PSI should be... also please state if it's the correct psi you're listing is when the tires are cold or hot. Thanks!!!
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
