Slip on highway...anyone else?
Old Aug 13, 2008 | 02:55 PM
  #41
Spike100's Avatar
Spike100
Originally Posted by DrPhantum
That reminds me of an old saying, too...
"If you're not a part of the solution... you're part of the problem"
I was trying to be part of the "solution." That is why I posted a message that advised not mounting front tires that are taller than the rears.
I guess I didn't make it clear enough (but I tried). I do attempt to post accurately here, so it's a disappointment when someone tells me I'm part of the "problem."
--Spike
Old Aug 13, 2008 | 03:16 PM
  #42
OhSnapZ's Avatar
OhSnapZ
this happened to my Z when I upgraded to 19 inch volks.. .the tire size was incorrect.. when I finally bought a new set of tires in the correct size, the problem went away.
Old Aug 28, 2008 | 11:16 PM
  #43
Otis's Avatar
Otis
Alright, another newbie with the similar question here: I rotated tires front to rear. The rears are now 225-50-17 and the fronts are 235-50-17, a difference of .20" taller sidewall height on the fronts, and I'm getting the same thing - TCS light on when slow cornering. Same fix - match tires or larger on back makes the TCS issue go away?
TIA.
Old Aug 28, 2008 | 11:31 PM
  #44
TIA.
Correct. Front tires are taller than the rear. This may be effecting TCS.
Old Aug 29, 2008 | 04:47 AM
  #45
350z-Jim's Avatar
350z-Jim
TIA.
There is no "rotating tires" on a 350Z. The OEM wheels are larger in the rear and smaller in the front, both in terms of width and overall size around. You can't rotate them. The rear's stay on the rear and fronts on the front. When the tires wear out you replace them, that simple.
If you really want to you can dismount the drivers rear tires and put it on the passenger rear wheel as long as your tires do not have an inside and outside position (like Falken Azenas), same for the fronts. Other then this, there is no rotating.
Put the right wheels on the right position and your TCS issue will go away.
Old Sep 24, 2008 | 05:05 PM
  #46
bloodwings19's Avatar
bloodwings19
Originally Posted by DavesZ#3
It sure sounds like you've got a wheel/tire mismatch. As davidv pointed out, check to make sure the right tires are on the front/rear positions.
+1, Thanks to these vets, I know why I have this problem. I knew I should of stayed with Toyo tires, but my friend offered me barely used Nitto Extreme set for $300, so I took it. When I had Toyo, the slip never ever came on, it was 275 35 19 (rear) and 245 35 19 (front), but when I switched tires to Nitto 275 35 19 (r) and 245 30 19 (f), my SLIP light comes on, on 1 really curvy turn, otherwise, it don't see SLIP.
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Paul.
Oct 16, 2015 07:34 PM
NFAC
Sep 26, 2015 10:11 PM
