Newby Need Upgrade Support!
Old Aug 5, 2008 | 08:47 AM
sam2944's Avatar
sam2944
Default Newby Need Upgrade Support!
Just purchased my first Z, a 2004 red Touring Coupe. I want to plus size wheel. Is the 19" a nice upgrade? I want to keep oem cool features and dont sacrifice suspension goodies. What sizes you guys recommend?
Old Aug 5, 2008 | 09:36 AM
halcyon901's Avatar
halcyon901
check out the top 100 questions FAQ. they have a section on wheels and tires, along with tire size calculator.
Old Aug 5, 2008 | 09:39 AM
sbZenth's Avatar
sbZenth
^ yep. Thats a good place to start
18s 19s and even 20s are common options
most people go for 18s and 19s though.
Old Aug 5, 2008 | 10:37 AM
saladito6's Avatar
saladito6
^ Miller Light Good Call of The Day
Old Aug 5, 2008 | 01:54 PM
I recommend that you do what pleases you.
Old Aug 5, 2008 | 07:28 PM
racerfreakxxx's Avatar
racerfreakxxx
i'd say 18 is the best... anything over that is just too much weight imo
Old Aug 5, 2008 | 09:39 PM
Allen331's Avatar
Allen331
Damn I don't know what kinda of 18s you're running, but there are many 19s that weigh 19-23 lbs...which is pretty damn good.
Old Aug 5, 2008 | 10:07 PM
terrasmak's Avatar
NT03's , RPF1's and many other are under 20 pounds, you can also get some nice 19's under 20 pounds too.
Old Aug 6, 2008 | 04:22 AM
asmvp84's Avatar
asmvp84
i think you need to decide what route you want your car to go in...if you want it to be a track car, drift, or show and that would help determine what would be more appropriate.
Old Aug 6, 2008 | 06:54 AM
Rekinyze's Avatar
Rekinyze
i would definately say 19" is the best look for the Z. I would go for a 10.5" in the back with a +20 to +30 offset and a 9.5" in the front with a +20 or so.
Old Aug 6, 2008 | 09:09 AM
Allen331's Avatar
Allen331
Originally Posted by Rekinyze
i would definately say 19" is the best look for the Z. I would go for a 10.5" in the back with a +18 to +22 offset and a 9.5" in the front with a +20 or so.
Correction
Old Aug 6, 2008 | 12:35 PM
Rekinyze's Avatar
Rekinyze
Correction
Dunno man...I have 10.5 +30 SSR D5Rs in the back and they line up well with the fender...actually just a tad bit outside. I'm assuming offset is considered a standard measurement...but it may vary a little by wheel....
But i guess you are correct under normal circumstances.
Old Aug 6, 2008 | 01:21 PM
terrasmak's Avatar
Offset should be determined by the tire size you want to run.
Old Aug 7, 2008 | 08:06 AM
Rekinyze's Avatar
Rekinyze
^ huh?
Old Aug 7, 2008 | 08:33 AM
z350boy's Avatar
z350boy
I think what is being referred to is the fact that tire size ( width) will affect how much offset is needed. The wider the tire the higher the offset will need to be to keep the tires flush with the fenders.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
