Tire Size Help on stock 18"s 8.5 front 9.5 rear
Old Jan 27, 2009 | 04:27 PM
jattgdup's Avatar
jattgdup
Default Tire Size Help on stock 18"s 8.5 front 9.5 rear
I know this question has already probably been asked but I need to know how wide i can go on the front on the 18 inch 8.5s and rear 9.5s tire width im thinkin 245 40 18 and 275 40 18 with no problems?
Old Jan 27, 2009 | 05:23 PM
stinky350z's Avatar
stinky350z
ya i think u would be ok with that tire size man good luck
Old Jan 27, 2009 | 06:22 PM
Big_C's Avatar
Big_C
I ran 9.5 +12 and 10.5 +15 with 245.40.18 and 275.40.18 no problem. You'll be fine.
Old Jan 27, 2009 | 07:13 PM
Best way to avoid a headache: Stick with the OEM sizes.
Old Jan 27, 2009 | 11:55 PM
terrasmak's Avatar
Stock rims are 18x8 front and rear for 03 to 05 , 8 front 8.5 rear on track on newer. You need different wheels to run 275's on the rear.
Old Jan 28, 2009 | 03:29 PM
Spike100's Avatar
Spike100
^^ He says his rear wheels are 9.5" wide, so 275's are very conservative and will work.
--Spike
Old Jan 28, 2009 | 05:10 PM
redlude97's Avatar
redlude97
--Spike
He also said they are stock, which would be contradictory to his statement...
Old Jan 30, 2009 | 05:27 PM
jattgdup's Avatar
jattgdup
Default but is that the widest i can go in the back with no probs?
Is that the widest i can go with 18 inch 9.5 rears? Can i go wider than 275 with no probs, if so whats the widest?
Old Jan 30, 2009 | 05:28 PM
jattgdup's Avatar
jattgdup
Default Its an 08 350
its an 08 350 buddy
Old Jan 30, 2009 | 06:51 PM
T_K's Avatar
T_K
its an 08 350 buddy
The base wheels are 18x8 Front and 18x8.5 Rear. The GT wheels are 18x9 Front and 19x10 Rear. The Nismo Edition wheels are the same dimensions as the GT wheels. The chrome wheel option, I believe are 18x8 at all four corners. If your Z has a 9.5in wide rim, they are not stock, unless you bought the LMGT4 wheels as an added accessory.
TK
Old Jan 30, 2009 | 08:21 PM
Toby-22's Avatar
Toby-22
What about 295/30 on an 18x9.5 rim? I know they're not recomended but has anyone tried that? Thanks and sorry for hijacking the thread op.
Old Jan 30, 2009 | 08:26 PM
Want wider tires? Get wider wheels.
Old Jan 30, 2009 | 09:30 PM
Get_Zwole's Avatar
Get_Zwole
i agree if they are stock they arent 9.5's but if you have 9.5's magically then 285 will work i wouldnt go any wider unless you actually need them for traction.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
hardkicks
Sep 20, 2015 12:28 PM
CJs_Z33
Sep 18, 2015 12:06 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
