Spare Tire for Brembo Brakes
Old Feb 18, 2009 | 11:25 AM
350Z_NOW's Avatar
350Z_NOW
Default Spare Tire for Brembo Brakes
I upgraded to OEM Brembo, I'm curious if my non Brembo spare tire 16" fit ?
Old Feb 18, 2009 | 02:35 PM
240zx's Avatar
240zx
No, it wont. You're going to have to buy a 17" spare wheel/tire.
Old Feb 20, 2009 | 11:36 PM
350Z_NOW's Avatar
350Z_NOW
you think 5mm wheel spacer will make it fit?
Old Feb 20, 2009 | 11:44 PM
SuperBlack350z's Avatar
SuperBlack350z
nope, you need the 17" spare like the person said above. i found a brand new one on here for 50 shipped. not a bad deal.
Old Jun 11, 2009 | 07:05 PM
350z006's Avatar
350z006
WTH?! I bought a Brembo spare 155/80/17 when I upgraded to brembos and it dosen't fit! What the hell?!
Brembo owners chime in!
Edit: It kinda fits, but it dosen't fit snug in the rear wheels...is this right?
Old Jun 12, 2009 | 02:32 AM
=Cerberus='s Avatar
=Cerberus=
I just did the Brembo swap, and I was nervous about going on a road trip from what i have read on here about the spare not fitting. I tried mine for ***** and giggles and it fit front and back.
I have an 06.5 base model. So I can only assume that nissan figured it was cheaper to just make 1 spare fit all then two different size spares.
If you can find one for sale that would be your best bet. I have called my local dealers, and all they can get are the rims for around $250, then you still have to get a tire mounted to it.
Old Feb 16, 2012 | 08:50 AM
ineedspeed's Avatar
ineedspeed
Default Spare tire question
Hello everyone, I have a question about spare tires. I purchased an 03 Track model that did not come with the spare tire or tool kit. I've been scanning Ebay and I see that there are 16's and 17's out there. I also have read that there is a specific version of the spare tire that fits the Track model with the Brembo brakes. Is there a specific spare for the Track model or will any 17 inch spare fit on the car, I assume the 16 inch wont fit.
TIA
Old Feb 16, 2012 | 09:02 AM
terrasmak's Avatar
You need the track model spare to clear your brakes. I don't know what size it is . I went with the 370Z spare to clear my aftermarket BBK.
Old Feb 16, 2012 | 09:05 AM
The spare wheel-tire is a bit unusual because of diameter and offset.
You can buy a 17-inch spare but it will not fit in the spare location.
For part numbers visit Courtesy Nissan.
Old Feb 16, 2012 | 09:52 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I replaced my 16" with the 17" after the Brembo upgrade. Everything fit fine.
Old Feb 16, 2012 | 12:03 PM
beezee's Avatar
beezee
I just picked up a 370Z Sport spare tire to clear my BBK. The way it looks it should clear lots of caliper sizes. And it looks good too. Lol. It fits in the spare location in the trunk perfectly. The only issue is the white cup that holds it down to the floor. The bolt is too short. I just got this 2 days ago so I am still trying to figure out how to deal with that,
possibly welding a piece of bolt to it since the existing bolt is a PITA to get out.
Check this thread out.
https://my350z.com/forum/wheels-and-...ght=Spare+tire
Old Feb 17, 2012 | 02:46 PM
ineedspeed's Avatar
ineedspeed
Smile Thank you
Originally Posted by beezee
I just picked up a 370Z Sport spare tire to clear my BBK. The way it looks it should clear lots of caliper sizes. And it looks good too. Lol. It fits in the spare location in the trunk perfectly. The only issue is the white cup that holds it down to the floor. The bolt is too should. I just got this 2 days ago so I am still trying to figure out how to deal with that,
Thanks for the link to the thread. I picked up a spare from a G37, the rim is 18x4 which I hope is the correct one. I'm assuming that the BBK calipers are wider and stick out more than the OEM Brembo's? If that is the case then I won't worry about test fitting it when it arrives.
Old Feb 17, 2012 | 03:28 PM
beezee's Avatar
beezee
You don't need to test fit. I test fitted mine yesterday. That thing will clear just about any caliper on the market now for the Z. I am currently trying out a way to deal with the holding screw cup that I talked about. Will post pics of what I am doing when done. Also the sidewall says to inflate to 60 PSI. I decided to inflate to 50 PSI but after puting it on I realized it needed more air so stay with the 60 PSI
Old Mar 29, 2012 | 04:14 AM
nachospizza's Avatar
nachospizza
Hi Guys I would like to buy one also as I upgrade mine to the Brembo Calipers and I blown my tires two times and my original spare wheel not fit the BBK... where can I purchase one back I don't mind it is used!!! Please send me a link or links thanks!
Old Mar 29, 2012 | 12:37 PM
beezee's Avatar
beezee
Hong Kong is a bit too far from our junk yards. Check eBay. Actually I got mine from ebay.
